Не коннектит вай фай при выходе из сна
danilka143
Благодарил (а): 2 раза
09 мар 2020, 19:17
Нет Wi-Fi на ноуте HP тут завели вай фай
теперь при выходе из сна долгое подключение к сети и в итоге
LM 19.3 Cinnamon
Host: dan-HP-Laptop-15-bs1xx Kernel: 5.3.0-40-generic x86_64 bits: 64
compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.5
Type: Laptop System: HP product: HP Laptop 15-bs1xx
v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 8444 v: 67.33 serial: <filter> UEFI: Insyde v: F.61
date: 08/29/2019
ID-1: BAT1 charge: 20.3 Wh condition: 41.4/41.6 Wh (99%)
model: COMPAL PABAS0241231 status: Discharging
Topology: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP
arch: Broadwell rev: 4 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15963
Speed: 1193 MHz min/max: 500/1900 MHz Core speeds (MHz): 1: 1156 2: 1095
3: 1124 4: 1136
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
v: 4.5 Mesa 19.2.8 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:03.0
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.3.0-40-generic
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 07:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek vendor: Hewlett-Packard driver: rtl8723de
v: v5.1.1.8_21285.20171026 port: 3000 bus ID: 0d:00.0
Local Storage: total: 238.47 GiB used: 8.02 GiB (3.4%)
ID-1: /dev/sda vendor: Micron model: MTFDDAV256TDL-1AW1ZABHA
ID-1: / size: 71.59 GiB used: 6.86 GiB (9.6%) fs: ext4 dev: /dev/sda4
ID-2: /home size: 11.95 GiB used: 1.10 GiB (9.2%) fs: ext4 dev: /dev/sda8
ID-3: swap-1 size: 1.95 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 207 Uptime: 4m Memory: 3.76 GiB used: 1.19 GiB (31.6%)
inxi: 3.0.32
так же
https://linux-hardware.org/?probe=2a1efc3ac0
это решаемо или он так и будет работать через сами-понимаете-что?
Последний раз редактировалось пользователем 1 Dja; всего редактировалось раз: 12
Причина: урл
09 мар 2020, 19:22
Благодарил (а): 1737 раз
09 мар 2020, 19:41
Ну сброс соединения после выхода из сна это нормально, сам не переподключается обратно что ли?
09 мар 2020, 20:43
А если попробовать вместо 3 поставить 0?
etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
[connection]
wifi.powersave = 3
danilka143
12 мар 2020, 16:32
WWolf, неа, циклическая попытка переподключения, довольно долго, в итоге оБшибка
danilka143
12 мар 2020, 16:34
madesta, по идиотским советам из гугла удалил NM, логично, что теперь директории нет
теперь использую wicd, проблемы оно не решило
12 мар 2020, 16:57
danilka143 писал(а):
12 мар 2020, 16:34
что тоже логично.
12 мар 2020, 18:18
12 мар 2020, 16:34
удалил NM
Ну если очень нужен NM обратно, то он восстанавливается без проблем. Правда когда делал себе, то потом долго ручками выпиливал следы widcd.
