Linux Mint, rEFInd, и раздражающее сообщение.
HayAlai
Благодарил (а): 2 раза
23 май 2025, 14:17
Всем доброго времени суток, у меня есть вопрос.
Мои данные:
ОС Linux Mint 22.1 Cinnamon x64
Версия Cinnamon 6.4.8
Ядро Linux 6.8.0-60-generic
Вот моё железо:
[System:
Kernel: 6.8.0-60-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.4.8 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASRock model: B450M Pro4 R2.0
serial: <superuser required> UEFI: American Megatrends v: P5.70
date: 10/20/2022
Info: 6-core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+
rev: 2 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 2234 high: 2611 min/max: 2200/4650 boost: enabled cores:
1: 2196 2: 2194 3: 2193 4: 2200 5: 2200 6: 2205 7: 2200 8: 2611 9: 2196
10: 2228 11: 2193 12: 2194 bogomips: 88625
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: Palit Microsystems
driver: nvidia v: 570.133.07 arch: Ampere bus-ID: 07:00.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa
gpu: nvidia,nvidia-nvswitch resolution: 2560x1440
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
Device-1: NVIDIA GA104 High Definition Audio vendor: Palit Microsystems
driver: snd_hda_intel v: kernel bus-ID: 07:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 09:00.4
Device-3: HAOBO USB Composite Device
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-3:2
Device-4: KTMicro fifine Chat driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 1-4:3
API: ALSA v: k6.8.0-60-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.14 TiB used: 42.68 GiB (3.6%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
temp: 40.9 C
ID-2: /dev/sda vendor: TeamGroup model: T253X2256G size: 238.47 GiB
ID-1: / size: 45.64 GiB used: 29.28 GiB (64.2%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 1.9 GiB used: 101.3 MiB (5.2%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 182.1 GiB used: 13.3 GiB (7.3%) fs: ext4 dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 3.81 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 47.8 C mobo: N/A gpu: nvidia temp: 55 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 16 GiB available: 15.54 GiB used: 2.32 GiB (14.9%)
Processes: 308 Uptime: 9m Init: systemd target: graphical (5)
Packages: 2195 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
У меня стоит refind, всё отлично работает, всё классно и хорошо, но меня раздражает одно....
Когда я в refind запускаю Linux Mint, сначала выходит это: (Вложение №1)
А потом только через 2-3 секунды видется Linux Mint.
Помогите как это убрать, и можно ли вообще ? Может хотя бы скрыть его, что бы просто не было текста.
Если нужны какие-то данные для лучшего понимания напишите, желательно ещё написать как это сделать, я новичок, только недавно скачал Linux.
Вложение №1
Решение slant » 23 май 2025, 17:11
В файле /boot/efi/EFI/refind/refind.conf найти строку #use_graphics_for osx,linux и убрать # - признак комментария, чтобы стала активной. Если такой строчки вообще нет - добавить. Если нет такого файла - создать (простой тестовый файл).
Делать с root правами. Например так: sudo xed /boot/efi/EFI/refind/refind.conf
23 май 2025, 17:11
HayAlai
23 май 2025, 18:07
23 май 2025, 17:11
Огромное вам спасибо, вы меня спасли.
