Kernel: 6.8.0-53-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.4.7 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Laptop System: LENOVO product: 20236 v: Lenovo G500
serial: <superuser required>
Mobo: LENOVO model: INVALID v: 31900004Std serial: <superuser required>
UEFI: LENOVO v: 78CN19WW(V1.07) date: 07/04/2013
ID-1: BAT1 charge: 3.9 Wh (100.0%) condition: 3.9/40.4 Wh (9.5%) volts: 11.5
min: 10.8 model: LENOVO PABAS0241231 status: full
Info: dual core model: Intel Core i3-3110M bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1197 min/max: 1200/2400 cores: 1: 1197 2: 1197 3: 1197
4: 1197 bogomips: 19156
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7 bus-ID: 00:02.0
Device-2: AMD Sun PRO [Radeon HD 8570A/8570M] vendor: Lenovo
driver: radeon v: kernel arch: GCN-1 bus-ID: 01:00.0 temp: 45.0 C
Device-3: Realtek Lenovo EasyCamera driver: uvcvideo type: USB
bus-ID: 3-4:3
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting,radeon unloaded: fbdev,vesa dri: crocus gpu: i915
resolution: 1366x768~60Hz
API: EGL v: 1.5 drivers: crocus,kms_swrast,radeonsi,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa
v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel HD Graphics 4000 (IVB GT2)
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.8.0-53-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Qualcomm Atheros QCA8172 Fast Ethernet vendor: Lenovo driver: alx
v: kernel port: 2000 bus-ID: 02:00.0
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Lenovo driver: N/A
bus-ID: 03:00.0
Bluetooth:
Device-1: Foxconn BCM43142A0 Bluetooth module driver: btusb v: 0.8 type: USB
bus-ID: 2-1.3:3
Report: hciconfig ID: hci0 rfk-id: 2 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 447.13 GiB used: 18.44 GiB (4.1%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-1: / size: 438.55 GiB used: 18.43 GiB (4.2%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda1
Swap:
System Temperatures: cpu: 56.0 C mobo: N/A gpu: radeon temp: 45.0 C
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.62 GiB used: 2.09 GiB (27.5%)
Processes: 224 Uptime: 10m Init: systemd target: graphical (5)
Packages: 1999 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
0: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: ideapad_bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
Kernel driver in use: radeon
Kernel modules: radeon, amdgpu
02:00.0 Ethernet controller [0200]: Qualcomm Atheros QCA8172 Fast Ethernet [1969:10a0] (rev 10)
Subsystem: Lenovo QCA8172 Fast Ethernet [17aa:3802]
Kernel driver in use: alx
Kernel modules: alx
