Проблема с WI-FI соединением. Qualcomm Atheros QCA9377
Drake
Благодарил (а): 3 раза
13 фев 2021, 18:15
Здравствуйте!
Модель ноутбука: Acer Extensa 215-51
Версия ОС: Linux Mint 20.1 Cinnamon x64
Wi-Fi роутер: Zyxel Keetenic Giga
Вывод inxi -Fxz:
  Kernel: 5.4.0-65-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
  base: Ubuntu 20.04 focal
  Type: Laptop System: Acer product: Extensa 215-51 v: V1.06
  serial: <filter>
  Mobo: WL model: Taurus_WC v: V1.06 serial: <filter> UEFI: Insyde v: 1.06
  date: 09/23/2019
  ID-1: BAT1 charge: 16.9 Wh condition: 28.3/37.0 Wh (77%)
  model: PANASONIC PABAS0241231 status: Discharging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/235/317
  charge: 100% (should be ignored) status: Discharging
  Topology: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
  arch: Kaby Lake rev: C L2 cache: 6144 KiB
  bogomips: 28800
  Speed: 700 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 700 2: 700
  3: 700 4: 700 5: 700 6: 700 7: 700 8: 700
  Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI
  Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
  resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.2.6
  Device-1: Intel Cannon Point-LP High Definition Audio
  bus ID: 00:1f.3
  Sound Server: ALSA v: k5.4.0-65-generic
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
  vendor: Lite-On driver: ath10k_pci v: kernel port: 4040 bus ID: 01:00.0
  vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
  bus ID: 02:00.0
  Local Storage: total: 238.47 GiB used: 16.39 GiB (6.9%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM256GDJTNG-8310A
  ID-1: / size: 233.24 GiB used: 16.38 GiB (7.0%) fs: ext4
  dev: /dev/nvme0n1p2
  System Temperatures: cpu: 49.0 C mobo: N/A
  Processes: 248 Uptime: 33m Memory: 7.63 GiB used: 1.53 GiB (20.0%)
  inxi: 3.0.38
Суть проблемы:
Планшет, телефон, а также ноутбук с Windows работает с роутером отлично, проблем нет.
Но решил установить на ноутбук Mint. Соединение ноутбука с роутером проходит успешно. Соединение в процессе стабильное, не обрывается. Около минуты (может меньше) интернет есть, медленный. Далее интернета нет.
Вывод команды ping 8.8.8.8:
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
ping: sendmsg: Недостаточно буферного пространства
64 bytes from 8.8.8.8: icmp_seq=1 ttl=109 time=40725 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=109 time=39712 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=109 time=38688 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=109 time=37660 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=109 time=36667 ms
64 bytes from 8.8.8.8: icmp_seq=6 ttl=109 time=35643 ms
64 bytes from 8.8.8.8: icmp_seq=7 ttl=109 time=34619 ms
64 bytes from 8.8.8.8: icmp_seq=8 ttl=109 time=33595 ms
64 bytes from 8.8.8.8: icmp_seq=9 ttl=109 time=32567 ms
64 bytes from 8.8.8.8: icmp_seq=10 ttl=109 time=31550 ms
64 bytes from 8.8.8.8: icmp_seq=11 ttl=109 time=30526 ms
64 bytes from 8.8.8.8: icmp_seq=12 ttl=109 time=29502 ms
64 bytes from 8.8.8.8: icmp_seq=23 ttl=109 time=1496 ms
64 bytes from 8.8.8.8: icmp_seq=24 ttl=109 time=1713 ms
64 bytes from 8.8.8.8: icmp_seq=25 ttl=109 time=711 ms
64 bytes from 8.8.8.8: icmp_seq=26 ttl=109 time=80.3 ms
64 bytes from 8.8.8.8: icmp_seq=27 ttl=109 time=79.3 ms
64 bytes from 8.8.8.8: icmp_seq=28 ttl=109 time=81.2 ms
64 bytes from 8.8.8.8: icmp_seq=29 ttl=109 time=82.2 ms
64 bytes from 8.8.8.8: icmp_seq=30 ttl=109 time=84.7 ms
64 bytes from 8.8.8.8: icmp_seq=31 ttl=109 time=79.7 ms
64 bytes from 8.8.8.8: icmp_seq=32 ttl=109 time=82.7 ms
64 bytes from 8.8.8.8: icmp_seq=33 ttl=109 time=93.4 ms
64 bytes from 8.8.8.8: icmp_seq=34 ttl=109 time=82.2 ms
64 bytes from 8.8.8.8: icmp_seq=35 ttl=109 time=82.5 ms
64 bytes from 8.8.8.8: icmp_seq=36 ttl=109 time=89.9 ms
64 bytes from 8.8.8.8: icmp_seq=37 ttl=109 time=82.8 ms
64 bytes from 8.8.8.8: icmp_seq=38 ttl=109 time=83.3 ms
64 bytes from 8.8.8.8: icmp_seq=39 ttl=109 time=86.1 ms
64 bytes from 8.8.8.8: icmp_seq=40 ttl=109 time=80.9 ms
64 bytes from 8.8.8.8: icmp_seq=41 ttl=109 time=85.3 ms
64 bytes from 8.8.8.8: icmp_seq=42 ttl=109 time=81.3 ms
64 bytes from 8.8.8.8: icmp_seq=43 ttl=109 time=80.4 ms
64 bytes from 8.8.8.8: icmp_seq=44 ttl=109 time=81.7 ms
64 bytes from 8.8.8.8: icmp_seq=45 ttl=109 time=81.8 ms
64 bytes from 8.8.8.8: icmp_seq=46 ttl=109 time=81.8 ms
64 bytes from 8.8.8.8: icmp_seq=47 ttl=109 time=82.9 ms
64 bytes from 8.8.8.8: icmp_seq=48 ttl=109 time=97.8 ms
64 bytes from 8.8.8.8: icmp_seq=49 ttl=109 time=78.5 ms
64 bytes from 8.8.8.8: icmp_seq=50 ttl=109 time=7079 ms
64 bytes from 8.8.8.8: icmp_seq=51 ttl=109 time=6068 ms
64 bytes from 8.8.8.8: icmp_seq=52 ttl=109 time=5053 ms
64 bytes from 8.8.8.8: icmp_seq=53 ttl=109 time=4033 ms
64 bytes from 8.8.8.8: icmp_seq=54 ttl=109 time=3010 ms
64 bytes from 8.8.8.8: icmp_seq=55 ttl=109 time=1992 ms
64 bytes from 8.8.8.8: icmp_seq=56 ttl=109 time=964 ms
64 bytes from 8.8.8.8: icmp_seq=57 ttl=109 time=79.9 ms
64 bytes from 8.8.8.8: icmp_seq=58 ttl=109 time=77.4 ms
Пробовал переключать антенну, воспользовавшись советом из Переключение антенн
Также пробовал решение про skip_otp из Соединение с wifi прерывается
Ничего из вышеперечисленного не помогло. Проблема сохраняется и на Ubuntu 20.04.1 LTS (Focal Fossa). Замечу, что при подключении ноутбука к телефону, интернет работает отлично.
Может кто сможет помочь.
Последний раз редактировалось пользователем 1 Drake; всего редактировалось раз: 13
ilikethat
Решено: 10
Благодарил (а): 129 раз
13 фев 2021, 18:37
А просто выгрузить
sudo modprobe -r ath10k_pci
загрузить драйвер
sudo modprobe ath10k_pci
помогает?
Drake
13 фев 2021, 19:04
ilikethat писал(а):
13 фев 2021, 18:37
А просто выгрузить
загрузить драйвер
помогает?
Нет, всё также.
ilikethat
Решено: 10
13 фев 2021, 19:09
Drake, еще могу посоветовать вариант, поменять частоту 5 -> 2.4 или наоборот.
13 фев 2021, 20:18
Drake писал(а):
13 фев 2021, 18:15
https://zalinux.ru/?p=4539
Drake
14 фев 2021, 05:20
Подключился к роутеру и уже минут 30 нормально пользуюсь интернетом. Проблема плавающая.
Drake
14 фев 2021, 07:09
ilikethat писал(а):
13 фев 2021, 19:09
Не помогло. Кстати при выборе 5 Ггц и переподключении к роутеру - каждый раз создается новый профиль в Сетевых соединениях.
Drake
14 фев 2021, 09:22
13 фев 2021, 20:18
Drake писал(а):
13 фев 2021, 18:15
Из статьи решил попробовать поменять режимы на роутере. Не помогло. Размеры буферов решил не трогать, так как сегодня ни разу сообщения "Недостаточно буферного пространства" не было. Только пинги по 5000 и выше периодически.
Последний раз редактировалось пользователем 1 Drake; всего редактировалось раз: 14
Drake
14 фев 2021, 09:26
Может стоит переустановить на другой драйвер? Если да, то кто-нибудь может подсказать как это сделать?
14 фев 2021, 16:15
Drake писал(а):
14 фев 2021, 09:22
М.б. периодически wifi ноутбука "засыпает"?
Отключение механизма энергосбережения чипсета беспроводной сетевой карты:
sudo xed /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
По умолчанию:
[connection]
wifi.powersave = 3
Измените значение с 3 на 0 и сохраните файл. Перезагрузитесь.
Здесь ещё пишут про firmware. Хотя речь и идёт про Kali Linux, но м.б. наведёт на какие-нибудь идеи.
Drake
14 фев 2021, 16:30
madesta писал(а):
14 фев 2021, 16:15
Да, уже. В настоящее время проверяю. Только значение у меня на 2.
Drake
15 фев 2021, 15:15
В принципе, после отключения режима энергосбережения на модуле беспроводной сети, соединение стало стабильнее, но не идеальное. Время отклика уменьшилось (ping), На speedtest.net загрузка 9-11 МБит/сек стабильно, при том, что на смартфоне и на планшете загрузка примерно 40-50 МБит/сек. Видимо проблема с драйвером всё таки есть, либо с настройками драйвера.
Всем участникам спасибо.
