Регулировка яркости
sveta13
Благодарил (а): 45 раз
Регулировка яркости
Сообщение sveta13 » 14 дек 2024, 11:34
Здравствуйте всем :smile:.
Не работает регулировка яркости, а также исчез бегунок онной регулировки при нажатии Fn <>.
acpi_video0
Host: sveta-Aspire-3830T Kernel: 6.8.0-49-generic arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: Linux Mint 22.1 Xia
Type: Laptop System: Acer product: Aspire 3830T v: V1.01
serial: <superuser required>
Mobo: Acer model: JM30_HR serial: <superuser required> BIOS: Acer v: 1.01
date: 03/10/2011
ID-1: BAT0 charge: 0% condition: 11.4/64.8 Wh (17.6%) volts: 8.3 min: 10.8
Info: dual core model: Intel Core i3-2310M bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 798 min/max: 800/2100 cores: 1: 798 2: 798 3: 798 4: 798
driver: i915 v: kernel
Device-2: NVIDIA GF108M [GeForce GT 540M] driver: nouveau v: kernel
Device-3: Alcor Micro Acer Integrated Webcam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915,nouveau
resolution: 1: 1366x768~60Hz 2: N/A
API: EGL v: 1.5 drivers: crocus,nouveau,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 24.0.9-0ubuntu0.3
renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
driver: snd_hda_intel
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.8.0-49-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet driver: atl1c
IF: enp2s0 state: down mac: 1c:75:08:f9:b6:dd
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter driver: ath9k
IF: wlp3s0 state: up mac: ec:55:f9:70:56:64
Bluetooth:
Device-1: Qualcomm Atheros AR3011 Bluetooth driver: btusb type: USB
Report: hciconfig ID: hci0 state: up address: C0:F8:DA:10:5A:FA bt-v: 3.0
Local Storage: total: 465.76 GiB used: 12.77 GiB (2.7%)
ID-1: /dev/sda vendor: Western Digital model: WD5000BPVT-22HXZT1
ID-1: / size: 49.19 GiB used: 8.66 GiB (17.6%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 148.36 GiB used: 4.11 GiB (2.8%) fs: ext4 dev: /dev/sda4
Swap:
Alert: No swap data was found.
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nouveau temp: 38.0 C
Fan Speeds (rpm): N/A
Memory: total: 6 GiB note: est. available: 5.64 GiB used: 2.01 GiB (35.6%)
Processes: 224 Uptime: 2h 5m Shell: Bash inxi: 3.3.34
Вроде ничего кримминального не делала, просто удалила почти все темы из usr/ share/themes, полвину из папки /icons, установила свои, я и раньше так делала и вроде всё было Ок, в интернете перерыла кучу инфы по этому вопросу? Раньше прокатывало это:
GRUB_CMDLINE_LINUX DEFAULT="quiet splash pcie_aspm=force acpi_backlight=native"
GRUB_CMDLINE_LINUX=""
sudo update-grub
сейчас нет.
Сеансы и запуск-Дополнительно-Запускать службы GNOME при входе в систему (бегунок появился, яркость не регулируеться)
Debian 12 xfce:LM-22.1 xfce:
sveta13
Регулировка яркости
Сообщение sveta13 » 15 дек 2024, 14:04
Переустановила систему. Тема закрыта :thumbs:
Вернуться в «Xfce»
