kot@kot-MS-7917:~$ gnome-boxes %U
(gnome-boxes:986906): Gtk-WARNING **: 21:02:43.868: GtkFlowBox with a model will ignore sort and filter functions
(gnome-boxes:986906): Gtk-WARNING **: 21:02:43.869: GtkListBox with a model will ignore sort and filter functions
(gnome-boxes:986906): Handy-WARNING **: 21:02:44.018: Using GtkSettings:gtk-application-prefer-dark-theme together with HdyStyleManager is unsupported. Please use HdyStyleManager:color-scheme instead.
Boxes-Message: 21:02:44.257: libvirt-machine.vala:274: Failed to connection to system libvirt: Unable to open qemu+unix:///system: Failed to connect socket to '/var/run/libvirt/libvirt-sock-ro': Адмоўлена ў злучэньні
(gnome-boxes:986906): Boxes-WARNING **: 21:02:44.259: libvirt-machine.vala:101: Failed to disable 3D Acceleration
(gnome-boxes:986906): Boxes-WARNING **: 21:02:44.263: libvirt-broker.vala:70: Failed to update domain 'boxes-unknown-2': Failed to set domain configuration: unsupported configuration: Emulator '/usr/bin/qemu-system-x86_64' does not support machine type 'pc-i440fx-8.2'
(gnome-boxes:986906): Boxes-WARNING **: 21:02:44.332: libvirt-machine.vala:101: Failed to disable 3D Acceleration
(gnome-boxes:986906): Boxes-WARNING **: 21:02:44.335: libvirt-broker.vala:70: Failed to update domain 'boxes-unknown': Failed to set domain configuration: unsupported configuration: Emulator '/usr/bin/qemu-system-x86_64' does not support machine type 'pc-i440fx-7.1'
(gnome-boxes:986906): GLib-GObject-WARNING **: 21:02:44.393: ../../../gobject/gsignal.c:2715: handler '2883' of instance '0x559a116be490' is not blocked
