адаптеру не присваивается MAC-адрес
tovarishch
29 июл 2022, 03:04
Всем привет!
Имею ноутбук на следующем железе под LM 20.3 x64 xfce:
Kernel: 5.4.0-122-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Laptop System: ASUSTeK product: K53BR v: 1.0 serial: <filter>
Mobo: ASUSTeK model: K53BR v: 1.0 serial: <filter>
BIOS: American Megatrends v: 207 date: 04/25/2012
ID-1: BAT1 charge: 51.5 Wh condition: 51.5/57.7 Wh (89%)
model: ASUSTEK PA3533U status: Full
Topology: Dual Core model: AMD E-450 APU with Radeon HD Graphics bits: 64
type: MCP arch: Bobcat L2 cache: 512 KiB
flags: lm nx pae sse sse2 sse3 sse4a ssse3 svm bogomips: 6586
Speed: 1390 MHz min/max: 825/1650 MHz Core speeds (MHz): 1: 1530 2: 1578
Device-1: AMD Wrestler [Radeon HD 6320] vendor: ASUSTeK driver: radeon
v: kernel bus ID: 00:01.0
Device-2: AMD Seymour [Radeon HD 6400M/7400M Series] vendor: ASUSTeK
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD PALM (DRM 2.50.0 / 5.4.0-122-generic LLVM 12.0.0)
v: 3.3 Mesa 21.2.6 direct render: Yes
Device-1: AMD Wrestler HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:01.1
Device-2: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Sound Server: ALSA v: k5.4.0-122-generic
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 03:00.0
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel port: d000 bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Device-3: TP-Link 802.11ac WLAN Adapter type: USB driver: rtl88XXau
bus ID: 1-2:6
IF: 붂>Z state: down mac: <filter>
Local Storage: total: 223.57 GiB used: 9.54 GiB (4.3%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
ID-1: / size: 218.51 GiB used: 9.54 GiB (4.4%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 6280.0 C mobo: N/A
GPU: device: radeon temp: 54 C device: radeon temp: 68 C
Processes: 191 Uptime: 41m Memory: 7.38 GiB used: 1.58 GiB (21.5%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
В ноутбуке есть родной модуль WI-FI, но он не поддерживает 5 Ггц. поэтому был приобретен адаптер TP-Link Archer T2U Nano (AC600).
проблема заключается в следующем: после установки драйвера rtl8812au система начинает видеть 5Ггц сети, но не может к ним подключиться (постоянно просит пароль). Немного покопавшись я обнаружил, что адаптеру не присваивается MAC-адрес, мб поэтому не подключается к сети. 붂>Z - это и есть адаптер, при извлечении из юсб он пропадает
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp3s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether 10:bf:48:d9:df:76 brd ff:ff:ff:ff:ff:ff
3: wlp4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
link/ether 74:e5:43:02:f0:41 brd ff:ff:ff:ff:ff:ff
4: 붂>Z: <NO-CARRIER,BROADCAST,MULTICAST,UP,LOWER_UP> mtu 2312 qdisc mq state DORMANT mode DORMANT group default qlen 1000
link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
мною были накатаны дрова по схеме с данного сайта, - не помогло. после я извлек родной модуль, переустановил систему полностью и снова накатил дрова - не помогло.
Так же я пробовал установить пакетную прошивку
E: Невозможно найти пакет firmware-iwlwifi
Вообщем прошу помогите разобраться, сильно не ругайте - я второй день использую Линукс.
Благодарил (а): 54 раза
29 июл 2022, 08:28
tovarishch писал(а):
29 июл 2022, 03:04
29 июл 2022, 03:04
Вот это MAC адрес вашего адаптера. Дело явно не в этом.
Если просит пароль - скорее всего что-то с криптографией. Разрешенные протоколы аутентификации совпадают на точке и машине? Для проверки, если есть доступ к настройкам точки, можно попробовать отключить на ней шифрование полностью и попробовать подключится так. Если заработает - разбираться что там с протоколами дальше.
tovarishch
29 июл 2022, 11:11
link/ether 74:e5:43:02:f0:41 brd ff:ff:ff:ff:ff:ff - это мас родного модуля "3: wlp4s0:", адаптер распознается в системе иероглифами и его мас прописывается как: link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
29 июл 2022, 13:14
Хм, да, это меня спросонья проглючило. Таки да, mac пустой. И это странно, т.к. mac должен быть в самой прошивке нормальной железки, даже если есть возможность его программно менять (не всегда она есть). Если же железка не имеет своего собственного мака вообще, (может на драйвер полагается) - это мы значит имеем очередную реинкарнацию железяк класса "winmodem", "winprinter" и т.д. - особо тупое железо, вместо которого все что можно должна система программно делать, и грузящих тем самым процессор компа. Если оно так - лучше сдать назад сразу. Это вечный источник геморроя.
Дайте-ка сначала вывод lsusb, и lsusb -v (раздельно) сюда, при подключенном свистке разумеется. Посмотрим детально, что он за зверь такой...
Благодарил (а): 1737 раз
29 июл 2022, 13:20
и dmesg | tail -n 20 в придачу сразу после подключения свистка... может дровина не находит фирмварю для модема и не прогружает при подключении...
tovarishch
29 июл 2022, 17:04
29 июл 2022, 13:14
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 1ea7:0064 SHARKOON Technologies GmbH 2.4G Mouse
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 0bda:0138 Realtek Semiconductor Corp. RTS5138 Card Reader Controller
Bus 001 Device 003: ID 04f2:b23b Chicony Electronics Co., Ltd Chicony CNFA078
Bus 001 Device 005: ID 2357:011e TP-Link 802.11ac WLAN Adapter
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
idProduct 0x0001 1.1 root hub
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0002 1x 2 bytes
bInterval 255
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 255
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x1ea7 SHARKOON Technologies GmbH
idProduct 0x0064
bcdDevice 2.00
iManufacturer 0
iProduct 1
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 0x0022
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 2 Mouse
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 105
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 1
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 255
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0bda Realtek Semiconductor Corp.
idProduct 0x0138 RTS5138 Card Reader Controller
bcdDevice 38.82
iManufacturer 1
iProduct 2
iSerial 3
bLength 9
bDescriptorType 2
wTotalLength 0x0020
bNumInterfaces 1
iConfiguration 4
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x04f2 Chicony Electronics Co., Ltd
idProduct 0xb23b
bcdDevice 26.62
iManufacturer 3
iProduct 1
iSerial 2
bLength 9
bDescriptorType 2
wTotalLength 0x0211
bNumInterfaces 2
iConfiguration 4
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 14 Video
bFunctionSubClass 3 Video Interface Collection
bFunctionProtocol 0
iFunction 5
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 14 Video
bInterfaceSubClass 1 Video Control
iInterface 5
VideoControl Interface Descriptor:
bLength 13
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdUVC 1.00
wTotalLength 0x006b
dwClockFrequency 15.000000MHz
bInCollection 1
baInterfaceNr( 0) 1
bLength 18
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201 Camera Sensor
bAssocTerminal 0
iTerminal 0
wObjectiveFocalLengthMin 0
wObjectiveFocalLengthMax 0
wOcularFocalLength 0
bControlSize 3
bmControls 0x00000002
Auto-Exposure Mode
bLength 11
bDescriptorType 36
bDescriptorSubtype 5 (PROCESSING_UNIT)
Warning: Descriptor too short
bUnitID 2
bSourceID 1
wMaxMultiplier 0
bControlSize 2
bmControls 0x0000177f
Brightness
Contrast
Hue
Saturation
Sharpness
Gamma
White Balance Temperature
Backlight Compensation
Gain
Power Line Frequency
White Balance Temperature, Auto
iProcessing 0
bmVideoStandards 0x09
None
SECAM - 625/50
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 2
iTerminal 0
bLength 27
bDescriptorType 36
bDescriptorSubtype 6 (EXTENSION_UNIT)
bUnitID 4
guidExtensionCode {1229a78c-47b4-4094-b0ce-db07386fb938}
bNumControl 2
bNrPins 1
baSourceID( 0) 1
bControlSize 2
bmControls( 0) 0x00
bmControls( 1) 0x06
iExtension 0
bLength 29
bDescriptorType 36
bUnitID 7
guidExtensionCode {0fb885c3-68c2-4547-90f7-8f47579d95fc}
bNumControl 0
bNrPins 1
baSourceID( 0) 3
bControlSize 4
bmControls( 0) 0x0f
bmControls( 1) 0x00
bmControls( 2) 0x00
bmControls( 3) 0x00
iExtension 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 6
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Video Streaming
iInterface 0
VideoStreaming Interface Descriptor:
bLength 14
bDescriptorType 36
bDescriptorSubtype 1 (INPUT_HEADER)
bNumFormats 1
wTotalLength 0x0107
bEndPointAddress 129
bmInfo 0
bTerminalLink 3
bStillCaptureMethod 2
bTriggerSupport 1
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 0
bLength 27
bDescriptorType 36
bDescriptorSubtype 4 (FORMAT_UNCOMPRESSED)
bFormatIndex 1
bNumFrameDescriptors 5
guidFormat {32595559-0000-0010-8000-00aa00389b71}
bBitsPerPixel 16
bDefaultFrameIndex 1
bAspectRatioX 0
bAspectRatioY 0
bmInterlaceFlags 0x00
Interlaced stream or variable: No
Fields per frame: 2 fields
Field 1 first: No
Field pattern: Field 1 only
bCopyProtect 0
bLength 38
bDescriptorType 36
bDescriptorSubtype 5 (FRAME_UNCOMPRESSED)
bFrameIndex 1
bmCapabilities 0x00
Still image unsupported
wWidth 640
wHeight 480
dwMinBitRate 98304000
dwMaxBitRate 147456000
dwMaxVideoFrameBufferSize 614400
dwDefaultFrameInterval 333333
bFrameIntervalType 3
dwFrameInterval( 0) 333333
dwFrameInterval( 1) 400000
dwFrameInterval( 2) 500000
bLength 38
bDescriptorType 36
bFrameIndex 2
bmCapabilities 0x00
wWidth 160
wHeight 120
dwMinBitRate 6144000
dwMaxBitRate 9216000
dwMaxVideoFrameBufferSize 38400
bLength 38
bDescriptorType 36
bFrameIndex 3
bmCapabilities 0x00
wWidth 176
wHeight 144
dwMinBitRate 8110080
dwMaxBitRate 12165120
dwMaxVideoFrameBufferSize 50688
bLength 38
bDescriptorType 36
bFrameIndex 4
bmCapabilities 0x00
wWidth 320
wHeight 240
dwMinBitRate 24576000
dwMaxBitRate 36864000
dwMaxVideoFrameBufferSize 153600
bLength 38
bDescriptorType 36
bFrameIndex 5
bmCapabilities 0x00
wWidth 352
wHeight 288
dwMinBitRate 32440320
dwMaxBitRate 48660480
dwMaxVideoFrameBufferSize 202752
bLength 26
bDescriptorType 36
bDescriptorSubtype 3 (STILL_IMAGE_FRAME)
bEndpointAddress 0
bNumImageSizePatterns 5
wWidth( 0) 640
wHeight( 0) 480
wWidth( 1) 160
wHeight( 1) 120
wWidth( 2) 176
wHeight( 2) 144
wWidth( 3) 320
wHeight( 3) 240
wWidth( 4) 352
wHeight( 4) 288
bNumCompressionPatterns 0
bLength 6
bDescriptorType 36
bDescriptorSubtype 13 (COLORFORMAT)
bColorPrimaries 1 (BT.709,sRGB)
bTransferCharacteristics 1 (BT.709)
bMatrixCoefficients 4 (SMPTE 170M (BT.601))
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0080 1x 128 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0b00 2x 768 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0c00 2x 1024 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 6
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x1380 3x 896 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 7
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x1400 3x 1024 bytes
bInterval 1
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2357 TP-Link
idProduct 0x011e
bcdDevice 2.00
iManufacturer 1
iProduct 2
iSerial 3
bLength 9
bDescriptorType 2
wTotalLength 0x003c
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 500mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 6
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 3
bLength 7
bDescriptorType 5
bEndpointAddress 0x08 EP 8 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x09 EP 9 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9 Hub
bDeviceSubClass 0
bMaxPacketSize0 64
bcdDevice 5.04
iManufacturer 3
iProduct 2
iSerial 1
bLength 9
bDescriptorType 2
wTotalLength 0x0019
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 255
29 июл 2022, 13:20
[ 49.960298] wlp4s0: Limiting TX power to 27 (27 - 0) dBm as advertised by c0:94:ad:36:b0:b4
[ 50.114392] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[ 65.813713] usb 1-2: new high-speed USB device number 5 using ehci-pci
[ 65.974924] usb 1-2: New USB device found, idVendor=2357, idProduct=011e, bcdDevice= 2.00
[ 65.974932] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 65.974936] usb 1-2: Product: 802.11ac WLAN Adapter
[ 65.974939] usb 1-2: Manufacturer: Realtek
[ 65.974942] usb 1-2: SerialNumber: 00e04c000001
[ 66.163037] usb 1-2: 88XXau 14:eb:b6:82:3e:5a hw_info[107]
[ 67.295826] IPv6: ADDRCONF(NETDEV_CHANGE): 붂>Z: link becomes ready
[ 352.554471] wlp4s0: AP c0:94:ad:36:b0:b4 changed bandwidth, new config is 2412 MHz, width 1 (2412/0 MHz)
[ 445.560735] usb 1-2: USB disconnect, device number 5
[ 457.267520] usb 1-2: new high-speed USB device number 6 using ehci-pci
[ 457.429309] usb 1-2: New USB device found, idVendor=2357, idProduct=011e, bcdDevice= 2.00
[ 457.429321] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 457.429328] usb 1-2: Product: 802.11ac WLAN Adapter
[ 457.429333] usb 1-2: Manufacturer: Realtek
[ 457.429339] usb 1-2: SerialNumber: 00e04c000001
[ 457.619622] usb 1-2: 88XXau 14:eb:b6:82:3e:5a hw_info[107]
[ 458.687573] IPv6: ADDRCONF(NETDEV_CHANGE): 붂>Z: link becomes ready
29 июл 2022, 13:14
Сдать успею - еще 13 дней
еще добавил изображение окна подключения к WIFI
yarichin
29 июл 2022, 17:27
https://linux-hardware.org/?id=usb:2357 ... e=1#status
Меняй пока не поздно , свисток не для твоего 10 летнего ноута.
29 июл 2022, 17:34
tovarishch, Судя по этому топику: Подключение Archer T2U Nano - человек с точно таким же адаптером (начинка) ставил точно такой же драйвер. У него заработало. Так что либо ваш экземпляр устройства немного того, либо проблема не в MAC и не в драйвере, а все же где-то выше - в протоколах криптографии...
Еще раз рекомендую попробовать тест без шифрования (т.е. "незащищенное соединение", без пароля на WiFi).
tovarishch
29 июл 2022, 19:02
29 июл 2022, 17:34
попробовал с телефона раздать - телефон отображает подключение и даже фиксирует какой то мас адрес, но вот компьютер подключиться к сети не смог
есть какая-то команда, чтобы прочитать отчет об ошибках?
29 июл 2022, 21:10
journalctl -b и пролистать до конца. В таком виде команда показывает системный лог от загрузки до текущего момента.
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
30 июл 2022, 03:41
А вот как раз о таком адаптере и речь: Обновление LinuxMint-20.3-Una до LinuxMint-21-Vanessa (Пост antropomorf #126217)
То есть, можно попробовать обновить ядро и через менеджер драйверов удалить доп. драйвер. Ну или поставить Минт 21, раз уж он вышел.
30 июл 2022, 18:54
Ара Магеддон писал(а):
30 июл 2022, 03:41
Не вышел, бета только))))
UPD: Каюсь, не видел что Клем уже в стейбл разрешил
dkpost3
Благодарил (а): 9 раз
30 июл 2022, 19:10
