v@H110M-S2H:~$ inxi -Fxz
System: Host: H110M-S2H Kernel: 4.15.0-20-generic x86_64 bits: 64 gcc: 7.3.0 Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) Distro: Linux Mint 19 Tara Machine: Device: desktop System: Gigabyte product: H110M-S2H serial: N/A Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: N/A UEFI: American Megatrends v: F22 date: 06/12/2017 CPU: Dual core Intel Celeron G3900 (-MCP-) arch: Skylake-S rev.3 cache: 2048 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 11232 clock speeds: max: 2800 MHz 1: 800 MHz 2: 800 MHz Graphics: Card: Intel HD Graphics 510 bus-ID: 00:02.0 Display Server: x11 (X.Org 1.19.6 ) drivers: modesetting (unloaded: fbdev,vesa) Resolution: 1920x1080@60.00hz OpenGL: renderer: Mesa DRI Intel HD Graphics 510 (Skylake GT1) version: 4.5 Mesa 18.0.0-rc5 Direct Render: Yes Audio: Card Intel Sunrise Point-H HD Audio driver: snd_hda_intel bus-ID: 00:1f.3 Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic Network: Card: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 01:00.0 IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter> Drives: HDD Total Size: 500.1GB (2.2% used) ID-1: /dev/sda model: TOSHIBA_HDWD105 size: 500.1GB Partition: ID-1: / size: 28G used: 5.9G (23%) fs: ext4 dev: /dev/sda6 ID-2: /home size: 65G used: 772M (2%) fs: ext4 dev: /dev/sda8 ID-3: swap-1 size: 4.10GB used: 0.00GB (0%) fs: swap dev: /dev/sda7 RAID: No RAID devices: /proc/mdstat, md_mod kernel module present Sensors: System Temperatures: cpu: 29.8C mobo: 27.8C Fan Speeds (in rpm): cpu: N/A Info: Processes: 200 Uptime: 36 min Memory: 1695.6/3832.3MB Init: systemd runlevel: 5 Gcc sys: 7.3.0 Client: Shell (bash 4.4.191) inxi: 2.3.56 v@H110M-S2H:~$
ifconfig enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.88.211 netmask 255.255.255.0 broadcast 192.168.88.255 inet6 fe80::a515:cc51:8a9f:c15c prefixlen 64 scopeid 0x20<link> ether e0:d5:5e:21:1a:eb txqueuelen 1000 (Ethernet) RX packets 65138 bytes 74774642 (74.7 MB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 34300 bytes 5310215 (5.3 MB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Локальная петля (Loopback)) RX packets 1552 bytes 118778 (118.7 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 1552 bytes 118778 (118.7 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Проблема вот в чем. Комп с минтом часто не видит сетевое окружение. Причем доходит до такого: перезагрузка - в сетевом окружени 5 компов. Перезагрузка - 11, еще перезагрузка - 28, еще 15 и т.д. Сегодня в сетевом было пусто, после пары перезагрузок появилась часть.
Сеть пингуется по ip адресам, по названиям хостов нет. Расшаренная общая папка на сервере подключена, иногда нужно несколько раз нажать на нее, чтобы она открылась.
я не специалист, на хабре есть статья в которой пишут что возможны проблемы dns. Меня смущает в etc/resolv.conf надпись nameserver 127.0.0.53. С таким адресом в локалке ничего нет, но при этом он пингуется.
Что предпринять?
