Отваливаются Х-ы
_DS_
Благодарил (а): 12 раз
Отваливаются Х-ы
16 мар 2018, 16:00
:hi2: Доброго времени суток. Уважаемые форумчане.
~ $ inxi -Fxz
System:    Host: dsnout Kernel: 3.16.0-5-amd64 x86_64 (64 bit gcc: 4.8.4)
           Desktop: Cinnamon 3.2.7 (Gtk 3.14.5+4) Distro: LinuxMint 2 betsy
Machine:   System: Sony product: VPCEB1M1R v: C6048RGS
           Mobo: Sony model: VAIO
           Bios: American Megatrends v: R0300Y8 date: 07/20/2010
CPU:       Dual core Intel Core i3 M 330 (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8512
           Clock Speeds: 1: 2133 MHz 2: 933 MHz 3: 933 MHz 4: 1333 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Madison [Mobility Radeon HD 5650/5750 / 6530M/6550M]
           bus-ID: 01:00.0
           Display Server: X.Org 1.16.4 driver: fglrx
           Resolution: 1366x768@59.94hz
           GLX Renderer: AMD Mobility Radeon HD 5000 Series
           GLX Version: 4.5.13399 - CPC 15.201.1151 Direct Rendering: Yes
Audio:     Card-1 Intel 5 Series/3400 Series High Definition Audio
           Card-2 Advanced Micro Devices [AMD/ATI] Redwood HDMI Audio [Radeon HD 5000 Series]
           Sound: Advanced Linux Sound Architecture v: k3.16.0-5-amd64
Network:   Card-1: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet Controller with AVB]
           driver: sky2 v: 1.30 port: a000 bus-ID: 04:00.0
           Card-2: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
           driver: ath9k bus-ID: 02:00.0
           IF: wlan0 state: up mac: <filter>
Drives:    HDD Total Size: 320.1GB (13.4% used)
           ID-1: /dev/sda model: WDC_WD3200BEVT size: 320.1GB temp: 35C
Partition: ID-1: / size: 21G used: 5.1G (27%) fs: ext4 dev: /dev/sda6
           ID-2: /boot size: 580M used: 76M (14%) fs: ext2 dev: /dev/sda2
           ID-3: /home size: 251G used: 34G (15%) fs: ext4 dev: /dev/sda5
           ID-4: swap-1 size: 1.07GB used: 0.00GB (0%) fs: swap dev: /dev/sda1
Sensors:   System Temperatures: cpu: 46.0C mobo: 46.0C gpu: 50.00C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 175 Uptime: 39 min Memory: 1007.3/3819.6MB
           Init: SysVinit runlevel: 2 Gcc sys: 4.9.2
           Client: Shell (bash 4.3.301) inxi: 2.1.28
Проблема заключается в следующем:
Если перейти в другой терминал, а затем попытаться вернуться в Х-ы (tty7) вываливается вот такая надпись
OK] Startinng MDM Display Manager: mdm.
 FAIL] Startpar: service(s) returned failure: plymoth ... failed
в остальных терминалах не работает переключатель раскладки, хотя в Х-ах всё нормально.
Перед этим устанавливал видеодрайвер по инструкции отсюда
Установка AMD Catalyst 15.9 (основной репозиторий)
Драйвера встали нормально
Подскажите в чём проблема.
PS (ну и пути её решения) :blush:
Последний раз редактировалось пользователем 2 _DS_; всего редактировалось раз: 16
Отваливаются Х-ы
16 мар 2018, 16:03
_DS_
Отваливаются Х-ы
16 мар 2018, 16:08
Отваливаются Х-ы
16 мар 2018, 16:11
_DS_,
Отваливаются Х-ы
16 мар 2018, 16:12
_DS_ писал(а):
16 мар 2018, 16:08
В подписи
На момент проблемы?
_DS_
Отваливаются Х-ы
16 мар 2018, 16:13
16 мар 2018, 16:12
На момент проблемы?
да
_DS_
Отваливаются Х-ы
16 мар 2018, 16:25
di_mok писал(а):
16 мар 2018, 16:11
_DS_,
Да-нет, вроде переходит.
broken
Благодарил (а): 21 раз
Отваливаются Х-ы
25 мар 2018, 18:40
7 не срабатывает - значит 8.
_DS_ писал(а):
16 мар 2018, 16:00
plymoth
а это вообще лучше выключить.
