Пропадает сетевое окружение
paskelas
Благодарил (а): 2 раза
10 окт 2018, 13:51
Доброго времени суток. С недавних пор имеется LM 19 x64
v@H110M-S2H:~$ inxi -Fxz
System:    Host: H110M-S2H Kernel: 4.15.0-20-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1)
           Distro: Linux Mint 19 Tara
Machine:   Device: desktop System: Gigabyte product: H110M-S2H serial: N/A
           Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: N/A
           UEFI: American Megatrends v: F22 date: 06/12/2017
CPU:       Dual core Intel Celeron G3900 (-MCP-)
           arch: Skylake-S rev.3 cache: 2048 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 11232
           clock speeds: max: 2800 MHz 1: 800 MHz 2: 800 MHz
Graphics:  Card: Intel HD Graphics 510 bus-ID: 00:02.0
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 510 (Skylake GT1)
           version: 4.5 Mesa 18.0.0-rc5 Direct Render: Yes
Audio:     Card Intel Sunrise Point-H HD Audio
           driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 01:00.0
           IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 500.1GB (2.2% used)
           ID-1: /dev/sda model: TOSHIBA_HDWD105 size: 500.1GB
Partition: ID-1: / size: 28G used: 5.9G (23%) fs: ext4 dev: /dev/sda6
           ID-2: /home size: 65G used: 772M (2%) fs: ext4 dev: /dev/sda8
           ID-3: swap-1 size: 4.10GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda7
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 200 Uptime: 36 min Memory: 1695.6/3832.3MB
v@H110M-S2H:~$
ifconfig
ifconfig
enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.88.211  netmask 255.255.255.0  broadcast 192.168.88.255
        inet6 fe80::a515:cc51:8a9f:c15c  prefixlen 64  scopeid 0x20<link>
        ether e0:d5:5e:21:1a:eb  txqueuelen 1000  (Ethernet)
        RX packets 65138  bytes 74774642 (74.7 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 34300  bytes 5310215 (5.3 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Локальная петля (Loopback))
        RX packets 1552  bytes 118778 (118.7 KB)
        TX packets 1552  bytes 118778 (118.7 KB)
Комп находится в локальной сети, в которой все остальные машины на виндах. Есть сервер (файлопомойка), AD нет. Выход в сеть через роутер микротик, он же шлюз он же днс сервер (судя по сетевым настройкам всех машин). В локалке есть устройства как с динамическим адресом, так и со статическим. Инет есть, с этим проблем нет.
Проблема вот в чем. Комп с минтом часто не видит сетевое окружение. Причем доходит до такого: перезагрузка - в сетевом окружени 5 компов. Перезагрузка - 11, еще перезагрузка - 28, еще 15 и т.д. Сегодня в сетевом было пусто, после пары перезагрузок появилась часть.
Сеть пингуется по ip адресам, по названиям хостов нет. Расшаренная общая папка на сервере подключена, иногда нужно несколько раз нажать на нее, чтобы она открылась.
я не специалист, на хабре есть статья в которой пишут что возможны проблемы dns. Меня смущает в etc/resolv.conf надпись nameserver 127.0.0.53. С таким адресом в локалке ничего нет, но при этом он пингуется.
Что предпринять?
10 окт 2018, 14:16
paskelas писал(а):
10 окт 2018, 13:51
127.0.0.x - это т.н. loopback адреса. Принадлежат вашей собственной машине, т.е. пингуете по этому адресу вы сами себя. Запись в resolv.conf предполагает, что на вашей машине находится кеширующий dns сервер или служба.
10 окт 2018, 14:19
1. Попробуйте выдавать динамические адреса с именем локального домена. имя локальному домену придумайте своё. На примере рисунка локальный домен = vot
2. Установите авторегистрацию на dns MikroTik хостов, получивших динамические адреса. Статику хостов с именем домена впишите в DNS руками. Чтобы авторегистрация проходила вставьте в настроках dhcp скрипт.
Имя вашего локального домена будет в строке :set topdomain "ххх"; ххх - ваше имя локального домена
Время TTL должно совпадать с временем аренды адреса dhcp, например 23 часа 59 минут 59 секунд = :set ttl "23:59:59";
Текст скрипта:
:local topdomain;
:set topdomain "vot";
:local ttl;
:local hostname;
:local hostip;
:local free;
/ip dns static;
:foreach a in=[find] do={
  :if ([get $a ttl] = $ttl) do={
    :put ("Removing: " . [get $a name] . " : " . [get $a address]);
    remove $a;
/ip dhcp-server lease ;
:foreach i in=[find] do={
  :if ([:len [get $i host-name]] > 0) do={
    :set free "true";
    :set hostname ([get $i host-name] . "." . $topdomain);
    :set hostip [get $i address];
    /ip dns static ;
    :foreach di in [find] do={
      :if ([get $di name] = $hostname) do={
        :set free "false";
        :put ("Not adding already existing entry: " . $hostname);
    :if ($free = true) do={
      :put ("Adding: " . $hostname . " : " . $hostip ) ;
      /ip dns static add name=$hostname address=$hostip ttl=$ttl;
При получении адреса ip от dhcp имя компьютера в виде хост.домен MikroTik автоматически внесёт в свой DNS. После того как dhcp заберёт адрес обратно эта запись в dns микротика также удалится.
3. По крайней мере приучите свою сеть искать узлы по dns микротика, а не по непонятному широковещанию. Да и компьютеры, получившие ip от микротика, будут знать, что искать нужно на dns микротика. Может быть, станет немного получше.
paskelas
10 окт 2018, 14:29
Ага. Спасибо.
еще напишу, возможно это связано.
принтер есть, подключен как smb://WORKGROUP/hostname/Canon%20LBP6000LBP6018
Сups не печатает пробную страницу. Состояние принтера: Простаивает - Session setup failed: NT_STATUS_INVALID_PARAMETER
Случайно из текстового редактора нажал печать и документ распечатался....
10 окт 2018, 14:36
Так откуда же Linux знает на какой ему hostname ломиться?
Он же сначала ищет имена по etc/hosts, а потом спрашивает DNS где такой узел искать.
paskelas
10 окт 2018, 14:51
madesta писал(а):
10 окт 2018, 14:19
А если прописать всем хостам в локалке статику (так в общем изначально задумывалось), это не решит проблему? и после этого в etc/hosts прописать все адреса хостов?
Просто я далеко не системный администратор, и к it сфере не имею никакого отношения по роду занятий. И мне абсолютно никто не даст ковырять настройки роутера. А присвоить всем участникам сети статику я могу.
10 окт 2018, 14:55
Можно и так. Только прописывать везде: и на винде, и на пингвине. Только адрес dns не забудьте указать как адрес микротика.
Только какой-то странный у вас etc/resolv.conf
Мой:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.1.1
search vot
11 окт 2018, 13:45
10 окт 2018, 14:16
А для чего же?
paskelas
16 окт 2018, 13:48
Изучаю сейчас вопросы взаимодействия DNS и netbios имен.
Ибо nbtscan выдает такое
IP address NetBIOS Name Server User MAC address
192.168.88.24 SVETLANA <server> <unknown> 00:1d:92:29:0e:60
сетевое окружение насколько я понял существует именно благодаря нетбиос именам.
19 окт 2018, 00:49
Ну по идее поскольку нет домена, то шлюзом является роутер и сервером DNS надо указывать его же :) И если из-за него плодятся машины в сетевом окружении, то я бы подумал про поднятие домена и ДНС-сервером тогда уже являлся бы контроллер, который такие пляски не выдает.
Вернуться в «Работа с сетью»
