Минт и 5060TI
den_kaz
Благодарил (а): 2 раза
Минт и 5060TI
28 июн 2025, 21:23
Приветствую.
Kernel: 6.8.0-62-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: MATE v: 1.26.2 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.D0
date: 12/12/2022
Info: quad core model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2
rev: 0 cache: L1: 256 KiB L2: 2 MiB L3: 16 MiB
Speed (MHz): avg: 2200 min/max: 2200/3906 boost: enabled cores: 1: 2200
2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 bogomips: 57597
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: AMD Baffin [Radeon RX 550 640SP / 560/560X] vendor: Gigabyte
driver: amdgpu v: kernel arch: GCN-4 bus-ID: 2b:00.0 temp: 37.0 C
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
resolution: 1280x1024~75Hz
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa
v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: AMD
Radeon RX 560 Series (radeonsi polaris11 LLVM 19.1.1 DRM 3.57
6.8.0-62-generic)
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 2b:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2d:00.4
API: ALSA v: k6.8.0-62-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 29:00.0
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel port: f000
bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-9:4
Report: hciconfig ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 1.14 TiB used: 46.13 GiB (4.0%)
ID-1: /dev/sda vendor: Western Digital model: WD1003FBYX-01Y7B1
ID-2: /dev/sdb vendor: Hitachi model: HTS545025B9A300 size: 232.89 GiB
ID-1: / size: 110.48 GiB used: 46.12 GiB (41.7%) fs: ext4 dev: /dev/sdb6
ID-2: /boot/efi size: 140.8 MiB used: 7 MiB (5.0%) fs: vfat dev: /dev/sdb4
Swap:
ID-1: swap-1 type: partition size: 3.72 GiB used: 0 KiB (0.0%)
dev: /dev/sdb5
System Temperatures: cpu: 39.9 C mobo: N/A gpu: amdgpu temp: 37.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1926
Memory: total: 8 GiB available: 7.67 GiB used: 3.59 GiB (46.7%)
Processes: 302 Uptime: 10m Init: systemd target: graphical (5)
Packages: 2034 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
купил карточку 5060TI
Картинки нет,вентиляторы на полную.
У кого имеется такая или новее карта подскажите как решили проблему,чтобы точно сработало с первого раза.
Гуглением пока нашёл вот это
https://forums.linuxmint.com/viewtopic.php?t=447920
https://zalinux.ru/?p=10240
сейчас чтобы работать в линуксе нужно ставить АМДшную карту.
как понимаю,можно попробовать поставить драйвера из под неё ?но смущают небольшие проблемы из поста по второй ссылке,типа поставишь и всё равно не работает...перетыкать карту опять придётся,чтобы в линукс загрузиться.
Минт и 5060TI
28 июн 2025, 22:13
В публикации указано, что 570-Open works fine with Kernel 6.11.
Ваше ядро – 6.8. Ядро 6.11 установить не пробовали?
Минт и 5060TI
29 июн 2025, 08:57
den_kaz, удали установленные драйвера невидии, перезагрузись, после этого установи из "Менеджера обновлений" самое свежее ядро (6.11). После этого уже устанавливай видяху. Комп должен загрузиться нормально, только видяха не будет работать "на все бабки", т.к. будет использоваться драйвер nouveau. И вот теперь можно пробовать устанавливать драйвер для видяхи. Если не взлетит пиши, у нас тут есть народ с картами невидии подскажут куда дальше копать
den_kaz
Минт и 5060TI
29 июн 2025, 11:45
Ядро Linux 6.11.0-28-generic x86_64
воз и ныне там
Минт и 5060TI
29 июн 2025, 11:54
den_kaz, тогда пробуй свежатинку(6.15) при помощи этой программы
den_kaz
Минт и 5060TI
29 июн 2025, 12:29
буду пробовать.
ДОП.
Ядро поставил,пришлось отключить в БИОСе Секьюр бут,а иначе вылезала ошибка с неверной подписью SHIM.Карту чуть позже подкину.
Минт и 5060TI
29 июн 2025, 14:28
den_kaz писал(а):
29 июн 2025, 12:29
Это надо было сделать еще до установки ОС. В случае с линукс оно только мешает. Некоторые устройства или вообще не работает или работают криво
den_kaz
Минт и 5060TI
29 июн 2025, 14:50
барабанная дробь.......нифига ))) кулера на всю,картинки нет.
ДОП.
Попробую всё ж тогда.
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt update
sudo apt-get install nvidia-driver-570-open
А потом уже пихнуть саму карту.
Благодарил (а): 1223 раза
Минт и 5060TI
29 июн 2025, 15:23
Бета-драйвер NVIDIA Graphics Driver 575.51.02 для Linux добавляет поддержку Smooth Motion — ИИ-интерполяции кадров в Vulkan-играх, а также множество исправлений. Также представлены видеокарты GeForce RTX 5060 и 5060 Ti
https://www.comss.ru/page.php?id=16264# ... %20Windows.
Минт и 5060TI
29 июн 2025, 16:19
den_kaz писал(а):
29 июн 2025, 14:50
кулера на всю
У меня была подобная проблема, когда на установленном на Macbook LM кулер визжал на полных оборотах не останавливаясь. Вылечилось установкой пакета mpbfan. М.б. и для вашей графики что-либо найдётся.
den_kaz
Минт и 5060TI
29 июн 2025, 17:18
Интересно,я если попробовать установить систему на другой ЖД установка то пройдёт нормально или тоже картинки не будет.Нужно пробовать.
den_kaz
Минт и 5060TI
29 июн 2025, 17:23
madesta, чтобы что-то сработало нужно для начала загрузиться в систему,а этого не происходит...но вот смущает то.что на забугорных форумах люди грузятся в систему .у них просто проблемы при установке дров и всё.
Попробовал удалить дрова 570 и этого система не дает.
Попробовал поставить из run по ссылке выше и тоже нифига...неужто нужно иметь рабочую графику,чтобы дрова поставить.
Проблема ещё в том,что у матери всего один разъём PCI-e и всё,остальные мелочёвка.А так можно было бы подсоединить Радеоновскую карту (второй картой) и попробовать загрузиться с неё (если такое возможно в Линуксе)
Есть ещё помирающая GTS450,но не думаю,что на неё встанут 570-575 дрова.
den_kaz
Минт и 5060TI
29 июн 2025, 21:21
Попробовал загрузится с флешки в надежде поставить систему.Ни последняя убунта 25.04,ни Минт так и не загрузились.Тот же звук кулеров на максимум и чёрный экран.
карта Гигабайт 5060TI Аурус Элит.
Минт и 5060TI
30 июн 2025, 00:09
den_kaz писал(а):
29 июн 2025, 21:21
Тут написано, что в BIOS попробовать сделать можно.
den_kaz
Минт и 5060TI
30 июн 2025, 14:52
Помогло
SR-IOV: ENABLED
Above 4G decoding: ENABLED
Всё работает и на ядре 6.8 на свободном драйвере.
От нвидиа ставить наверно не стану.Есть ли в нём толк,не знаю.
Минт и 5060TI
30 июн 2025, 16:47
den_kaz писал(а):
30 июн 2025, 14:52
Для твоей карты толк есть
Вернуться в «Мультимедиа»
