Упал FPS на рабочем столе после перехода на mint
ethelay
10 фев 2025, 17:26
Linux Mint 22.1 x64 Xia
Kernel: 6.8.0-52-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.4.6 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Laptop System: Hewlett-Packard product: HP EliteBook Folio 9480m
v: A3009DD10303 serial: <superuser required>
Mobo: Hewlett-Packard model: 22DA v: KBC Version 92.17
serial: <superuser required> UEFI: Hewlett-Packard v: M85 Ver. 01.50
date: 02/24/2020
ID-1: BAT0 charge: 19.0 Wh (36.6%) condition: 51.9/51.9 Wh (100.0%)
volts: 14.8 min: 14.8 model: Hewlett-Packard Primary status: discharging
Info: dual core model: Intel Core i5-4310U bits: 64 type: MT MCP
arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 914 high: 1057 min/max: 800/3000 cores: 1: 1006 2: 1057
3: 798 4: 798 bogomips: 20751
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7.5 bus-ID: 00:02.0
Device-2: Lite-On HP HD Webcam driver: uvcvideo type: USB bus-ID: 2-7:6
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: intel dri: crocus gpu: i915 resolution: 1366x768~60Hz
API: EGL v: 1.5 drivers: crocus,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa
v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel HD Graphics 4400 (HSW GT2)
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard 8
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.8.0-52-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: 5080 bus-ID: 00:19.0
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 08:00.0
Device-3: HP HP hs3110 HSPA+ Mobile Broadband Device driver: N/A type: USB
bus-ID: 2-6:5
Bluetooth:
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
bus-ID: 2-4:3
Report: hciconfig ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 476.94 GiB used: 26.14 GiB (5.5%)
ID-1: /dev/sda vendor: Apacer model: AS350 512GB size: 476.94 GiB
ID-1: / size: 467.89 GiB used: 26.13 GiB (5.6%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 512 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB note: est. available: 7.18 GiB used: 3.22 GiB (44.9%)
Processes: 238 Uptime: 57m Init: systemd target: graphical (5)
Packages: 1961 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Перешёл на Mint с Windows. До этого с FPS все было в порядке. Сейчас же FPS как-будто упал, а раскрытие окон и пролистывание страницы идет рывками. Понимаю, что вопрос может быть банальным, но перерыл все и не смог решить проблему. Заранее спасибо!
sveta13
Благодарил (а): 47 раз
11 фев 2025, 00:08
В какую игру играешь, народ вне понятке :magic:
Debian 12 xfce:LM-22.1 xfce:
SpectreZ
Благодарил (а): 6 раз
11 фев 2025, 13:02
Скорее всего, речь о том, что тормозят эффекты рабочего стола (свертывание окон и т.д.).
Можно попробовать установить драйвер на видео, если используется видео карта Nvidia.
11 фев 2025, 14:38
SpectreZ писал(а):
11 фев 2025, 13:02
У автора Intel HD Graphics 4400 (HSW GT2) с драйвером i915.
SpectreZ писал(а):
11 фев 2025, 13:02
...тормозят эффекты рабочего стола (свертывание окон и т.д.).
А вот это отключить следовало бы попробовать.
Также может быть имеет смысл вдумчиво рассмотреть возможность чего-то улучшить на основании этих материалов: ссылка1, ссылка2, ссылка3. Мне, например, по последней ссылке очень помогло в параметрах grub: page_alloc.shuffle=1 и pci=pcie_bus_perf
11 фев 2025, 15:02
ethelay, тебе бы взять версию с MATE или XFCE, т.к. для твоей видяхи Cinnamon очень тяжело крутить
11 фев 2025, 18:02
Я тут вспомнил, что slant по ноутбукам выказывался. Может быть как раз тот случай?
ethelay
13 фев 2025, 08:41
Спасибо большое! Сегодня попробую, отвечу
Максимыч
Благодарил (а): 7 раз
14 фев 2025, 08:38
11 фев 2025, 15:02
Есть старенький ноут, не заметил разницы между Cinnamon и Mate на LMDE.
14 фев 2025, 13:08
Максимыч писал(а):
14 фев 2025, 08:38
Повезло. Cinnamon смог запуститься с аппаратным рендерингом.
Максимыч
16 фев 2025, 10:36
14 фев 2025, 13:08
Максимыч писал(а):
14 фев 2025, 08:38
А что может быть и программный? Не силен в этом вопросе
16 фев 2025, 11:23
Максимыч писал(а):
16 фев 2025, 10:36
На предыдущем системном блоке (покупка в 2011 г.) у меня Cinnamon периодически вылетал с последующим перезапуском. В те времена (2012-2016) предположил, что моё железо системного блока не дружит с Cinnamon, поэтому устанавливал xfce. На более новом железе таких проблем уже не было, правда и проверялось на релизе LM20. Что сейчас думать не берусь и предполагать.
16 фев 2025, 14:59
Максимыч писал(а):
16 фев 2025, 10:36
Конечно. Можно даже принудительно запустить сессию Cinnamon в этом режиме. Выбирается в окне логина
Максимыч
17 фев 2025, 07:59
madesta писал(а):
16 фев 2025, 11:23
Максимыч писал(а):
16 фев 2025, 10:36
Странно,у меня ноут 5 года, на нем корица, для офисных задач очень уверенно работает.
