VERSION="21.1 (Vera)"
железо:
Kernel: 5.15.0-67-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: KDE Plasma 5.24.7 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.67 date: 12/29/2022
ID-1: BAT0 charge: 35.9 Wh (88.4%) condition: 40.6/40.6 Wh (100.0%)
volts: 12.2 min: 11.3 model: Hewlett-Packard Primary status: Discharging
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 1527 high: 2159 min/max: 1400/2600 boost: enabled
cores: 1: 1197 2: 1285 3: 2159 4: 1470 bogomips: 20760
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:5
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.6 DRM 3.42
5.15.0-67-generic)
v: 4.6 Mesa 22.2.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-67-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 114.73 GiB (48.1%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 25.9 C
ID-1: / size: 28.92 GiB used: 16.5 GiB (57.1%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /home size: 195.98 GiB used: 98.23 GiB (50.1%) fs: ext4
dev: /dev/nvme0n1p6
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p5
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Processes: 245 Uptime: 22m Memory: 5.71 GiB used: 2.01 GiB (35.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 3165 Shell: Bash
v: 5.1.16 inxi: 3.3.13
bus-ID: 1-5.2:5
5.15.0-67-generic)
bus-ID: 02:00.0
Bluetooth:
bus-ID: 1-4:3
dev: /dev/nvme0n1p6
Swap:
dev: /dev/nvme0n1p5
Попробовал ввести, подсказанные ранее, команды
мар 05 20:40:05 oleg-HP kernel: Linux version 5.15.0-67-generic (buildd@lcy02-amd64-116) (gcc (Ubuntu 11.3.0->
мар 05 20:40:05 oleg-HP kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-67-generic root=UUID=ee1147e5-4>
мар 05 20:40:05 oleg-HP kernel: KERNEL supported cpus:
мар 05 20:40:05 oleg-HP kernel: Intel GenuineIntel
мар 05 20:40:05 oleg-HP kernel: AMD AuthenticAMD
мар 05 20:40:05 oleg-HP kernel: Hygon HygonGenuine
мар 05 20:40:05 oleg-HP kernel: Centaur CentaurHauls
мар 05 20:40:05 oleg-HP kernel: zhaoxin Shanghai
мар 05 20:40:05 oleg-HP kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
мар 05 20:40:05 oleg-HP kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
мар 05 20:40:05 oleg-HP kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
мар 05 20:40:05 oleg-HP kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
мар 05 20:40:05 oleg-HP kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compa>
мар 05 20:40:05 oleg-HP kernel: signal: max sigframe size: 1776
мар 05 20:40:05 oleg-HP kernel: BIOS-provided physical RAM map:
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009ecffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x0000000009ed0000-0x0000000009ffffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20afff] ACPI NVS
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x000000000a20b000-0x00000000da8aafff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000da8ab000-0x00000000da9a7fff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000da9a8000-0x00000000daa2efff] ACPI data
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000daa2f000-0x00000000dabd9fff] ACPI NVS
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000dabda000-0x00000000dda41fff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000dda42000-0x00000000deffffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x0000000100000000-0x000000019effffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x000000019f000000-0x000000021effffff] reserved
lines 1-32
sudo: powertop: команда не найдена
Но пока никакого результата не вижу. Быть может, я делаю что-то не так.
Пожалуйста, помогите настроить электропитание так, чтобы разряд аккумуляторной батареи, на полностью отключённом ноутбуке, снизился до 0% за сутки.
