Установил Mint 22.1 Cinnamon х64 на Macbook Air 2018 года.
Kernel: 6.8.0-51-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.4.6 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Laptop System: Apple product: MacBookAir7,2 v: 1.0
serial: <superuser required>
Mobo: Apple model: Mac-937CB26E2E02BB01 v: MacBookAir7,2
serial: <superuser required> UEFI: Apple v: 184.0.0.0.0 date: 02/15/2019
ID-1: BAT0 charge: 12.2 Wh (87.1%) condition: 14.0/54.3 Wh (25.8%)
volts: 8.2 min: 7.6 model: SMP bq20z451 status: full
Info: dual core model: Intel Core i5-5350U bits: 64 type: MT MCP
arch: Broadwell rev: 4 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 800 min/max: 500/2900 cores: 1: 800 2: 800 3: 800 4: 800
bogomips: 14400
Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915 v: kernel
arch: Gen-8 bus-ID: 00:02.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915
resolution: 1440x900~60Hz
API: EGL v: 1.5 drivers: iris,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-0ubuntu0.3
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 6000 (BDW
GT3)
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0
Device-2: Intel Wildcat Point-LP High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A bus-ID: 02:00.0
API: ALSA v: k6.8.0-51-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
vendor: Apple driver: wl v: kernel bus-ID: 03:00.0
Bluetooth:
Device-1: Apple Bluetooth USB Host Controller driver: btusb v: 0.8 type: USB
bus-ID: 1-3.3:7
Report: hciconfig ID: hci0 rfk-id: 2 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 113 GiB used: 58.81 GiB (52.0%)
ID-1: /dev/sda vendor: Apple model: SSD SM0128G size: 113 GiB
ID-1: / size: 109.68 GiB used: 58.71 GiB (53.5%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
Swap:
System Temperatures: cpu: 70.0 C pch: 64.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.66 GiB used: 2.38 GiB (31.1%)
Processes: 228 Uptime: 18m Init: systemd target: graphical (5)
Packages: 1881 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
bogomips: 14400
GT3)
Bluetooth:
bus-ID: 1-3.3:7
address: <filter>
Swap:
Пробовал отключить сеть Wi fi, думал может быть она его будит - нет, все равно сразу просыпается.
Попробовал отключить проводную мышь - система ушла с ждущий режим и почему-то полностью выключился ноутбук. Причем примерно 10 минут не реагировал на кнопку включения и не хотел включаться. Потом ожил и загрузился.
Помогите пожалуйста разобраться, как наладить ждущий режим и не сломать все окончательно. Я в Линкусе совсем новичек. Пытался гуглить, но ничего полезного для себя не нашел.
