Работа наушников и динамиков одновременно,и ещё кое-что.
den_kaz
Благодарил (а): 2 раза
24 апр 2025, 20:15
В названии темы полностью вопрос не сформулировать,так что написал как написал.
Для начала вывод из консоли
~$ inxi -Fxz
Kernel: 6.8.0-58-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: MATE v: 1.26.2 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.D0
date: 12/12/2022
Info: quad core model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2
rev: 0 cache: L1: 256 KiB L2: 2 MiB L3: 16 MiB
Speed (MHz): avg: 2200 min/max: 2200/3906 boost: enabled cores: 1: 2200
2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 bogomips: 57599
Device-1: AMD Baffin [Radeon RX 550 640SP / 560/560X] vendor: Gigabyte
driver: amdgpu v: kernel arch: GCN-4 bus-ID: 2b:00.0 temp: 44.0 C
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
resolution: 1280x1024~75Hz
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa
v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: AMD
Radeon RX 560 Series (radeonsi polaris11 LLVM 19.1.1 DRM 3.57
6.8.0-58-generic)
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 2b:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2d:00.4
API: ALSA v: k6.8.0-58-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 29:00.0
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel port: f000
bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-9:6
Report: hciconfig ID: hci0 rfk-id: 3 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 1.14 TiB used: 36.81 GiB (3.2%)
ID-1: /dev/sda vendor: Hitachi model: HTS545025B9A300 size: 232.89 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD1003FBYX-01Y7B1
ID-1: / size: 110.48 GiB used: 36.8 GiB (33.3%) fs: ext4 dev: /dev/sda6
ID-2: /boot/efi size: 140.8 MiB used: 6.1 MiB (4.3%) fs: vfat
dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 3.72 GiB used: 0 KiB (0.0%)
dev: /dev/sda5
System Temperatures: cpu: 45.1 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1150
Memory: total: 16 GiB available: 15.54 GiB used: 3.16 GiB (20.3%)
Processes: 280 Uptime: 20h 28m Init: systemd target: graphical (5)
Packages: 1978 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Проблема со звуком такого рода тут поднималась не однократно уже как погляжу.На старых системах решение с Альсамиксером помогало (выставил один раз и работает),на новой сейчас нет.
Стоит отправить систему в сон или выключить/перезагрузить и при повторной загрузке звука уже нет.Приходится лезть в Альсамиксер и ручками выставлять аналоговое устройство.
На старой системе (Уна) такого трабла не было вообще.
Звук в колонках всегда был...изредка не было звука в наушниках,но решалось либо переключением линейник/наушники,либо передёргиванием разъёма наушников....но это было крайне редко.
Пробовал по советам из Инета и alsa-tools-gui ,и pavucontrol-qt - не дало результата это.
Встречал ещё советы по удалению полностью устройства на ХДМИ,чтобы аналог стал дефолтным (нулевым) и затем уже повторной установки устройства на ХДМИ....чтобы они местами поменялись.
Ещё встречал совет редактирования конфигурационного файла Альсы,но так и не понял где там ставить 0 и 1 напротив устройств.
Потыкался,совсем звук пропал.Благо заскринил как было и вернул всё взад.
По команде aplay -l выводит это
$ aplay -l
**** Список PLAYBACK устройств ****
карта 0: HDMI [HDA ATI HDMI], устройство 3: HDMI 0 [HDMI 0]
Подустройства: 1/1
Подустройство №0: subdevice #0
карта 0: HDMI [HDA ATI HDMI], устройство 7: HDMI 1 [HDMI 1]
Подустройства: 1/1
карта 0: HDMI [HDA ATI HDMI], устройство 8: HDMI 2 [HDMI 2]
Подустройства: 1/1
карта 0: HDMI [HDA ATI HDMI], устройство 9: HDMI 3 [HDMI 3]
Подустройства: 1/1
карта 0: HDMI [HDA ATI HDMI], устройство 10: HDMI 4 [HDMI 4]
Подустройства: 1/1
карта 1: Generic [HD-Audio Generic], устройство 0: ALC892 Analog [ALC892 Analog]
Подустройства: 1/1
Суть проблемы в данном случае.
Как выставить аналоговое устройство так в списке,чтобы с него шёл звук всё время и не приходилось ничего выбирать.
Звук с ХДМИ как и устройство само мне не нужно вообще,монитор без динамиков.
при запуске Альсамиксера высвечивается это
в списке по дефолту сначала идёт звук с наушников (вроде)
на аналоговом устройстве при подключённых наушниках и колонках,последние не видятся,приходится постоянно включать Центр
24 апр 2025, 23:40
Что-то похожее было здесь. По крайней мере, в 2020 г. на LM мне помогло создание .asoundrc.
den_kaz
25 апр 2025, 11:48
den_kaz писал(а):
24 апр 2025, 20:15
конечно Фронт имелось ввиду,а не Центр.
madesta,
попробую.
den_kaz
25 апр 2025, 15:37
Небольшое продвижение есть.
После создания файла .asoundrc и прописывания в нём card1 ,как по ссылке выше,одновременно звук в динамиках и наушниках не появился,но в Альсамиксере при его запуске высвечивается аналоговое устройство,сразу же,выбирать ничего не приходится.Уже плюс.
Осталось заставить как-нибудь запускать и Фронтальный выход на динамики .В Параметрах звука стоит Аналоговый стерео дуплекс.По идее звук должен быть.
Если же переключить с дуплекса на стерео,а потом обратно,то звука в динамиках уже нет.Только в наушниках.
И приходится в Альсамиксере снова включать Фронтальный выход.
Чего они там поломали,фиг знает.
Вернуться в «Мультимедиа»
