NTFS
NTFS
мой пример fstab
# / was on /dev/sda2 during installation
UUID=f7bad9ae-8f69-48b4-a204-b1ed702cfb4e / ext4 errors=remount-ro 0 1
# /boot/efi was on /dev/sda1 during installation
UUID=E01D-4FB6 /boot/efi vfat umask=0077 0 1
# /home was on /dev/sda4 during installation
UUID=98751bbe-9cf8-4315-9f08-95531ce4f7ad /home ext4 defaults 0 2
#Entry for /dev/sda5 :
UUID=71FC84E61F0AF303 /media/hardD ntfs-3g uid=1000,gid=1000,dmask-022,fmask=133,locale=ru_RU.UTF-8 0 0
#Binds
/media/hardD/dja/Documents /home/dja/Документы none bind 0 0
/media/hardD/dja/Downloads /home/dja/Загрузки none bind 0 0
/media/hardD/dja/Music /home/dja/Музыка none bind 0 0
/media/hardD/dja/Pictures /home/dja/Изображения none bind 0 0
/media/hardD/dja/Video /home/dja/Видео none bind 0 0
/media/hardD/dja/local /home/dja/local none bind 0 0
/media/hardD/dja/Clouds/MailRu /home/dja/Clouds/MailRu none bind 0 0
/media/hardD/dja/Clouds/YaDisk /home/dja/Clouds/YaDisk none bind 0 0
/media/hardD/dja/Distrib /home/dja/samba/pub/Distr none bind 0 0
/media/hardD/dja/Documents/Work/Instructions /home/dja/samba/pub/Инструкции none bind 0 0
/media/hardD/dja/ISO/YUMI /home/dja/samba/pub/Distr/MustDie/yumi none bind 0 0
/media/hardD/dja/Clouds/YaDisk/temp /home/dja/temp none bind 0 0
/media/hardD/dja/Documents /media/hardD/dja/VirtualShare/mc.admin/Documents none bind 0 0
/media/hardD/dja/Downloads /media/hardD/dja/VirtualShare/mc.admin/Downloads none bind 0 0
/media/hardD/dja/Pictures /media/hardD/dja/VirtualShare/mc.admin/Pictures none bind 0 0
/media/hardD/dja/Desktop /media/hardD/dja/VirtualShare/mc.admin/Desktop none bind 0 0
#tmpfs
tmpfs /tmp tmpfs defaults 0 0
tmpfs /home/dja/.cache tmpfs defaults 0 0
#Binds
#tmpfs
Автор темы - Сообщения: 49
NTFS
а вот мой примерDja писал(а): ↑10 ноя 2017, 01:35мой пример fstab# /etc/fstab: static file system information.
#Binds
#tmpfs
/dev/sda2: UUID="2E286EFB286EC187" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="b9004997-cd9b-4243-9455-f4b1726ba489"
/dev/sdb1: LABEL="EFI" UUID="67E3-17ED" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="ab09fcfd-9e2b-47f0-a23f-a768156d0e75"
/dev/sdb2: UUID="916e0740-981d-3364-867e-08358c316fff" LABEL="OS X El Cap" TYPE="hfsplus" PARTLABEL="M-PM-^QM-PM-5M-PM-7 M-PM-=M-PM-0M-PM-7M-PM-2M-PM-0M-PM-=M-PM-8M-QM-^O" PARTUUID="42be0add-10dc-4063-a0ac-cc2eb7a1ed3d"
/dev/sdb3: UUID="c8689d0c-25f5-3f8a-b9f3-da6c4fa143d0" LABEL="Recovery HD" TYPE="hfsplus" PARTLABEL="Recovery HD" PARTUUID="c93a0cc6-4c79-42a6-9039-7a6b5ee7d3b2"
/dev/sdb4: UUID="CEB82AE3B82AC9B3" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="fe34009e-90fb-47d4-9971-86a08a27c407"
/dev/sdc1: UUID="bdb66cce-64e7-49b2-9a76-4a6023b6ba1f" TYPE="ext4" PARTUUID="adcfab5f-01"
/dev/sdc5: UUID="32466dd3-e7a8-412d-bbc0-8ca6cf9a1ad6" TYPE="ext4" PARTUUID="adcfab5f-05"
/dev/sda1: PARTLABEL="Microsoft reserved partition" PARTUUID="0918fb54-010e-41b5-9747-1d4e19509619"
NTFS
dwais, Если на компе есть винда - то запуститься в винду дождаться полной загрузки, затем выключить комп нормально через кнопку "Пуск". Если нет винды - скачать лайв-сиди с виндой нарезать на болванку или сделать флешку, загрузиться в винду ну и выключить штатно.
