MintInstall: Detected system architecture: 'x86_64' MintInstall: User pkgcache is most recent, using it. Traceback (most recent call last): File "/usr/lib/linuxmint/mintinstall/installer/installer.py", line 360, in _get_backend_component backend_component = self.backend_table[pkginfo] KeyError: <installer.pkgInfo.AptPkgInfo object at 0x7fc819c88ac8> During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/linuxmint/mintinstall/mintinstall.py", line 470, in do_activate self.on_installer_ready() File "/usr/lib/linuxmint/mintinstall/mintinstall.py", line 704, in on_installer_ready self.load_featured_on_landing() File "/usr/lib/linuxmint/mintinstall/mintinstall.py", line 762, in load_featured_on_landing tile = FeatureTile(pkginfo, self.installer, background, text, text_shadow, stroke) File "/usr/lib/linuxmint/mintinstall/mintinstall.py", line 204, in __init__ label_name.set_label(self.installer.get_display_name(pkginfo)) File "/usr/lib/linuxmint/mintinstall/installer/installer.py", line 385, in get_display_name comp = self._get_backend_component(pkginfo) File "/usr/lib/linuxmint/mintinstall/installer/installer.py", line 365, in _get_backend_component backend_component = _apt.search_for_pkginfo_apt_pkg(pkginfo) File "/usr/lib/linuxmint/mintinstall/installer/_apt.py", line 127, in search_for_pkginfo_apt_pkg apt_cache = get_apt_cache() File "/usr/lib/linuxmint/mintinstall/installer/_apt.py", line 40, in get_apt_cache _apt_cache = apt.Cache() File "/usr/lib/python3/dist-packages/apt/cache.py", line 130, in __init__ self.open(progress) File "/usr/lib/python3/dist-packages/apt/cache.py", line 185, in open self._cache = apt_pkg.Cache(progress) apt_pkg.Error: E:Искажённая запись 3 в list из файла /etc/apt/sources.list.d/additional-repositories.list (Suite), E:Не читается перечень источников. ** (mintinstall.py:4889): WARNING **: 03:15:47.462: Found icon of unknown type, skipping it: unknown
Не запускается менеджер програм...Cinnamon 19
При нажатии на иконку менеджера программ происходит...Ничего не происходит. Кто-то на форуме советовал вбить mintinstall в терминал. Вбил сначала с приставкой sudo, потом понял что без неё надо. Ввёл без неё. Выдало вот это:
Что это значит? Я без понятия, ибо сюда переходил с винды, и это было неделю назад. Что мне с этим делать?
Решение
Если не поможет, то переустанавливайся. И прежде чем экспериментировать не забывай бэкапиться.
Мой запуск
dja-laptop ~ $ mintinstall
Detected system architecture: 'x86_64' (using 'x86_64')
load_cache took 777.999 ms
add_categories took 59.877 ms
build_matched_packages took 0.258 ms
add_packages took 2609.919 ms
process_matching_packages took 4.119 ms
First run detected, initial set of reviews used
add_reviews took 377.073 ms
Downloading new reviews
__init__ took 4295.839 ms
Overwriting reviews file in /home/dja/.cache/mintinstall/reviews.list
update_reviews took 1545.840 ms
add_flatpaks took 6624.346 ms
update_reviews took 1604.282 ms
тут я его закрыл
Killed
dja-laptop ~ $
До этого я... установил wine через консоль, дальше его пока не запускал и пошёл серфить инет, в поисках годного графического редактора. Когда же я его нашёл, я попытался открыть менеджер программ...А дальше - это...
Если ещё сильнее "до", то до этого я как раз искал граф. редактор в менеджере.
т.е. до установки вайна (возможно прямо, а может и нет) менеджер программ работал
А бэкапа разумеется как обычно нет...
Идем в логи апта /var/log/apt
Смотри что там менялось и меняем обратно. Если что-то ставилось - сносим, сносилось - ставим.
снести
поставить
И прежде чем браться за всякие вина надо было изучить вопрос и найти годную инструкцию.
снести
sudo apt purge name
sudo apt install name
Не могу удалить или поставить; не читается перечень источников
Кстати почему бэкапа нет? В 19 же таймшифт прям навязывается. Неужели надо было упереться и не сделать бэкап чтоб прийти к ситуации когда он нужен???
Открыл обслуживание, выполнил "исправление проблем списка пакетов", вылезло сообщение:
Не удалось загрузить список пакетов
Это серьёзная проблема. Попробуйте повторить позже. Если проблема возникнет вновь, пожалуйста, отправьте отчёт об ошибке разработчикам
Вкладка "Подробнее": E:Malformed entry 3 in list file /etc/apt/sources.list.d/additional-repositories.list (Suite), E:The list of sources could not be read.
UPD: сообщение вылезло при обновлении кэша после исправления
Последний раз редактировалось пользователем 2 Новичок; всего редактировалось раз: 1
Удали его. У меня вот такого вообще нет.
dja-laptop /etc/apt/sources.list.d $ ls -la
итого 48
drwxr-xr-x 2 root root 4096 сен 30 01:18 .
drwxr-xr-x 6 root root 4096 сен 30 01:18 ..
-rw-r--r-- 1 root root 136 сен 9 22:12 bumblebee-testing-xenial.list
-rw-r--r-- 1 root root 142 сен 9 22:12 graphics-drivers-ppa-xenial.list
-rw-r--r-- 1 root root 158 сен 27 23:38 nm-l2tp-network-manager-l2tp-xenial.list
-rw-r--r-- 1 root root 144 сен 14 15:26 obsproject-obs-studio-xenial.list
-rw-r--r-- 1 root root 653 сен 27 23:35 official-package-repositories.list
-rw-r--r-- 1 root root 187 сен 26 12:55 opera-stable.list
-rw-r--r-- 1 root root 128 сен 12 18:10 slytomcat-ppa-xenial.list
-rw-r--r-- 1 root root 1507 авг 4 02:49 teamviewer.list
-rw-r--r-- 1 root root 138 сен 15 09:50 vacuum-im-unstable-xenial.list
-rw-r--r-- 1 root root 55 сен 12 18:21 yandex-disk.list
Ой не надо... Запускаешь апдейтер и там про таймшифт сразу пишут чтоб настроил и тд.
Либо у тебя вообще не минт.
Я ничего не могу удалить.
Вот это выходит.
Произошла непреодолимая ошибка
Судя по всему, в aptdaemon, программном обеспечении, позволяющем вам устанавливать/удалять программы и выполнять связанные с пакетами задачи, присутствует программная ошибка.
org.debian.apt: E: isn't a valid package name
Вот это выходит.
Сначала через терминал, как ты говорил, но там не читается перечень источников, потом через меню-ПКМ по приложению-удалить, там вылетает то, что написано сверху. Через менеджер не могу удалить по понятным причинам.
sudo rm /etc/apt/sources.list.d/additional-repositories.list
Не помогло...
Буду переустанавливатся.
Запомню теперь ваш совет.
