Долгая загрузка системы
pluer
Благодарил (а): 2 раза
06 дек 2024, 14:03
LM 22 Cinnamon wilma x86_64
Kernel: 6.8.0-49-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
Desktop: Cinnamon v: 6.2.9 Distro: Linux Mint 22 Wilma
base: Ubuntu 24.04 noble
Type: Laptop System: HUAWEI product: NBD-WXX9 v: M1010
serial: <superuser required>
Mobo: HUAWEI model: NBD-WXX9-PCB-B5 v: M1010 serial: <superuser required>
UEFI: HUAWEI v: 2.31 date: 11/02/2022
ID-1: BAT1 charge: 20.1 Wh (39.9%) condition: 50.4/54.9 Wh (91.7%)
volts: 7.5 min: 7.6 model: Sunwoda-H HB4692Z9ECW-22T status: discharging
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB
Speed (MHz): avg: 716 high: 1288 min/max: 400/4200 cores: 1: 523 2: 941
3: 400 4: 626 5: 400 6: 1288 7: 975 8: 576 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: QUANTA
driver: i915 v: kernel arch: Gen-12.1 bus-ID: 00:02.0
Device-2: Quanta ov9734_techfront_camera driver: uvcvideo type: USB
bus-ID: 1-6:3
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-0ubuntu0.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: QUANTA
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
API: ALSA v: k6.8.0-49-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
IF: wlp0s20f3 state: up mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-10:5
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 476.94 GiB used: 59.07 GiB (12.4%)
ID-1: /dev/nvme0n1 model: 511BS0512HB size: 476.94 GiB temp: 27.9 C
ID-1: / size: 46.88 GiB used: 22.99 GiB (49.0%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 196 MiB used: 51.4 MiB (26.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 91.39 GiB used: 36.03 GiB (39.4%) fs: ext4
dev: /dev/nvme0n1p7
Swap:
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.56 GiB used: 4.65 GiB (61.6%)
Processes: 345 Uptime: 14m Init: systemd target: graphical (5)
Packages: 2335 Compilers: gcc: 13.2.0 Shell: Zsh v: 5.9 inxi: 3.3.34
После расширения корневого и home диска система начала долго загружаться, но в спящий режим переходит быстро. Дольше всего загружается userspace.
Startup finished in 2.993s (firmware) + 5.434s (loader) + 33.391s (kernel) + 1min 37.860s (userspace) = 2min 19.679s
graphical.target reached after 1min 37.847s in userspace.
5.873s NetworkManager-wait-online.service
2.221s postgresql@16-main.service
1.665s zfs-load-module.service
1.077s systemd-udev-settle.service
709ms docker.service
692ms NetworkManager.service
521ms thermald.service
272ms systemd-rfkill.service
267ms blueman-mechanism.service
229ms dev-nvme0n1p5.device
188ms upower.service
180ms boot-efi.mount
166ms ufw.service
152ms containerd.service
151ms rsyslog.service
147ms accounts-daemon.service
139ms gnome-remote-desktop.service
138ms udisks2.service
134ms user@1000.service
132ms gpu-manager.service
122ms ubuntu-system-adjustments.service
121ms polkit.service
101ms systemd-udev-trigger.service
В моем случае подойдет решение добавить в файл? vi /etc/default/grub - GRUB_CMDLINE_LINUX_DEFAULT="quiet rootfstype=ext4 libahci.ignore_sss=1 raid=noautodetect selinux=0 plymouth.enable=0 lpj=12053560"
06 дек 2024, 19:38
pluer писал(а):
06 дек 2024, 14:03
Нет.
В вашем случае нужно сначала логи смотреть. Командой journalctl -b > lastboot.txt создайте файл и загрузите его куда-нить так, чтобы можно было скачать и посмотреть.
pluer
06 дек 2024, 20:01
06 дек 2024, 19:38
Отправляю ссылку https://disk.yandex.ru/d/Z-QNJCVNxmzOeA
06 дек 2024, 22:03
дек 06 19:52:36 pluer-NBD-WXX9 systemd[1]: systemd-rfkill.service: Deactivated successfully.
дек 06 19:53:00 pluer-NBD-WXX9 systemd[1]: systemd-fsckd.service: Deactivated successfully.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: dev-disk-by\x2duuid-6d6be005\x2d6606\x2d4082\x2d9fd5\x2d23b934ede4b7.device: Job dev-disk-by\x2duuid-6d6be005\x2d6606\x2d4082\x2d9fd5\x2d23b934ede4b7.device/start timed out.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-6d6be005\x2d6606\x2d4082\x2d9fd5\x2d23b934ede4b7.device - /dev/disk/by-uuid/6d6be005-6606-4082-9fd5-23b934ede4b7.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: Dependency failed for dev-disk-by\x2duuid-6d6be005\x2d6606\x2d4082\x2d9fd5\x2d23b934ede4b7.swap - /dev/disk/by-uuid/6d6be005-6606-4082-9fd5-23b934ede4b7.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: Dependency failed for swap.target - Swaps.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: swap.target: Job swap.target/start failed with result 'dependency'.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: dev-disk-by\x2duuid-6d6be005\x2d6606\x2d4082\x2d9fd5\x2d23b934ede4b7.swap: Job dev-disk-by\x2duuid-6d6be005\x2d6606\x2d4082\x2d9fd5\x2d23b934ede4b7.swap/start failed with result 'dependency'.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: dev-disk-by\x2duuid-6d6be005\x2d6606\x2d4082\x2d9fd5\x2d23b934ede4b7.device: Job dev-disk-by\x2duuid-6d6be005\x2d6606\x2d4082\x2d9fd5\x2d23b934ede4b7.device/start failed with result 'timeout'.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: dev-disk-by\x2duuid-85af7e66\x2d5dd7\x2d40cc\x2d983c\x2d8a5105df29bc.device: Job dev-disk-by\x2duuid-85af7e66\x2d5dd7\x2d40cc\x2d983c\x2d8a5105df29bc.device/start timed out.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-85af7e66\x2d5dd7\x2d40cc\x2d983c\x2d8a5105df29bc.device - /dev/disk/by-uuid/85af7e66-5dd7-40cc-983c-8a5105df29bc.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: Dependency failed for dev-disk-by\x2duuid-85af7e66\x2d5dd7\x2d40cc\x2d983c\x2d8a5105df29bc.swap - /dev/disk/by-uuid/85af7e66-5dd7-40cc-983c-8a5105df29bc.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: dev-disk-by\x2duuid-85af7e66\x2d5dd7\x2d40cc\x2d983c\x2d8a5105df29bc.swap: Job dev-disk-by\x2duuid-85af7e66\x2d5dd7\x2d40cc\x2d983c\x2d8a5105df29bc.swap/start failed with result 'dependency'.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: dev-disk-by\x2duuid-85af7e66\x2d5dd7\x2d40cc\x2d983c\x2d8a5105df29bc.device: Job dev-disk-by\x2duuid-85af7e66\x2d5dd7\x2d40cc\x2d983c\x2d8a5105df29bc.device/start failed with result 'timeout'.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: Mounting run-qemu.mount - Prepare /run/qemu to allow still running qemu binaries of former builds (after package upgrades) to fallback-load modules from there...
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: Mounted run-qemu.mount - Prepare /run/qemu to allow still running qemu binaries of former builds (after package upgrades) to fallback-load modules from there.
дек 06 19:54:00 pluer-NBD-WXX9 systemd[1]: Reached target local-fs.target - Local File Systems.
Вот причина задержки - система пытается проверить и использовать несуществующие уже разделы. Вы что-перемудрили с ними в процессе расширения.
Проверяйте /etc/fstab на наличие записей с неактуальным UUID (команда sudo blkid покажет актуально существующие) а после еще обновите initramfs - sudo update-initramfs -u
Особо подозрителными должны быть записи про 6d6be005-6606-4082-9fd5-23b934ede4b7 и 85af7e66-5dd7-40cc-983c-8a5105df29bc
pluer
07 дек 2024, 12:55
06 дек 2024, 22:03
В /etc/fstab UUID=85af7e66-5dd7-40cc-983c-8a5105df29bc none swap и UUID=6d6be005-6606-4082-9fd5-23b934ede4b7 none swap их можно удалить оттуда?
07 дек 2024, 13:24
Это вообще swap - такие можно удалять безболезненно при подозрениях, без swap система сразу не сломается в любом случае. Можно будет обратно добавить если там рабочий затесался.
А вообще - сверяйте через blkid. Если в выводе нету раздела с таким UUID как есть в fstab - то он там не нужен, ибо будет только тормозить загрузку.
pluer
07 дек 2024, 21:00
slant, спасибо большое! Время загрузки userspace значительно сократилось! Возможно как то уменьшить загрузку kernel?
Startup finished in 2.945s (firmware) + 4.058s (loader) + 33.402s (kernel) + 9.649s (userspace) = 50.056s
graphical.target reached after 9.622s in userspace.
07 дек 2024, 21:01
pluer писал(а):
07 дек 2024, 21:00
Собрать самому, чисто под свое железо
