Вопрос по диску
Вопрос по диску
18 апр 2023, 18:38
Есть у меня диск Toshiba P300 HDWD120UZSVA, купленный 3 года назад.
Использовался как файлопомойка.
И вот что-то стал он как-то плохо себя чувствовать
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.2.10-1-MANJARO] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Toshiba P300 (CMR)
Device Model:     TOSHIBA HDWD120
Serial Number:    994EPN8CS
LU WWN Device Id: 5 000039 fdbc63a1c
Firmware Version: MX4OACF0
User Capacity:    2 000 398 934 016 bytes [2,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5319
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Apr 18 20:26:27 2023 +05
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (14631) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 244) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   075   075   016    Pre-fail  Always       -       39388850
  2 Throughput_Performance  0x0005   138   138   054    Pre-fail  Offline      -       74
  3 Spin_Up_Time            0x0007   128   128   024    Pre-fail  Always       -       295 (Average 295)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       2163
  5 Reallocated_Sector_Ct   0x0033   001   001   005    Pre-fail  Always   FAILING_NOW 2005
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   124   124   020    Pre-fail  Offline      -       33
  9 Power_On_Hours          0x0012   099   099   000    Old_age   Always       -       13863
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2146
192 Power-Off_Retract_Count 0x0032   099   099   000    Old_age   Always       -       2189
193 Load_Cycle_Count        0x0012   099   099   000    Old_age   Always       -       2189
194 Temperature_Celsius     0x0002   150   150   000    Old_age   Always       -       40 (Min/Max 21/44)
196 Reallocated_Event_Count 0x0032   001   001   000    Old_age   Always       -       2701
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
ATA Error Count: 17 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        SC = Sector Count Register [HEX]
        SN = Sector Number Register [HEX]
        CL = Cylinder Low Register [HEX]
        CH = Cylinder High Register [HEX]
        DH = Device/Head Register [HEX]
        DC = Device Command Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 17 occurred at disk power-on lifetime: 13857 hours (577 days + 9 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 08 d8 1d 94 08  Error: UNC 8 sectors at LBA = 0x08941dd8 = 143924696
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 00 08 d8 1d 94 e0 08      06:16:29.641  READ DMA EXT
  ef 10 03 00 00 00 a0 08      06:16:29.641  SET FEATURES [Enable SATA feature]
  ef 10 02 00 00 00 a0 08      06:16:29.641  SET FEATURES [Enable SATA feature]
  27 00 00 00 00 00 e0 08      06:16:29.641  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
  ec 00 00 00 00 00 a0 08      06:16:29.638  IDENTIFY DEVICE
Error 16 occurred at disk power-on lifetime: 13857 hours (577 days + 9 hours)
  40 51 f0 e8 1e 94 08  Error: UNC 240 sectors at LBA = 0x08941ee8 = 143924968
  25 00 00 d8 1e 94 e0 08      06:16:19.001  READ DMA EXT
  25 00 00 b8 64 81 e0 08      06:16:18.962  READ DMA EXT
  25 00 00 b8 62 81 e0 08      06:16:18.960  READ DMA EXT
  25 00 00 b8 61 81 e0 08      06:16:18.946  READ DMA EXT
  ef 10 03 00 00 00 a0 08      06:16:18.946  SET FEATURES [Enable SATA feature]
Error 15 occurred at disk power-on lifetime: 13857 hours (577 days + 9 hours)
  40 51 08 78 60 5c 03  Error: UNC 8 sectors at LBA = 0x035c6078 = 56385656
  25 00 08 78 60 5c e0 08      06:14:07.384  READ DMA EXT
  25 00 00 78 d8 81 e0 08      06:14:07.370  READ DMA EXT
  ef 10 03 00 00 00 a0 08      06:14:07.369  SET FEATURES [Enable SATA feature]
  ef 10 02 00 00 00 a0 08      06:14:07.369  SET FEATURES [Enable SATA feature]
  27 00 00 00 00 00 e0 08      06:14:07.369  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 14 occurred at disk power-on lifetime: 13857 hours (577 days + 9 hours)
  25 00 08 78 60 5c e0 08      06:14:03.289  READ DMA EXT
  25 00 08 70 60 5c e0 08      06:14:00.161  READ DMA EXT
  25 00 00 78 d6 81 e0 08      06:14:00.154  READ DMA EXT
  25 00 00 78 d7 81 e0 08      06:14:00.132  READ DMA EXT
  ef 10 03 00 00 00 a0 08      06:14:00.131  SET FEATURES [Enable SATA feature]
Error 13 occurred at disk power-on lifetime: 13857 hours (577 days + 9 hours)
  40 51 08 68 60 5c 03  Error: UNC 8 sectors at LBA = 0x035c6068 = 56385640
  25 00 08 68 60 5c e0 08      06:13:56.235  READ DMA EXT
  25 00 00 78 d5 81 e0 08      06:13:56.234  READ DMA EXT
  25 00 00 78 d4 81 e0 08      06:13:56.214  READ DMA EXT
  ef 10 03 00 00 00 a0 08      06:13:56.213  SET FEATURES [Enable SATA feature]
  ef 10 02 00 00 00 a0 08      06:13:56.213  SET FEATURES [Enable SATA feature]
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     12078         -
# 2  Short offline       Completed without error       00%     12064         -
# 3  Short offline       Completed without error       00%     12049         -
# 4  Short offline       Completed without error       00%     12035         -
# 5  Short offline       Completed without error       00%     12023         -
# 6  Short offline       Completed without error       00%     12012         -
# 7  Short offline       Completed without error       00%     11986         -
# 8  Short offline       Completed without error       00%     11972         -
# 9  Short offline       Completed without error       00%     11957         -
#10  Short offline       Completed without error       00%     11942         -
#11  Short offline       Completed without error       00%     11919         -
#12  Short offline       Completed without error       00%     11898         -
#13  Short offline       Completed without error       00%     11883         -
#14  Short offline       Completed without error       00%     11868         -
#15  Short offline       Completed without error       00%     11853         -
#16  Short offline       Completed without error       00%     11838         -
#17  Extended offline    Interrupted (host reset)      10%     11830         -
#18  Short offline       Completed without error       00%     11815         -
#19  Short offline       Completed without error       00%     11800         -
#20  Short offline       Completed without error       00%     11785         -
#21  Short offline       Completed without error       00%     11750         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Подозреваю что дальнейшая судьба его - разбор на магнитики.
Если ошибаюсь поправьте.
Если таки он труп - хотел бы услышать что можно взять понадежнее для тех же целей(объем можно больше)
ilikethat
Решено: 10
Благодарил (а): 129 раз
Вопрос по диску
18 апр 2023, 19:46
ИМНО. Начал сыпаться, при смерти.
Reallocated_Sector - число переназначенных секторов большое.
Если под файлопомойку, и не большой емкости - то диск с CMR технологией, НЕ черепиной.
Например у WD Purple серия
WD20PURZ
WD22PURZ
WD40PURZ
WD40PURX - такой у меня стоит полгода
еще RED Plus серия
у Toshiba серия MG, но дорого!
Вопрос по диску
18 апр 2023, 20:01
Подумываю взять уже ~10ТБ, что-то типа WD Ultrastar DC HC330.
Но это только вариант на рассмотрении.
Хотелось бы понять что из современных дисков можно брать таких объемов и под такие задачи
Вопрос по диску
18 апр 2023, 20:33
18 апр 2023, 18:38
Помянем. :reap:
18 апр 2023, 18:38
Не Toshiba, и не SMR, в остальном практически пофигу, если нет особых требований к быстродействию (особенно random access, а не линейным скоростям).
Тошиба же массово вторичку делает, у нее целые серии дисков - из первоначально бракованных и восстановленных компонентов других производителей.
А SMR - это SMR. По моему мнению, экономия на их цене не стоит геморроя с ними.
Но если нужна надежность без лишних затрат - только raid1.
Можно btrfs raid1 - в таком случае можно и из трех дисков собрать - будет выгоднее по соотношению цена/полезный объем т.к. в этом случае с ним будет почти как raid5 - данные пишутся только два раза на разных дисках (но с равным заполнением), а не как в случае mdadm - просто тройное дублирование. Ну и для btrfs не нужны идентичные диски. В случае btrfs, диски - 1Tb + 1Tb + 2Tb = полноценный 2TB raid1.
И под простую файлопомойку не считаю разумным брать топовые модели - у них соотношение цены за гиг даже подобному рейду аналогичного размера из трех дисков часто проигрывает, при несоизмеримо меньшей надежности решения.
Real
Вопрос по диску
18 апр 2023, 21:00
Я взял Seagate IronWolf для хранения архивов. Модель ST2000VN004 SATA III, 6 Гбит/с, 5900 об/мин, кэш - 64 МБ, RAID Edition.
Предыдущие диски для этих целей у меня были WD Black 640GB - живы по сей день, хранят холодные архивы.
Выбирал по таким критериям:
- CMR - НЕ черепичная запись - RAID Edition,
- тишина и отсутствие вибраций, после WD Black - прям небо и земля
- большой расчётный ресурс, т.к. IronWolf позиционируются под файл-серверы (а SkyHawk для систем видеонаблюдения)
- в моей моделе нет, но на больших объёмах есть система подавления вибраций, в т.ч. резонанса от нескольких рядом расположенных дисков, в RAID-массивах и т.п.
p.s. если интересна статистика по сотням тысяч единиц hdd и ssd - загугли "backblaze статистика"
Вопрос по диску
18 апр 2023, 21:24
18 апр 2023, 20:33
raid1 ... под простую файлопомойку не считаю разумным брать топовые модели - у них соотношение цены за гиг даже подобному рейду аналогичного размера из трех дисков часто проигрывает, при несоизмеримо меньшей надежности решения
А это идея.
Тогда, наверно, будет неплохой идеей взять 2 вот таких диска WD Purple Surveillance WD42EJRX.
18 апр 2023, 20:33
Можно btrfs raid1
А не будет ли с ней проблем из-за торрентов?
Вопрос по диску
18 апр 2023, 21:31
18 апр 2023, 21:24
Не будет, если на каталоге с ними отключить COW.
sudo chattr +C torrents_folder
На пустом каталоге перед началом его заполнения. Атрибут применяется только к новым файлам, или файлам с нулевой длинной, иначе игнорируется. Ну, и наследуется от каталога, для его нового содержимого. Главное не спутать с атрибутом сжатия - "с". :)
Вопрос по диску
18 апр 2023, 21:49
18 апр 2023, 21:31
Понятно.
Тогда заказываю диски, благо есть в городе по наличию.
Завтра-послезавтра заберу и буду собирать raid1 на btrfs
Вопрос по диску
18 апр 2023, 22:09
Чет сомнения появились по поводу дисков
1. WD Purple Surveillance WD42EJRX - кэш 256 МБ
2. WD Purple WD40PURZ - кэш 64 МБ
И вот не понятно - первый CMR или SMR
Тут пишут что таки CMR.
В сети срач среди диванных экспертов.
Не понятно.
Вопрос по диску
19 апр 2023, 13:15
В общем поискал еще разных обзоров/тестов и т.п. на диски WD Purple Surveillance WD42EJRX - напрашивается вывод что это таки CMR хоть и с довольно большим кэшем.
Буду брать.
Вопрос по диску
19 апр 2023, 15:29
У WD в серии Purple - в единственной нету SMR вообще. Даже у в black есть парочка, а здесь нету.
Но т.к. эти диски заточены под видеонаблюдение, у них есть некоторые особенности работы, и большой кеш.
Основные особенности заключаются в том, что прошивка не нацелена на сохранение данных любым путем. Для нее главное - не устраивать "заторов". Если будет сбойный блок - диск не будет пытаться его вычитывать/записывать многократно, даже на уровне тех дисков что на RAID ориентированы. Он просто его пропустит и будет читать/писать дальше. Т.к. потеря одного блока в видеозаписи - совершенно не критична (ну, сыпанет слегка "кубиком" по экрану, и что?), а вот если видео с камер не сможет записаться из-за занятости диска - это уже может быть неприятно.
И оптимизация многопоточности - расчет на относительно малое количество потоков, но непрерывных - запись с нескольких камер. Запись же совсем мелочи в больших рандомных количествах (как БД) не оптимизируется.
Потому хранить на таких дисках что-то сильно ценное, и не видео, без raid1 - так себе идея. :)
С raid - этой проблемы нету, остается только особенность оптимизации многопоточных операций. Но она же проявляется в основном при максимальных загрузках, а уж торренты - вообще похожи на его основное назначение, т.к. блоки там достаточно крупные, и льются примерно одинаковым потоком. :)
А вообще - по поводу SMR сверяться тут: https://nascompares.com/answer/list-of- ... rives-hdd/
Вопрос по диску
19 апр 2023, 19:20
Диски забрал.
Сейчас будем из них делать btrfs raid1
Вопрос по диску
19 апр 2023, 19:45
slant, поправь если я где-то ошибся.
Допустим диски определились как sda и sdb
1. Монтируем
sudo mount /dev/sda1 /mnt/data
2. Добавляем второй диск
sudo btrfs device add /dev/sdb /mnt/data
3. Конвертируем метаданные
sudo btrfs balance start -mconvert=raid1 /mnt/data
4. Конвертируем данные
sudo btrfs balance start -dconvert=raid1 /mnt/data
После этого можно создать каталог где будут хранится данные, качаемые торрентом и сделать для него
UPD: руководствовался этим и Объединение дисков
Вопрос по диску
19 апр 2023, 20:09
В пункте 2 - разбивку сделать (gpt) и один раздел на весь диск лучше все-таки создать, чем без разделов отдать как raw диск целиком. Намного гибче, и поможет избежать некоторых проблем в дальнейшем, если понадобится переконфигурация на что-либо другое. Т.е. в финале команда должна выглядеть как sudo btrfs device add /dev/sdb1 /mnt/data
И после четвертого нужно еще конвертировать sys блок данных: sudo btrfs balance start -sconvert=raid1 /mnt/data
Причем оно еще будет кричать типа "ОПАСНО! Вы точно уверены?!?" - это нормально и нужно подтвердить. Или оно может даже ключ -f попросить использовать (force) - но в данном случае это действительно надо, т.к. если умрет диск где эти блоки (оно по дефолту как DUP создается) - собрать FS без них уже будет невозможно. Там данные об UUID устройств и прочая "бюрократия" самой FS как структуры.
Вопрос по диску
19 апр 2023, 20:55
Btrfs raid1 собрал.
Буду пытаться забрать с умирающего диска данные, которые не скачать с сети. Они не очень-то и нужны, но их наличие не будет лишним.
slant, спасибо за помощь
