Нет Wi-Fi на ноуте HP
danilka143
Благодарил (а): 2 раза
09 мар 2020, 17:22
Вчера накатил LM 19.3 Cinnamon. Работает только LAN-кабель, ви-фи тупо не заводится. HP Laptop 15-bs1xx. Что с ним не так?
Host: dan-HP-Laptop-15-bs1xx Kernel: 5.3.0-40-generic x86_64 bits: 64
compiler: gcc v: 7.4.0 Desktop: Cinnamon 4.4.5
Type: Laptop System: HP product: HP Laptop 15-bs1xx
v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 8444 v: 67.33 serial: <filter> UEFI: Insyde v: F.61
date: 08/29/2019
ID-1: BAT1 charge: 25.9 Wh condition: 41.4/41.6 Wh (99%)
model: COMPAL PABAS0241231 status: Discharging
Topology: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP
arch: Broadwell rev: 4 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 15963
Speed: 1199 MHz min/max: 500/1900 MHz Core speeds (MHz): 1: 1411 2: 1453
3: 1368 4: 1493
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
v: 4.5 Mesa 19.2.8 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:03.0
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.3.0-40-generic
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 07:00.0
Device-2: Realtek vendor: Hewlett-Packard driver: N/A port: 3000
bus ID: 0d:00.0
Local Storage: total: 238.47 GiB used: 7.89 GiB (3.3%)
ID-1: /dev/sda vendor: Micron model: MTFDDAV256TDL-1AW1ZABHA
size: 238.47 GiB temp: 27 C
ID-1: / size: 71.59 GiB used: 6.80 GiB (9.5%) fs: ext4 dev: /dev/sda4
ID-2: /home size: 11.95 GiB used: 1.03 GiB (8.6%) fs: ext4 dev: /dev/sda8
ID-3: swap-1 size: 1.95 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 196 Uptime: 27m Memory: 3.76 GiB used: 1.14 GiB (30.3%)
inxi: 3.0.32
Вот что показывают сетевые соединения
Решение WWolf » 09 мар 2020, 17:55
danilka143, тебе это пробовать надо https://github.com/smlinux/rtl8723de, оно для пятых ядер адаптировано, а ты для 4.15 пытаешься запустить
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 9
Причина: картинка
Благодарил (а): 1737 раз
09 мар 2020, 17:26
danilka143 писал(а):
09 мар 2020, 17:22
Что с ним не так?
09 мар 2020, 17:22
bus ID: 0d:00.0
банально драйвера нет... ищи что там за вайфай внутрях и ищи драйвер на него... как вариант попробовать ядро 4.15 - если там драйвер есть, значит просто выбросили его из 5.3 по каким-то причинам...
danilka143
09 мар 2020, 17:39
WWolf, https://linux-hardware.org/?probe=b2ad5523d1
там есть ссылка на гитхаб с драйвером, в read.me инструкция
sudo apt-get install git dkms libelf-dev
git clone https://github.com/vvmspace/rtl8723de.git
sudo dkms add ./rtl8723de
sudo dkms install rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414
sudo reboot
выдает ошибку 4 команда
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
'make' all KVER=5.3.0-40-generic................(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.3.0-40-generic (x86_64)
Consult /var/lib/dkms/rtl8723de/5.1.1.8_21285.20171026_COEX20170111-1414/build/make.log for more information.
09 мар 2020, 17:55
danilka143
09 мар 2020, 18:19
WWolf, завелось, спасибо Вам огромное)
09 мар 2020, 18:22
danilka143, та мне то за что? спасибо hw-probe что держат ссылки для дровин :) просто будь внимательней, в том что ты ставил написано же
"Fixed compatibility with Linux Kernel 4.15 version and older", а ядра 5+ новее
