Отсутствие звука на Huawei Matebook D15
Нет звука? Вас не устраивает качество звучания? Вы попали по адресу.
ivantozavr
Сообщение ivantozavr » 02 янв 2025, 19:51
Здравствуйте! Я пользуюсь Linux Mint 21.3 Virginia x64 на Huawei Matebook D15, недавно перешел с Windows.
Вывод inxi -Fxz:
  Kernel: 6.8.0-49-generic x86_64 bits: 64 compiler: N/A
    base: Ubuntu 22.04 jammy
  Type: Laptop System: HUAWEI product: BOM-WXX9 v: M1010
    serial: <superuser required>
  Mobo: HUAWEI model: BOM-WXX9-PCB-B3 v: M1010 serial: <superuser required>
    UEFI: HUAWEI v: 3.01 date: 10/13/2023
  ID-1: BAT1 charge: 23.3 Wh (42.6%) condition: 54.7/54.9 Wh (99.6%)
    volts: 7.6 min: 7.6 model: Sunwoda-H HB4692Z9ECW-22T status: Discharging
  Info: 8-core model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 2 rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
  Speed (MHz): avg: 524 high: 1397 min/max: 400/4372 cores: 1: 400 2: 400
    3: 400 4: 400 5: 400 6: 400 7: 1397 8: 400 9: 400 10: 400 11: 400 12: 1397
    13: 400 14: 400 15: 400 16: 400 bogomips: 57491
  Device-1: AMD Lucienne vendor: QUANTA driver: amdgpu v: kernel
    bus-ID: 03:00.0
  Device-2: Quanta ov9734_techfront_camera type: USB driver: uvcvideo
    bus-ID: 1-4:3
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
    unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
  OpenGL: renderer: RENOIR (renoir LLVM 15.0.7 DRM 3.57 6.8.0-49-generic)
    v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: QUANTA
    driver: snd_hda_intel v: kernel bus-ID: 03:00.1
    vendor: QUANTA driver: snd_acp_pci v: kernel bus-ID: 03:00.5
  Sound Server-1: ALSA v: k6.8.0-49-generic running: yes
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: & Tele RSH driver: rtw_8822ce v: N/A port: 2000 bus-ID: 01:00.0
Bluetooth:
  Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
    bus-ID: 3-2:2
    bt-v: 3.0 lmp-v: 5.1
  Local Storage: total: 476.94 GiB used: 129.09 GiB (27.1%)
  ID-1: /dev/nvme0n1 model: PCIe-4 SSD 512GB size: 476.94 GiB temp: 28.9 C
  ID-1: / size: 467.89 GiB used: 129.08 GiB (27.6%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 34.0 C
  Processes: 368 Uptime: 54m Memory: 14.96 GiB used: 2.22 GiB (14.8%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2475 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Собственно, проблема в тотальном отсутствии звука. Слушать получается только через bluetooth-наушники.
А через динамики ноута и jack-порт звук не идет (последний в системе даже не виден).
Вот вывод aplay -l:
карта 0: Generic [HD-Audio Generic], устройство 3: Generic Digital [Generic Digital]
  Подустройства: 1/1
  Подустройство №0: subdevice #0
карта 1: acp3xes83xx [acp3x-es83xx], устройство 0: (null) ES8316 HiFi-0 []
  Подустройства: 1/1
Вот что имеется в alsamixer:
В pavucontrol есть стерео-выход, подключенный jack не виден:
Стерео, как я уже сказал, тоже не работает, хоть и виден. Насколько я понимаю, это какая-то глобальная проблема моего ноутбука, но все же хочу попытать удачи, вдруг кто-нибудь что-нибудь подскажет. Ситуация с jack, возможно, не та же, что со стандартным стерео выходом. Короче, буду благодарен за любую помощь.
Благодарил (а): 802 раза
Сообщение rogoznik » 03 янв 2025, 11:14
В alsamixer надо выбрать карту через F6. И уже смотреть что там
Решено: 19
Благодарил (а): 1322 раза
Сообщение hellonet » 03 янв 2025, 11:18
У меня практически такой же ноутбук
https://www.dns-shop.ru/product/542dd71 ... win10grey/
Звук нормальный. Установлена LM 21.3 Virginia Mate
h@h-NBLK-WAX9X:~$ inxi -Fxz
Kernel: 5.15.0-124-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: MATE 1.26.0 Distro: Linux Mint 21.3 Virginia
Type: Laptop System: HUAWEI product: NBLK-WAX9X v: M1020
Mobo: HUAWEI model: NBLK-WAX9X-PCB v: M1020 serial: <superuser required>
UEFI: HUAWEI v: 1.19 date: 01/06/2023
ID-1: BAT1 charge: 37.9 Wh (87.1%) condition: 43.5/55.3 Wh (78.6%)
volts: 15.8 min: 15.3 model: Sunwoda-H HB4692Z9ECW-41 status: Discharging
Info: quad core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB
L2: 2 MiB L3: 4 MiB
Speed (MHz): avg: 1483 high: 2365 min/max: 1400/2100 boost: enabled
cores: 1: 1197 2: 1197 3: 2321 4: 2365 5: 1197 6: 1197 7: 1197 8: 1197
bogomips: 33537
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Huawei driver: amdgpu v: kernel bus-ID: 03:00.0
Device-2: IMC Networks ov9734_azurewave_camera type: USB driver: uvcvideo
bus-ID: 1-4:3
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1280x720~60Hz
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 15.0.7 DRM 3.42
5.15.0-124-generic)
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
vendor: Huawei driver: snd_pci_acp3x v: kernel bus-ID: 03:00.5
Device-3: AMD Family 17h HD Audio vendor: Huawei driver: snd_hda_intel
v: kernel bus-ID: 03:00.6
Sound Server-1: ALSA v: k5.15.0-124-generic running: yes
vendor: & Tele RSH driver: rtw_8822ce v: N/A port: 2000 bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-2:3
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 476.94 GiB used: 34.84 GiB (7.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-00000
size: 476.94 GiB temp: 36.9 C
ID-1: / size: 35.07 GiB used: 16.24 GiB (46.3%) fs: ext4
dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 96 MiB used: 55.2 MiB (57.5%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 35.37 GiB used: 18.54 GiB (52.4%) fs: ext4
dev: /dev/nvme0n1p7
Swap:
ID-1: swap-1 type: partition size: 3.9 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p8
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 319 Uptime: 5m Memory: 6.7 GiB used: 2.51 GiB (37.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2316 Shell: Bash
Специально ничего не настраивал. Всё пошло сразу после установки
ivantozavr
Сообщение ivantozavr » 03 янв 2025, 11:53
03 янв 2025, 11:14
У меня вот так:
Решено: 19
Сообщение hellonet » 03 янв 2025, 12:29
ivantozavr, может дело в ядре?
У меня Kernel: 5.15.0-124-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
А у тебя Kernel: 6.8.0-49-generic x86_64 bits: 64 compiler: N/A
Особенно смущает compiler: N/A
Может стоит поставить более старое ядро?
ivantozavr
Сообщение ivantozavr » 03 янв 2025, 13:31
hellonet писал(а):
03 янв 2025, 12:29
Переустановил ядро. Теперь у меня тоже
И появилась еще одна звуковая карта:
Но звука как не было, так и нет, и jack-разъем по-прежнему не виден((
Благодарил (а): 55 раз
Сообщение slant » 03 янв 2025, 13:47
ivantozavr писал(а):
03 янв 2025, 13:31
А теперь переустанавливай обратно - поддержка этих карт судя по всему только с 6.0 появилась.
Вообще - мало на их тему. Вот, нашел кое что - у некоторых запускается, у некоторых нет. Кому-то помогает полный сброс UEFI... В общем - проблемное железо, походу.
https://archlinux.com.ru/forum/viewtopi ... 0059da2d9a
ivantozavr
Сообщение ivantozavr » 03 янв 2025, 14:05
Переустановил самое последнее ядро 6.8.0-50. Теперь появилась новая карта в alsamixer, при выборе которой выглядит все так (звука нет):
Решено: 19
Сообщение hellonet » 03 янв 2025, 14:27
03 янв 2025, 13:31
Но в плане звука ничего не изменилось((
А если запустить ноут с загрузочной флешки - звук есть? Если то же нет, то восстанавливаем звук по инструкции на хабре:
https://habr.com/ru/articles/767434/
Последний раз редактировалось пользователем 2 hellonet; всего редактировалось раз: 3
Решено: 19
Сообщение hellonet » 03 янв 2025, 14:30
03 янв 2025, 14:05
Тоже его поставил. Звук есть как и на 5.15
ivantozavr
Сообщение ivantozavr » 03 янв 2025, 16:15
hellonet писал(а):
03 янв 2025, 14:27
Спасибо, попробую
ivantozavr
Сообщение ivantozavr » 03 янв 2025, 19:37
hellonet писал(а):
03 янв 2025, 14:27
К сожалению, ничего не вышло. Насколько я понимаю, это руководство полезно в том случае, когда нет поддержки кодека ES8336, то есть при запросе "cat /boot/config-`uname -r` |grep 8336" НЕ выдается "CONFIG_SND_SOC_INTEL_SOF_ES8336_MACH=m". Но у меня этот кодек базово поддерживается. Я все равно проделал все, что в этой статье советуется, результата нет.
По поводу того, что у нас с вами похожие устройства - это да. Но если посмотреть на аудио устройства, то совпадает только "AMD Raven/Raven2/FireFlight/Renoir Audio Processor", остальные Audio: Device не совпадают, то есть по железу D14 и D15, получается, не идентичны.
Решено: 19
Сообщение hellonet » 03 янв 2025, 19:53
03 янв 2025, 19:37
Увы, да. Поэтому и пишут про D15, что у многих проблемы, связаны с отсутствием звука в различных версиях Linux. В Windows звук есть. С этим проблем не возникает. Хотя есть сведения, что и D14 этим страдает. Видимо есть разновидности моделей этих ноутбуков с различными аудиоустройствами. Подозреваю есть и идентичные по ним D14 и 15 у которых тоже нет звука и есть модели , у которых он есть, которые тоже идентичны между собой по аудио. В общем собирают ноуты на заводе из того, что в данный момент есть под рукой. Унифицированности (или унификации?) особой нет
Решено: 19
Сообщение hellonet » 03 янв 2025, 20:25
Поискал, почитал. Очень всё мудрёно
https://ru.stackoverflow.com/questions/ ... 1%82%d1%83
Я бы наверное не справился. Это мне ещё с D14 повезло просто
ivantozavr
Сообщение ivantozavr » 04 янв 2025, 10:26
hellonet писал(а):
03 янв 2025, 20:25
Да, это что-то для продвинутых линуксоидов, я так сильно в железо лезть не стану. Без динамиков грустно, но жить можно. Все равно спасибо за помощь))
Решено: 19
Сообщение hellonet » 04 янв 2025, 10:34
02 янв 2025, 19:51
Можно попробовать подсоединить колонки не через встроенный jack-порт, а через внешнюю USB звуковую карту. Она недорогая. Бывает, что спасает, когда нужен хоть какой-то звук
https://www.ozon.ru/product/vneshnyaya- ... =questions
ivantozavr
Сообщение ivantozavr » 04 янв 2025, 12:42
hellonet писал(а):
04 янв 2025, 10:34
Да, скорее всего придется сделать так. Спасибо
umpersand
Сообщение umpersand » 14 дек 2025, 11:29
Приветствую всех.
Я так понимаю не удалось решить вопрос со звуком?! Понравился Linux Mint , но тоже столкнулся с проблемой со звуком. (Huawei Matebook D15)
Попробовал много дистрибутивов разных линукс. Минт "зашел" больше всех. НО везде беда со звуком - кроме Debian!
Сразу работает из коробки абсолютно все .
Вопрос: Возможно ли как то вытащить драйвера из дебиан , чтобы установить их на минт?
пс: скрины не грузятся с облака в посте - вот Залил на облако скрины связанные со звуком
survordie
Благодарил (а): 36 раз
Сообщение survordie » 14 дек 2025, 11:49
umpersand писал(а):
14 дек 2025, 11:29
Минт это DE Cinnamon поверх Бубунты, которая является нестабильным Debian.
Если у вас работают драйвера в Дебиан и вам нравится Минт( DE Cinnamon), то и поставьте себе Дебиан. А на этапе установки в момент выбора оболочки, просто выберите DE Cinnamon.
Тут вот даже руководство завалялось.
Со скрином выбора DE. Только вместо Xfce выберите Cinnamon
Debian 13 + Xfce
umpersand
Сообщение umpersand » 14 дек 2025, 12:01
survordie писал(а):
14 дек 2025, 11:49
Я установил дебиан ( на этапе установки не увидел что можно DE Cinnamon. выбрать)- сейчас им и пользуюсь. Но тем не менее возможно ли вытащить драйвера ?
Вернуться в «Звуковые карты»
