Настройки управления питанием
1o4ka
Благодарил (а): 23 раза
06 мар 2023, 09:52
NAME="Linux Mint"
VERSION="21.1 (Vera)"
железо:
Kernel: 5.15.0-67-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: KDE Plasma 5.24.7 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.67 date: 12/29/2022
ID-1: BAT0 charge: 35.9 Wh (88.4%) condition: 40.6/40.6 Wh (100.0%)
volts: 12.2 min: 11.3 model: Hewlett-Packard Primary status: Discharging
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 1527 high: 2159 min/max: 1400/2600 boost: enabled
cores: 1: 1197 2: 1285 3: 2159 4: 1470 bogomips: 20760
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:5
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.6 DRM 3.42
5.15.0-67-generic)
v: 4.6 Mesa 22.2.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-67-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 114.73 GiB (48.1%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 25.9 C
ID-1: / size: 28.92 GiB used: 16.5 GiB (57.1%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /home size: 195.98 GiB used: 98.23 GiB (50.1%) fs: ext4
dev: /dev/nvme0n1p6
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p5
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Processes: 245 Uptime: 22m Memory: 5.71 GiB used: 2.01 GiB (35.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 3165 Shell: Bash
v: 5.1.16 inxi: 3.3.13
bus-ID: 1-5.2:5
5.15.0-67-generic)
bus-ID: 02:00.0
Bluetooth:
bus-ID: 1-4:3
dev: /dev/nvme0n1p6
Swap:
dev: /dev/nvme0n1p5
В полностью выключенном состоянии, с отключённым внешним блоком питания, аккумуляторная батарея ноутбука HP Laptop 15s-eq1426ur быстро разряжается (7% за 12 часов). Тест с альтернативной ОС показал следующий результат: 0% за >16 часов.
Попробовал ввести, подсказанные ранее, команды
journalctl -b -1
мар 05 20:40:05 oleg-HP kernel: Linux version 5.15.0-67-generic (buildd@lcy02-amd64-116) (gcc (Ubuntu 11.3.0->
мар 05 20:40:05 oleg-HP kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.15.0-67-generic root=UUID=ee1147e5-4>
мар 05 20:40:05 oleg-HP kernel: KERNEL supported cpus:
мар 05 20:40:05 oleg-HP kernel: Intel GenuineIntel
мар 05 20:40:05 oleg-HP kernel: AMD AuthenticAMD
мар 05 20:40:05 oleg-HP kernel: Hygon HygonGenuine
мар 05 20:40:05 oleg-HP kernel: Centaur CentaurHauls
мар 05 20:40:05 oleg-HP kernel: zhaoxin Shanghai
мар 05 20:40:05 oleg-HP kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
мар 05 20:40:05 oleg-HP kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
мар 05 20:40:05 oleg-HP kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
мар 05 20:40:05 oleg-HP kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
мар 05 20:40:05 oleg-HP kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compa>
мар 05 20:40:05 oleg-HP kernel: signal: max sigframe size: 1776
мар 05 20:40:05 oleg-HP kernel: BIOS-provided physical RAM map:
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000009ecffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x0000000009ed0000-0x0000000009ffffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x000000000a200000-0x000000000a20afff] ACPI NVS
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x000000000a20b000-0x00000000da8aafff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000da8ab000-0x00000000da9a7fff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000da9a8000-0x00000000daa2efff] ACPI data
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000daa2f000-0x00000000dabd9fff] ACPI NVS
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000dabda000-0x00000000dda41fff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000dda42000-0x00000000deffffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x0000000100000000-0x000000019effffff] usable
мар 05 20:40:05 oleg-HP kernel: BIOS-e820: [mem 0x000000019f000000-0x000000021effffff] reserved
lines 1-32
sudo powertop --auto-tune
sudo: powertop: команда не найдена
Но пока никакого результата не вижу. Быть может, я делаю что-то не так.
Пожалуйста, помогите настроить электропитание так, чтобы разряд аккумуляторной батареи, на полностью отключённом ноутбуке, снизился до 0% за сутки.
Последний раз редактировалось пользователем 1 1o4ka; всего редактировалось раз: 6
...bis dat qui cito dat
06 мар 2023, 09:59
1o4ka писал(а):
06 мар 2023, 09:52
journalctl -b -1
Тут не весь вывод. Это лог - он большой. Сделай так
journalctl -b -1 > log.txt
Получившийся файл положи в архив и прикрепи к сообщению(чуть ниже кнопки "Отправить" есть кнопка "Прикрепить файлы")
1o4ka
06 мар 2023, 10:10
log.tar.gz
(43.24 КБ) 21 скачивание
06 мар 2023, 11:45
1o4ka писал(а):
06 мар 2023, 09:52
Доустановите соответствующий пакет - apt install powertop, или через GUI установщик.
1o4ka
06 мар 2023, 12:04
06 мар 2023, 11:45
Установил. Вот - скрин. Что можете сказать по теме?
Так не проходит. Представляю все разделы:
обзор:
Разряд батареи составляет 7.99 Вт
The energy consumed was 164 J
Предполагаемое оставшееся время работы 3 часов, 59 минут
Сводка: 483,6 пробуждений/с., 0,0 ГП оп./с., 0,0 VFS ops/sec and 50,2% CPU use
Использование Событий/с Категория Описание
405,9 ms/s 10,3 kWork commit_work
5,8 ms/s 147,3 Timer tick_sched_timer
7,6 ms/s 63,4 Interrupt [55] amdgpu
6,0 ms/s 28,1 Process [PID 1877] /usr/lib/firefox/firefox
5,4 ms/s 22,6 Process [PID 893] /usr/lib/xorg/Xorg -core :0 -seat seat0 -auth /va
7,6 ms/s 23,1 Process [PID 1420] /usr/bin/kwin_x11
1,8 ms/s 24,8 Process [PID 1885] /usr/lib/firefox/firefox
1,7 ms/s 18,8 Process [PID 1951] /usr/lib/firefox/firefox
6,3 ms/s 12,8 Process [PID 1942] /usr/lib/firefox/firefox
1,2 ms/s 15,6 Process [PID 1426] /usr/bin/kwin_x11
6,7 ms/s 12,8 Process [PID 2082] /usr/lib/firefox/firefox-bin -contentproc -child
179,2 µs/s 15,2 Process [PID 14] [rcu_sched]
215,5 µs/s 14,4 kWork kfree_rcu_monitor
6,3 ms/s 11,3 Interrupt [6] AMDI0010:01
332,9 µs/s 11,6 kWork kfree_rcu_work
0,7 ms/s 8,7 Process [PID 238] [gfx]
2,2 ms/s 7,6 Process [PID 1955] /usr/lib/firefox/firefox
399,8 µs/s 7,5 Timer hrtimer_wakeup
1,6 ms/s 6,7 Process [PID 1929] /usr/lib/firefox/firefox
9,6 ms/s 1,2 Process [PID 1991] /usr/lib/firefox/firefox
5,9 ms/s 2,3 Interrupt [7] sched(softirq)
1,9 ms/s 3,5 Interrupt [3] net_rx(softirq)
182,0 µs/s 3,6 Process [PID 557] [irq/63-rtw88_pc]
7,6 ms/s 0,10 kWork rtw_watch_dog_work
138,0 µs/s 2,2 kWork psi_avgs_work
240,8 µs/s 1,8 kWork ieee80211_iface_work
статистика
Pkg(OS) | Core(OS) | CPU(OS) 0 CPU(OS) 1
POLL 0,0% | POLL 0,0% | POLL 0,0% 0,1 ms 0,0% 0,1 ms
C1 30,2% | C1 35,9% | C1 36,1% 0,3 ms 35,6% 0,3 ms
C2 53,4% | C2 48,2% | C2 48,3% 1,5 ms 48,1% 1,3 ms
| Core(OS) | CPU(OS) 2 CPU(OS) 3
| POLL 0,0% | POLL 0,0% 0,1 ms 0,0% 0,2 ms
| C1 24,6% | C1 24,2% 0,3 ms 25,0% 0,3 ms
| C2 58,6% | C2 59,2% 1,4 ms 58,1% 1,4 ms
частотная статистика:
Пакет| Ядро| ЦПУ 0 ЦПУ 1
2,60 GHz 34,4% | 2,60 GHz 33,9% | 2,60 GHz 2,7% 32,5%
1,71 GHz 0,9% | 1,71 GHz 0,9% | 1,71 GHz 0,0% 0,9%
1400 MHz 51,2% | 1400 MHz 50,2% | 1400 MHz 0,3% 50,0%
Бездействие 13,5% | Бездействие 15,1% | Бездействие 97,0% 16,7%
| Ядро| ЦПУ 2 ЦПУ 3
| 2,60 GHz 33,3% | 2,60 GHz 1,9% 32,7%
| 1,71 GHz 0,8% | 1,71 GHz 0,0% 0,8%
| 1400 MHz 48,9% | 1400 MHz 1,7% 47,8%
| Бездействие 16,9% | Бездействие 96,4% 18,6%
статистика устройства:
Разряд батареи составляет 8.66 Вт
The energy consumed was 146 J
Используемое устройство
42,1% CPU misc
42,1% CPU core
80,0% Display backlight
0,0% Аудиокодек hwC1D0: Realtek
100,0% Радиоустройство: btusb
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridg
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Ser
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
100,0% Устройство PCI : SK hynix Gold P31 SSD
100,0% Радиоустройство: rtw_8821ce
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven2 USB 3.1
100,0% Устройство PCI : Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Networ
100,0% USB устройство: xHCI Host Controller
100,0% USB устройство: Usb Mouse (SIGMACHIP)
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
100,0% Устройство PCI : Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller
Tunables:
Bad VM writeback timeout
Bad NMI watchdog should be turned off
Bad Runtime PM for I2C Адаптер i2c-5 (AMDGPU DM i2c hw bus 1)
Bad Runtime PM for I2C Адаптер i2c-2 (SMBus PIIX4 adapter port 2 at 0b00)
Bad Runtime PM for I2C Адаптер i2c-4 (AMDGPU DM i2c hw bus 0)
Bad Runtime PM for I2C Адаптер i2c-1 (SMBus PIIX4 adapter port 0 at 0b00)
Bad Runtime PM for I2C Адаптер i2c-3 (SMBus PIIX4 adapter port 1 at 0b20)
Bad Автоприостановление устройств USB Usb Mouse [SIGMACHIP]
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0]
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven2 USB 3.1
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
Bad Runtime PM for PCI Device Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Networ
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dum
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
Bad Runtime PM for PCI Device SK hynix Gold P31 SSD
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Ser
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller
Bad Runtime PM for PCI Device Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
Good Включить управление питанием звукового кодека
Good Состояние инетрфейса Bluetooth устройства
Good Автоприостановление устройств USB Bluetooth Radio [Realtek ]
Good Автоприостановление устройств USB USB2.0 Hub [1-5]
WakeUp:
Disabled Статус wake-on-lan для устройства wlo1
Disabled Wake status for USB device usb1
Disabled Wake status for USB device 1-5
Disabled Wake status for USB device 1-3
Disabled Wake status for USB device usb2
Disabled Wake status for USB device 1-4
06 мар 2023, 13:07
1o4ka писал(а):
06 мар 2023, 12:04
Большинство разделов представляют интерес в динамике, т.к. они больше для настройки машины во время работы, и там, первый взгляд особого криминала нету.
Больше интересует результат после использования с ключом --auto-tune, т.к. Tunables выглядит несколько специфически, но я не ручаюсь, что для ноутбука на базе Rizen оно требует вмешательства. А автоматика должна привести в норму то что нужно. Ну и результат после - будет ли дальше разряжаться.
1o4ka
06 мар 2023, 15:04
06 мар 2023, 13:07
Не понял. Что надо с этим делать?
yarichin
06 мар 2023, 15:14
1o4ka
06 мар 2023, 16:35
Выполнил настройки оптимизации powertop. Вручную. потому как, USB - порты мне необходимы при работе (работаю на ноутбуке только с мышью; с сенсорной панелью - не получается). Выполнил калибровку.
Цитата:
Чтобы Powertop работал при каждом запуске системы и настраивал все параметры в положение “Good”, необходимо создать конфигурационный файл.
Данный файл создавать не стал. Потому как, опять-таки, при запуске ноутбука будет "отваливаться" мышь. Да и флешки не будут читаться.
Вопрос: Powertop надо запускать при каждом запуске ОСи, или - есть варианты?
Далее. Установил TLP. Там присутствует графическая оболочка, поддерживается русский язык. Но. Боюсь в него лезть, тем более, что-то настраивать, потому как могу, по неопытности, много чего натворить. Подскажите, как пользоваться TLP (инструкция на русском языке)? По сети нашёл только как его устанавливать. Быть может, я зря эту прогу установил? Потому как она служит для увеличения времени работы от аккумуляторной батареи. Я же, на практике, стараюсь работать только с внешним блоком питания (иногда ноутбук по нескольку суток не выключаю).
На данном этапе выключил ноутбук. Тестирую. Пусть постоит хотя бы 12-ть часов. Посмотрю результат на предмет расхода заряда батареи.
06 мар 2023, 17:27
1o4ka писал(а):
06 мар 2023, 15:04
Запустить команду sudo powertop --auto-tune
Которая должна разобрать сама - что можно переводить в режим управления питанием а что нет.
Причем вы немного неправильно поняли про Tunables - там не выключается питание, а лишь дается разрешение это делать. Если устройство питание требует (например в USB порт флешка воткнута) - оно будет подаваться. То же самое и по поводу внешней мыши с клавиатурой.
Однако там другая тонкость - если клавиатура или мышь нужна для вывода ноутбука из спящего режима (нажатие кнопок на клавиатуре или шевеление мышью) - тогда питание на их порт нужно подавать всегда, иначе в спящем состоянии они будут обесточены и подать сигнал по которому машина включится не смогут.
Изредка может наблюдаться еще какой-нить глюк с каким то устройством в режиме управления - тогда тоже нужно отключать, чтобы питание подавалось безусловно.
Калибровка - это действительно больше про продление времени работы от батареи, не совсем ваш случай. Вам нужно лишь чтобы программа разобралась и включила управление для всего, что можно. Тогда, с достаточно большой вероятностью, ядро при выключении нормально обесточит и то, что сейчас жрет батарею.
TLP - не могу ничего посоветовать удаленно, надо живьем смотреть, тем более что с Ryzen платформой у меня почти нет живого опыта. Как то больше интелы вокруг были.
Если с powertop результата не будет - следующим логическим шагом я бы предложил установку самого свежего ядра, из доступных. Через штатную утилиту обновления системы - там есть отдельный пункт с ядрами.
Раньше еще можно было через ukuu без проблем поставить ядро еще более свежее, из mainline ветки, но автор утилиты ушел в коммерцию, так что теперь это уже только ручками, с некоторым курением руководств. (Или за 15$, кажись.)
06 мар 2023, 17:33
06 мар 2023, 17:27
Там нашелся энтузиаст, который сделал форк и его поддерживает https://github.com/bkw777/mainline
1o4ka
06 мар 2023, 19:43
06 мар 2023, 17:27
Запустил:
[sudo] пароль для oleg:
modprobe cpufreq_stats failedЗагружены 193 предварительные замеры
Невозможно загрузить из файла /var/cache/powertop/saved_parameters.powertop
Файл будет загружен после выполнения минимального количества измерений (только с батареей)
RAPL device for cpu 0
RAPL Using PowerCap Sysfs : Domain Mask 5
Devfreq not enabled
glob returned GLOB_ABORTED
To show power estimates do 83 measurement(s) connected to battery only
Завершение PowerTOP
Мышь сразу "отвалилась". Переткнул шнурок - мышь заработала. Окно powertop (Tunables) выглядит так:
То есть, везде "Good", кроме USB - портов. Но, при выключении ноутбука напряжение на них не подаётся. Проверял.
Остаётся вопрос: Powertop надо запускать при каждом запуске ОСи, или - есть варианты?
Никак не получается протестить ноут подольше. Но, за 4-е часа батарея разрядилась на 3%. Умножаем на 6, получается ~18% за сутки. Много.
С TLP пойду к товарищу.
1o4ka
06 мар 2023, 19:44
06 мар 2023, 17:27
Подробней, плз.
06 мар 2023, 19:58
1o4ka писал(а):
06 мар 2023, 19:44
Подробней
Менеджер обновлений, Вид, Ядра линукс
Выбрать самую свежую ветку, в ней выбрать самое свежее ядро. Установить, перезагрузиться. Пробовать выключение.
Решено: 31
06 мар 2023, 20:12
1o4ka писал(а):
06 мар 2023, 16:35
Так она же, вроде бы, управляет интенсивностью расхода АКБ при работе ОС от аккумулятора. Не представляю, какой эффект tlp будет давать в выключенном состоянии системы, если данная служба даже запущена не будет. Или я ошибаюсь?
Что же касается собственно настройки, то там ничего сложного нету и каждый параметр поясняется комментарием (значок в начале строки #). Комментарии можно вполне пропустить через переводчик. Ну и как пример, посмотрите здесь.
1o4ka
06 мар 2023, 20:22
06 мар 2023, 19:58
Странно. Менеджер обновлений перестал запускаться. В системном лотке, их (менеджеров) стояло два: Центр программ Discover и Менеджер обновлений. При наличии обновлений -- "маяковали" оба. Но я всегда пользовался именно Менеджером обновлений. Diskover, при закрытии, постоянно выдаёт ошибку о внезапном прекращении работы.
А вот сейчас Менеджер обновлений перестал запускаться. Что можно предпринять?
mintupdate
root@oleg-HP:/home/oleg# /usr/lib/linuxmint/mintUpdate/mintUpdate.py:1333: DeprecationWarning: Gdk.threads_init is deprecated
Gdk.threads_init()
module 'cinnamon' has no attribute 'UpdateManager'
<class 'AttributeError'>
От обычного пользователя выдаёт тоже самое.
Попытка обмануть судьбу:
sudo apt install mintupdate
Построение дерева зависимостей… Готово
Уже установлен пакет mintupdate самой новой версии (5.9.7).
Всё установлено, а включаешь - не работает.
Последний раз редактировалось пользователем 5 1o4ka; всего редактировалось раз: 6
1o4ka
06 мар 2023, 20:24
madesta писал(а):
06 мар 2023, 20:12
Или я ошибаюсь?
Я сам не знаю, как к этому относиться. Вначале просто посмотрю. Может, даже трогать не стану.
yarichin
06 мар 2023, 21:06
1o4ka писал(а):
06 мар 2023, 20:22
Он считает что работает в среде Циннамон а не КДЕ.
https://forums.linuxmint.com/viewtopic.php?p=2047761
06 мар 2023, 21:49
1o4ka, TLP в вашем случае вряд-ли что-то испортит, но и помочь не сможет. Это служба которая должна быть запущена, чтобы был эффект. Т.е. для продления времени от батареи работающего ноутбука. Принцип работы - следит за тем, какое питание подается, и в зависимости от этого меняет некоторые настройки устройств - частоты процессора, APM дисков и т.д.
Есть предложение, что можно еще предпринять для проверки-теста:
Скачайте и запишите себе live версию manjaro вот отсюда: https://manjaro.org/download/ (верхние три официальных варианта - на выбор).
Загрузитесь в нее, а потом выключите машину через меню системы. И посмотрите - будет ли разряжаться батарея. Т.к. Manjaro это rolling дистрибутив, там весьма свежие версии ядра даже на live образе. Если батарея все равно будет садится - то нет смысла заниматься заменой ядра в минте. А вот если не будет - тогда можно дальше пробовать.
1o4ka
06 мар 2023, 21:57
slant, попробую. Потом отпишусь.
Вернуться в «KDE»
Сейчас этот форум просматривают: Google [Bot] и 0 гостей
