Подключение Archer T2U Nano
Taciturn
19 июн 2019, 17:14
Всем привет!
Имею адаптер TP-Link Archer T2U Nano (AC600) на следующем железе под LM 19.1 x64 Cinnamon:
System: Host: sergey-P55M-UD2 Kernel: 4.15.0-52-generic x86_64 bits: 64 compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa base: Ubuntu 18.04 bionic
Machine: Type: Desktop Mobo: Gigabyte model: P55M-UD2 serial: N/A
BIOS: Award v: F7 date: 01/28/2010
CPU: Topology: Dual Core model: Intel Core i3 540 bits: 64 type: MT MCP arch: Nehalem rev: 2 L2 cache: 4096 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24513 Speed: 1554 MHz min/max: 1197/3059 MHz Core speeds (MHz): 1: 1970 2: 1620 3: 1825 4: 2031
Graphics: Device-1: AMD RV790 [Radeon HD 4890] vendor: XFX Pine driver: radeon v: kernel bus ID: 01:00.0 Display: server: X.Org 1.19.6 driver: ati,radeon unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz OpenGL: renderer: AMD RV770 (DRM 2.50.0 / 4.15.0-52-generic LLVM 7.0.0) v: 3.3 Mesa 18.2.8 direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Device-2: AMD RV770 HDMI Audio [Radeon HD 4850/4870] vendor: XFX Pine driver: snd_hda_intel v: kernel bus ID: 01:00.1 Sound Server: ALSA v: k4.15.0-52-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: 2.3LK-NAPI port: ce00 bus ID: 04:00.0 IF: enp4s0 state: down mac: <filter> IF-ID-1: enp0s26u1u4 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 698.64 GiB used: 17.14 GiB (2.5%) ID-1: /dev/sde vendor: Seagate model: ST9750420AS size: 698.64 GiB temp: 42 C Partition: ID-1: / size: 57.89 GiB used: 17.14 GiB (29.6%) fs: ext4 dev: /dev/sde5 Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: radeon temp: 75 C Fan Speeds (RPM): N/A Info: Processes: 209 Uptime: 1h 16m Memory: 11.72 GiB used: 1.87 GiB (16.0%) Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.19 inxi: 3.0.27
Чип Realtek RTL8811AU - взято отсюда (https://wikidevi.com/wiki/TP-LINK_Archer_T2U_Nano).
Путем неоднократно расписанных методик - скомпилирован и установлен драйвер.
usb 2-1.4: New USB device found, idVendor=2357, idProduct=011e
usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1.4: Product: 802.11ac WLAN Adapter
usb 2-1.4: Manufacturer: Realtek
usb 2-1.4: SerialNumber: 00e04c000001
даже появился wicd, которого изначально не было, но сети не определяются как и само usb устройство...
Bus 002 Device 005: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 002 Device 004: ID 2357:011e
Bus 002 Device 003: ID 0bda:0111 Realtek Semiconductor Corp. RTS5111 Card Reader Controller
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 004: ID 12d1:108a Huawei Technologies Co., Ltd.
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
подскажите в чем еще может быть проблема?
19 июн 2019, 17:21
Taciturn писал(а):
19 июн 2019, 17:14
как раз определяется
Taciturn писал(а):
19 июн 2019, 17:14
это оно судя по
Taciturn писал(а):
19 июн 2019, 17:14
Taciturn
19 июн 2019, 17:28
Может не правильно выразился - определилось, но не включилось, а по итогу сети нету :sad:
19 июн 2019, 17:31
откуда собирал?
19 июн 2019, 17:33
Покажи вывод
lspci -knn | grep -A2 "Net"
Taciturn писал(а):
19 июн 2019, 17:14
Хотелось бы узнать что было сделано и в каком порядке.
Taciturn
19 июн 2019, 17:35
Адаптер сидит на порту "enp0s26u1u4 (usb 2-1.4) state: unknown speed: N/A duplex: N/A mac: <filter>"
19 июн 2019, 17:31
откуда собирал?
https://github.com/kimocoder/rtl8812au и https://github.com/diederikdehaas/rtl88 ... ver-4.3.14
Перед этим были еще попытки, но при сборке давали ошибки...
19 июн 2019, 17:33
Покажи вывод lspci -knn | grep -A2 "Net"
пусто...
19 июн 2019, 17:33
git clone, далее через make или dkms (если позволяла сборка).
Есть такие же проблемы с Медиатековскими чипами, там один из вариантов решения добавить bin файлы в /lib/firmware/, но для Риалтэка пока не могу найти и в папке /lib/firmware/rtlwifi - 8811au, 8812au файлов нету.
19 июн 2019, 17:50
 ! Сообщение из: darkfenix
Taciturn, не части это не чат. Если после твоего сообщения никто не написал, добавляй мысли путем редактирования своего сообщения.
На первый раз устное предупреждение.
И изучить и использовать Панель форматирования текста в темах/ответах
19 июн 2019, 17:50
sudo ifup enp0s26u1u4
что говорит?
Taciturn
19 июн 2019, 18:02
19 июн 2019, 17:50
Замечание принято.
Просто Линукс для меня совсем новая система, вопросы и идеи всплывают постепенно... Мне показалось, что эти сведения тоже могут быть полезны для прояснения ситуации.
19 июн 2019, 17:50
что говорит?
Комп рабочий (стоит на работе) - поэтому попробую завтра, но если будут ещё идеи - накидывайте, с утра проверим.
Taciturn
20 июн 2019, 09:06
19 июн 2019, 17:50
что говорит?
Unknown interface enp0s26u1u4
И еще...
sergey@sergey-P55M-UD2:~$ iwconfig
enp0s26u1u4 no wireless extensions.
lo no wireless extensions.
enp4s0 no wireless extensions.
[ 0.076030] ACPI: bus type USB registered
[ 0.076046] usbcore: registered new interface driver usbfs
[ 0.076052] usbcore: registered new interface driver hub
[ 0.076067] usbcore: registered new device driver usb
[ 0.939437] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.939442] ehci-pci: EHCI PCI platform driver
[ 0.939725] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 0.939736] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.939751] ehci-pci 0000:00:1a.0: debug port 2
[ 0.943663] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 0.943681] ehci-pci 0000:00:1a.0: irq 18, io mem 0xfbfff000
[ 0.956110] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.956186] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.956189] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.956192] usb usb1: Product: EHCI Host Controller
[ 0.956194] usb usb1: Manufacturer: Linux 4.15.0-52-generic ehci_hcd
[ 0.956197] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.956495] hub 1-0:1.0: USB hub found
[ 0.956509] hub 1-0:1.0: 2 ports detected
[ 0.956874] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.956885] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.956897] ehci-pci 0000:00:1d.0: debug port 2
[ 0.960811] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.960826] ehci-pci 0000:00:1d.0: irq 23, io mem 0xfbffe000
[ 0.976101] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.976171] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.976175] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.976177] usb usb2: Product: EHCI Host Controller
[ 0.976179] usb usb2: Manufacturer: Linux 4.15.0-52-generic ehci_hcd
[ 0.976182] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.976477] hub 2-0:1.0: USB hub found
[ 0.976493] hub 2-0:1.0: 2 ports detected
[ 0.976650] ehci-platform: EHCI generic platform driver
[ 0.976662] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.976667] ohci-pci: OHCI PCI platform driver
[ 0.976680] ohci-platform: OHCI generic platform driver
[ 0.976691] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.292067] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.312096] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.964144] usb 2-1.4: new high-speed USB device number 4 using ehci-pci
[ 2.073282] usb 2-1.4: New USB device found, idVendor=2357, idProduct=011e
[ 2.073286] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.073289] usb 2-1.4: Product: 802.11ac WLAN Adapter
[ 2.073291] usb 2-1.4: Manufacturer: Realtek
[ 2.073293] usb 2-1.4: SerialNumber: 00e04c000001
[ 29.896749] usbcore: registered new interface driver cdc_ether
[ 29.906301] rndis_host 1-1.4:1.0 usb0: register 'rndis_host' at usb-0000:00:1a.0-1.4, RNDIS device, 2a:86:46:b9:5a:c9
[ 29.906329] usbcore: registered new interface driver rndis_host
[ 29.913314] rndis_host 1-1.4:1.0 enp0s26u1u4: renamed from usb0
[ 36.708102] NET: Registered protocol family 4
[ 36.712039] NET: Registered protocol family 5
[ 37.168512] IPv6: ADDRCONF(NETDEV_UP): enp0s26u1u4: link is not ready
[ 37.171238] IPv6: ADDRCONF(NETDEV_UP): enp4s0: link is not ready
Taciturn
21 июн 2019, 09:29
Проблема решена.
По порядку:
  1. Переустановлена система с подключенным интернетом через usb-модем телефона
  • Установлен драйвер rtl8812au-dkms из диспетчера программ!!!
    Адаптер не переподключал, но несколько раз перезагружался - сети нет...
  • Пробовал запустить драйвер вручную
    modprobe 8812au из каталога var/lib/...
    результат нулевой
  • Путем копирования и переименования файлов в /lib/firmware/rtlwifi добавил
    rtl8821aefw.bin -> rtl8812aufw.bin
    rtl8821aefw_29.bin -> rtl8812aufw_29.bin
    Адаптер не переподключал, перезагрузка - сети нет...
Дополнение - lsusb все равно не дает описания адаптеру...
ergey@sergey-P55M-UD2:~$ lsusb
Bus 002 Device 002: ID 0bda:0111 Realtek Semiconductor Corp. RTS5111 Card Reader Controller
Bus 009 Device 002: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 2357:011e
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
