Не запускается менеджер програм...Cinnamon 19
Новичок
01 окт 2018, 00:34
При нажатии на иконку менеджера программ происходит...Ничего не происходит. Кто-то на форуме советовал вбить mintinstall в терминал. Вбил сначала с приставкой sudo, потом понял что без неё надо. Ввёл без неё. Выдало вот это:
MintInstall: Detected system architecture: 'x86_64'
MintInstall: User pkgcache is most recent, using it.
Traceback (most recent call last):
  File "/usr/lib/linuxmint/mintinstall/installer/installer.py", line 360, in _get_backend_component
    backend_component = self.backend_table[pkginfo]
KeyError: <installer.pkgInfo.AptPkgInfo object at 0x7fc819c88ac8>
During handling of the above exception, another exception occurred:
  File "/usr/lib/linuxmint/mintinstall/mintinstall.py", line 470, in do_activate
    self.on_installer_ready()
  File "/usr/lib/linuxmint/mintinstall/mintinstall.py", line 704, in on_installer_ready
    self.load_featured_on_landing()
  File "/usr/lib/linuxmint/mintinstall/mintinstall.py", line 762, in load_featured_on_landing
    tile = FeatureTile(pkginfo, self.installer, background, text, text_shadow, stroke)
  File "/usr/lib/linuxmint/mintinstall/mintinstall.py", line 204, in __init__
    label_name.set_label(self.installer.get_display_name(pkginfo))
  File "/usr/lib/linuxmint/mintinstall/installer/installer.py", line 385, in get_display_name
    comp = self._get_backend_component(pkginfo)
  File "/usr/lib/linuxmint/mintinstall/installer/installer.py", line 365, in _get_backend_component
    backend_component = _apt.search_for_pkginfo_apt_pkg(pkginfo)
  File "/usr/lib/linuxmint/mintinstall/installer/_apt.py", line 127, in search_for_pkginfo_apt_pkg
    apt_cache = get_apt_cache()
  File "/usr/lib/linuxmint/mintinstall/installer/_apt.py", line 40, in get_apt_cache
    _apt_cache = apt.Cache()
  File "/usr/lib/python3/dist-packages/apt/cache.py", line 130, in __init__
    self.open(progress)
  File "/usr/lib/python3/dist-packages/apt/cache.py", line 185, in open
    self._cache = apt_pkg.Cache(progress)
apt_pkg.Error: E:Искажённая запись 3 в list из файла /etc/apt/sources.list.d/additional-repositories.list (Suite), E:Не читается перечень источников.
** (mintinstall.py:4889): WARNING **: 03:15:47.462: Found icon of unknown type, skipping it: unknown
Что это значит? Я без понятия, ибо сюда переходил с винды, и это было неделю назад. Что мне с этим делать?
Решение Dja » 01 окт 2018, 01:26
Если не поможет, то переустанавливайся. И прежде чем экспериментировать не забывай бэкапиться.
01 окт 2018, 00:38
Новичок писал(а):
01 окт 2018, 00:34
Мой запуск
dja-laptop ~ $ mintinstall
Detected system architecture: 'x86_64' (using 'x86_64')
load_cache took 777.999 ms
add_categories took 59.877 ms
build_matched_packages took 0.258 ms
add_packages took 2609.919 ms
process_matching_packages took 4.119 ms
First run detected, initial set of reviews used
add_reviews took 377.073 ms
Downloading new reviews
__init__ took 4295.839 ms
Overwriting reviews file in /home/dja/.cache/mintinstall/reviews.list
update_reviews took 1545.840 ms
add_flatpaks took 6624.346 ms
update_reviews took 1604.282 ms
тут я его закрыл
Killed
dja-laptop ~ $
Так что какие действия предшествовали этому у вас остается только догадываться.
Новичок
01 окт 2018, 00:44
Зачем это? (Сори я чайник)
Новичок
01 окт 2018, 00:46
Так что же делать?
01 окт 2018, 00:47
Вспоминать что делали "до"
Новичок
01 окт 2018, 00:52
До этого я... установил wine через консоль, дальше его пока не запускал и пошёл серфить инет, в поисках годного графического редактора. Когда же я его нашёл, я попытался открыть менеджер программ...А дальше - это...
Если ещё сильнее "до", то до этого я как раз искал граф. редактор в менеджере.
01 окт 2018, 00:56
т.е. до установки вайна (возможно прямо, а может и нет) менеджер программ работал :) А бэкапа разумеется как обычно нет...
Идем в логи апта /var/log/apt
Смотри что там менялось и меняем обратно. Если что-то ставилось - сносим, сносилось - ставим.
снести
sudo apt purge name
поставить
sudo apt install name
И прежде чем браться за всякие вина надо было изучить вопрос и найти годную инструкцию.
Новичок
01 окт 2018, 01:06
Не могу удалить или поставить; не читается перечень источников
01 окт 2018, 01:07
Попробуйте
Система - Источники приложений - Обслуживание.
01 окт 2018, 01:10
Кстати почему бэкапа нет? В 19 же таймшифт прям навязывается. Неужели надо было упереться и не сделать бэкап чтоб прийти к ситуации когда он нужен??? :blink2:
Новичок
01 окт 2018, 01:12
Открыл обслуживание, выполнил "исправление проблем списка пакетов", вылезло сообщение:
Не удалось загрузить список пакетов
Это серьёзная проблема. Попробуйте повторить позже. Если проблема возникнет вновь, пожалуйста, отправьте отчёт об ошибке разработчикам
Вкладка "Подробнее": E:Malformed entry 3 in list file /etc/apt/sources.list.d/additional-repositories.list (Suite), E:The list of sources could not be read.
UPD: сообщение вылезло при обновлении кэша после исправления
Последний раз редактировалось пользователем 2 Новичок; всего редактировалось раз: 1
Новичок
01 окт 2018, 01:13
Не было никакого таймшифта
01 окт 2018, 01:16
Новичок писал(а):
01 окт 2018, 01:12
Удали его. У меня вот такого вообще нет.
dja-laptop /etc/apt/sources.list.d $ ls -la
итого 48
drwxr-xr-x 2 root root 4096 сен 30 01:18 .
drwxr-xr-x 6 root root 4096 сен 30 01:18 ..
-rw-r--r-- 1 root root  136 сен  9 22:12 bumblebee-testing-xenial.list
-rw-r--r-- 1 root root  142 сен  9 22:12 graphics-drivers-ppa-xenial.list
-rw-r--r-- 1 root root  158 сен 27 23:38 nm-l2tp-network-manager-l2tp-xenial.list
-rw-r--r-- 1 root root  144 сен 14 15:26 obsproject-obs-studio-xenial.list
-rw-r--r-- 1 root root  653 сен 27 23:35 official-package-repositories.list
-rw-r--r-- 1 root root  187 сен 26 12:55 opera-stable.list
-rw-r--r-- 1 root root  128 сен 12 18:10 slytomcat-ppa-xenial.list
-rw-r--r-- 1 root root 1507 авг  4 02:49 teamviewer.list
-rw-r--r-- 1 root root  138 сен 15 09:50 vacuum-im-unstable-xenial.list
-rw-r--r-- 1 root root   55 сен 12 18:21 yandex-disk.list
Новичок писал(а):
01 окт 2018, 01:13
Ой не надо... Запускаешь апдейтер и там про таймшифт сразу пишут чтоб настроил и тд.
Либо у тебя вообще не минт.
Новичок
01 окт 2018, 01:20
Я ничего не могу удалить.
Вот это выходит.
Произошла непреодолимая ошибка
Судя по всему, в aptdaemon, программном обеспечении, позволяющем вам устанавливать/удалять программы и выполнять связанные с пакетами задачи, присутствует программная ошибка.
org.debian.apt: E: isn't a valid package name
01 окт 2018, 01:22
а ты как удаляешь?
Новичок
01 окт 2018, 01:24
Сначала через терминал, как ты говорил, но там не читается перечень источников, потом через меню-ПКМ по приложению-удалить, там вылетает то, что написано сверху. Через менеджер не могу удалить по понятным причинам.
01 окт 2018, 01:25
sudo rm /etc/apt/sources.list.d/additional-repositories.list
01 окт 2018, 01:26
Новичок
01 окт 2018, 01:28
Не помогло...
Буду переустанавливатся.
Запомню теперь ваш совет.
Новичок
01 окт 2018, 01:32
Если даже это не поможет...Мой пк безнадёжен
