Linssid.
prusony
Благодарил (а): 182 раза
Linssid.
15 янв 2025, 17:02
Из репы поставил Linssid, запускаю, получаю:
У меня "Трыжик" , Беларусь, оператор "Лайф"
Что нетак ? Хелп.
Мой inxi -Fxz
Kernel: 5.15.0-130-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: Xfce 4.18.1 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: MSI model: ZH77A-G43 (MS-7758) v: 1.0
serial: <superuser required> BIOS: American Megatrends v: 1.7
date: 12/24/2012
Info: quad core model: Intel Core i7-3770 bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 2011 high: 2626 min/max: 1600/3900 cores: 1: 1600
2: 1787 3: 1773 4: 1798 5: 2488 6: 2626 7: 1611 8: 2411 bogomips: 54403
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: ZOTAC driver: nvidia
v: 535.183.01 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 535.183.01 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC
Device-3: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: N/A bus-ID: 05:01.0
Sound Server-1: ALSA v: k5.15.0-130-generic running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: ZTE WCDMA MSM DEMO Mobile Boardband type: USB
driver: cdc_ether,usb-storage bus-ID: 1-1.5:4
IF: enx344b50000000 state: up speed: 150 Mbps duplex: half mac: <filter>
Local Storage: total: 558.93 GiB used: 134.99 GiB (24.2%)
ID-1: /dev/sda model: SATA3 240GB SSD size: 223.57 GiB
ID-2: /dev/sdb vendor: Intel model: SSDSC2BW120A4 size: 111.79 GiB
ID-3: /dev/sdc model: SATA3 240GB SSD size: 223.57 GiB
ID-1: / size: 218.01 GiB used: 134.99 GiB (61.9%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 512 MiB used: 12 KiB (0.0%) fs: vfat dev: /dev/sda3
Swap:
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Processes: 295 Uptime: 31m Memory: 15.56 GiB used: 2.39 GiB (15.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3055 Shell: Bash
v: 5.1.16 inxi: 3.3.13
stasAiver
Благодарил (а): 312 раз
Linssid.
15 янв 2025, 17:17
prusony, так у тебя 3G Модем, а Linssid пытается найти WiFi, об отсутствии которой и пишет.
prusony
Linssid.
15 янв 2025, 17:25
Так-то сильно плаваю в сетевых делах... Потому сорри если туплю.
Но на 3G-жике ВайФай активен, разве этого не достаточно ?
Хорошо - а как тогда мне просмотреть что в эфире вокруг ? Какой софтиной ?
За ответ спасибо.
Linssid.
15 янв 2025, 18:24
prusony писал(а):
15 янв 2025, 17:25
В таком варианте - никакой. Нет подходящего железа на машине (если речь о Wi-Fi). То что в модеме - не считается, у системы к нему прямого доступа нет.
prusony
Linssid.
15 янв 2025, 19:03
Спасибо Всем!
(Поставлю на мобилку приложение...)
