Русификация Mint 19.1
Damian
Благодарил (а): 24 раза
12 авг 2019, 07:16
Не могу полностью русифицировать систему.Нажимаю Установить языковые пакеты для русского языка получаю вот что: The package system is broken
Check if you are using third party repositories. If so disable them, since they are a common source of problems.
Furthermore run the following command in a Terminal: apt-get install -f
Details:
The following packages have unmet dependencies:
libgstreamer-gl1.0-0: Depends: libc6 (>= 2.14) but 2.27-3ubuntu1 is installed
Depends: libdrm2 (>= 2.4.17) but 2.4.97-1ubuntu1~18.04.1 is installed
Depends: libgbm1 (>= 8.1~0) but 19.0.2-1ubuntu1.1~18.04.2 is installed
Depends: libglib2.0-0 (>= 2.40) but 2.56.4-0ubuntu0.18.04.4 is installed
Depends: libgudev-1.0-0 (>= 165) but 1:232-2 is installed
Depends: libwayland-egl1 (>= 1.15.0) but 1.16.0-1ubuntu1.1~18.04.1 is installed
libwebkit2gtk-4.0-37: Depends: libjavascriptcoregtk-4.0-18 (= 2.24.2-0ubuntu0.18.04.1) but 2.22.4-0ubuntu0.18.04.1 is installed
Depends: libc6 (>= 2.27) but 2.27-3ubuntu1 is installed
Depends: libgcc1 (>= 1:7) but 1:8.3.0-6ubuntu1~18.04.1 is installed
Depends: libglib2.0-0 (>= 2.43.1) but 2.56.4-0ubuntu0.18.04.4 is installed
Depends: libgtk-3-0 (>= 3.21.4) but 3.22.30-1ubuntu4 is installed
Depends: libicu60 (>= 60.1-1~) but 60.2-3ubuntu3 is installed
Depends: libjpeg8 (>= 8c) but 8c-2ubuntu8 is installed
Depends: libsoup2.4-1 (>= 2.61.90) but 2.62.1-1ubuntu0.1 is installed
Depends: libsqlite3-0 (>= 3.7.15) but 3.22.0-1ubuntu0.1 is installed
Depends: libstdc++6 (>= 6) but 8.3.0-6ubuntu1~18.04.1 is installed
Depends: libtasn1-6 (>= 4.12) but 4.13-2 is installed
Depends: libxcomposite1 (>= 1:0.3-1) but 1:0.4.4-2 is installed
Depends: libxdamage1 (>= 1:1.1) but 1:1.1.4-3 is installed
Depends: zlib1g (>= 1:1.2.0) but 1:1.2.11.dfsg-0ubuntu2 is installed
Как решить?
12 авг 2019, 07:25
Для начала выполнить рекомендацию системы.
Damian
12 авг 2019, 08:12
etamax писал(а):
12 авг 2019, 07:25
Ввожу sudo apt-get install -f ничего не выходит.
12 авг 2019, 08:25
Damian писал(а):
12 авг 2019, 08:12
ничего не выходит.
Ничего не вижу , покажи вывод команды.
Damian
12 авг 2019, 08:32
Исправление зависимостей… Готово
libgstreamer1.0-0 libjavascriptcoregtk-4.0-18
Следующие пакеты будут обновлены:
Обновлено 2 пакетов, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 280 пакетов не обновлено.
Установлено или удалено не до конца 127 пакетов.
Необходимо скачать 0 B/5 630 kB архивов.
После данной операции объём занятого дискового пространства возрастёт на 1 466 kB.
Хотите продолжить? [Д/н] Д
dpkg: проблемы зависимостей не позволяют выполнить обработку триггеров gconf2:
gconf2 зависит от default-dbus-session-bus | dbus-session-bus, однако:
Пакет default-dbus-session-bus не установлен.
Пакет dbus-user-session, предоставляющий default-dbus-session-bus, пока не настроен.
Пакет dbus-session-bus не установлен.
Пакет dbus-user-session, предоставляющий dbus-session-bus, пока не настроен.
Пакет dbus-x11, предоставляющий dbus-session-bus, пока не настроен.
dpkg: ошибка при обработке пакета gconf2 (--configure):
проблемы зависимостей — оставляем триггеры не обработанными
проблемы зависимостей — остОтчёт apport не записан, так как достигнуто значение MaxReports
dpkg: проблемы зависимостей не позволяютОтчёт apport не записан, так как достигнуто значение MaxReports
gconf2 зависит от default-dbus-session-bus | dbus-sessionОтчёт apport не записан, так как достигнуто значение MaxReports
-bus, однако:
Пакет dbus-user-session, предост�Отчёт apport не записан, так как достигнуто значение MaxReports
�вляющий default-dbus-session-bus, пока не настроен.
Пакет dbus-user-session, предостаОтчёт apport не записан, так как достигнуто значение MaxReports
dpkg: слишком много ошибок — останавливаемся
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
gconf2
Обработка остановлена из-за слишком большого количества ошибок.
damian@damian-pc:~$
12 авг 2019, 08:46
Damian писал(а):
12 авг 2019, 08:32
поставь эти 2 пакета для начала
Damian
12 авг 2019, 09:21
etamax писал(а):
12 авг 2019, 08:46
синтаксисом плохо владею,не знаю как.
12 авг 2019, 09:27
sudo apt install default-dbus-session-bus dbus-session-bus
Damian
12 авг 2019, 09:40
E: Невозможно найти пакет default-dbus-sessions-bus
E: Невозможно найти пакет dbus-sessions-bus
12 авг 2019, 09:55
Ну и нахрена в системе dconf2, когда его зависимостей нету в репах? Уничтож его к чертям собачим
Damian
12 авг 2019, 11:16
vir0id писал(а):
12 авг 2019, 09:55
Damian писал(а):
12 авг 2019, 09:21
12 авг 2019, 11:20
Damian
12 авг 2019, 14:20
После Удалить дубликаты записейпросят перезагрузить кэш,а в Удалении сторонних пакетов кроме сего прочего есть gconf2,gconf2-common,gconf-service,gconf-service-backend что именно удалять из этого
12 авг 2019, 14:28
Damian писал(а):
12 авг 2019, 14:20
Можно все , это настроечный редактор , он не особо нужен , и по дефолту кажется не устанавливался . Потом можешь поставить , если будет нужен.
Damian
12 авг 2019, 14:48
Вроде как поддержка русского языка полностью установлена,но вот пытаюсь Ctrl+Shift назначить для переключения клавиатуры и в настройках Параметры Раскладки почему-то всё на английском.Не могу нужные значения выставить.
12 авг 2019, 14:57
Damian, Английский не учил? Laiout - properties - типа того. Ещё кнопка есть - применить для всей системы , по английски не помню))
12 авг 2019, 14:59
Damian
12 авг 2019, 15:13
etamax писал(а):
12 авг 2019, 14:57
учил Switch another layoutназывается.Спасибо тебе.
12 авг 2019, 15:15
Переключение на следующую раскладку))) Русифицировалось?
Благодарил (а): 1236 раз
12 авг 2019, 15:43
Damian, а может стоит обновиться до 19.2 ?
http://dataenginer.ru/?p=3469
И всё что нужно притянется автоматически
