Выделить больше оперативной памяти для iGPU
°Feijoada°
Благодарил (а): 4 раза
02 дек 2024, 14:28
ОС: Linux Mint 20.3 Una
  Kernel: 5.15.0-126-generic x86_64 bits: 64 compiler: N/A
  Desktop: Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una
  base: Ubuntu 20.04 focal
  Type: Laptop System: HP product: HP Laptop 17-cp0xxx v: N/A
  serial: <filter>
  Mobo: HP model: 88C6 v: 74.21 serial: <filter> UEFI: AMI v: F.13
  date: 11/24/2021
  ID-1: BAT0 charge: 37.6 Wh condition: 37.6/37.6 Wh (100%)
  model: Hewlett-Packard Primary status: Full
  Topology: 6-Core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
  type: MT MCP arch: Zen rev: 1 L2 cache: 3072 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 50309
  Speed: 1397 MHz min/max: 1400/2100 MHz Core speeds (MHz): 1: 1397 2: 1285
  3: 1423 4: 1437 5: 1396 6: 1448 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397
  12: 1397
  Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus ID: 03:00.0
  Display: x11 server: X.Org 1.20.13 driver: amdgpu,ati
  OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.0-126-generic LLVM 12.0.0)
  v: 4.6 Mesa 21.2.6 direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 03:00.1
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
  vendor: Hewlett-Packard Raven/Raven2/FireFlight/Renoir Processor
  driver: snd_rn_pci_acp3x v: kernel bus ID: 03:00.5
  Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 03:00.6
  Sound Server: ALSA v: k5.15.0-126-generic
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
  bus ID: 01:00.0
  Local Storage: total: 476.94 GiB used: 318.01 GiB (66.7%)
  ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNU512GZH size: 476.94 GiB
  ID-1: / size: 467.89 GiB used: 317.98 GiB (68.0%) fs: ext4
  dev: /dev/nvme0n1p2
  System Temperatures: cpu: 45.0 C mobo: 0.0 C gpu: amdgpu temp: 43 C
  Processes: 359 Uptime: 17h 57m Memory: 14.95 GiB used: 6.00 GiB (40.1%)
  Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
  inxi: 3.0.38
При игре в некоторые игры, в данном случае WarThander выскакивает ошибка Vulkan: out of memory, в багрепортной данной игры я нашёл тему с аналогичной ошибкой, где по словам техподдержки и автора удалось решить проблему с помощью увеличения объёма оперативной памяти выделенной iGPU где-то в биосе. Вопрос: как в моей системе сделать это?
Тема в багрепортной: https://community.gaijin.net/issues/p/w ... UWiX03jgdB (там другой Линукс, не знаю имеет ли это весомое значение в данной проблеме)
Скрин с ошибкой:
03 дек 2024, 01:25
°Feijoada° писал(а):
02 дек 2024, 14:28
Эта настройка не относится к системе, и находится там же - в BIOS/UEFI. Если есть (а может и не быть - у ноутбуков часто прошивка сильно упрощена в плане возможных настроек).
Кроме того, iGPU - а это процессор+видео от intel. Не ваш случай.
sheridan
Решено: 14
Благодарил (а): 900 раз
03 дек 2024, 08:40
°Feijoada°, уж очень древняя меса и ядро у тебя установлены, и еслив биосе стоит авто работа с памятью GPU, возможна не корректная работа с выделением памяти, где то читал в баг репортах что в новой месе это пофиксили и ядре соответственно
03 дек 2024, 08:50
sheridan писал(а):
03 дек 2024, 08:40
Так логично у него же
02 дек 2024, 14:28
Linux Mint 20.3 Una
Благодарил (а): 1225 раз
03 дек 2024, 09:46
02 дек 2024, 14:28
А если всё-таки ось поновее поставить? Или эту последовательно обновить хотя бы до 21.3. Больше пока не надо. 22 сырая ещё
°Feijoada°
03 дек 2024, 10:40
03 дек 2024, 01:25
Уже успел покопаться в биосе, там данной настройки не нашёл, возможно её реально нет(
sheridan писал(а):
03 дек 2024, 08:40
hellonet писал(а):
03 дек 2024, 09:46
Хорошо, обновлю, надеюсь это решит проблему
03 дек 2024, 12:06
°Feijoada°,
принтер HUAWEI PixLab X1 не заработал?
°Feijoada°
03 дек 2024, 12:17
нет, он заработал только с maca, для Линукса купили похожий аппарат от Brother (DCP-T420W)
03 дек 2024, 13:24
03 дек 2024, 12:17
Увы струйник нам не подходит - пользуемся принтером раз в месяц, и то не каждый месяц
03 дек 2024, 13:25
03 дек 2024, 10:40
Отпишись о результате. Интересно
°Feijoada°
15 дек 2024, 21:03
Сегодня пробовал играть на новом Линуксе (21.3) порядка 12 часов, стало ещё хуже - около 10 вылетов за это время, хотя раньше было не больше 5(
15 дек 2024, 21:21
15 дек 2024, 21:03
Было так:
А как сейчас? Какое ядро?
°Feijoada°
15 дек 2024, 21:32
hellonet писал(а):
15 дек 2024, 21:21
  Kernel: 5.15.0-126-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    base: Ubuntu 22.04 jammy
    serial: <superuser required>
  Mobo: HP model: 88C6 v: 74.21 serial: <superuser required> UEFI: AMI
    v: F.13 date: 11/24/2021
  ID-1: BAT0 charge: 36.5 Wh (100.0%) condition: 36.5/36.5 Wh (100.0%)
    volts: 12.7 min: 11.3 model: Hewlett-Packard Primary status: Full
  Info: 6-core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB L3: 8 MiB
  Speed (MHz): avg: 1692 high: 2776 min/max: 1400/2100 boost: enabled
    cores: 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 2175 8: 2776
    9: 1492 10: 1493 11: 2058 12: 1935 bogomips: 50308
    bus-ID: 03:00.0
  Device-2: Cheng Uei Precision Industry (Foxlink) HP True Vision HD Camera
    type: USB driver: uvcvideo bus-ID: 1-3:2
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
    unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
  OpenGL: renderer: RENOIR (renoir LLVM 15.0.7 DRM 3.42 5.15.0-126-generic)
    v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.3 direct render: Yes
    driver: snd_hda_intel v: kernel bus-ID: 03:00.1
    vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel bus-ID: 03:00.5
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 03:00.6
  Sound Server-1: ALSA v: k5.15.0-126-generic running: yes
    bus-ID: 01:00.0
  IF-ID-1: amn0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Bluetooth:
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 3-3:3
  Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
    bt-v: 2.1 lmp-v: 4.2
  Local Storage: total: 476.94 GiB used: 110.55 GiB (23.2%)
    temp: 31.9 C
  ID-1: / size: 467.89 GiB used: 110.52 GiB (23.6%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 511 MiB used: 28.9 MiB (5.7%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 3.2 MiB (0.2%) file: /swapfile
  System Temperatures: cpu: 53.0 C mobo: 0.0 C gpu: amdgpu temp: 51.0 C
  Processes: 352 Uptime: 4h 14m Memory: 14.95 GiB used: 4.05 GiB (27.1%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2194 Shell: Bash
  v: 5.1.16 inxi: 3.3.13[pre]
Кстати помимо vulcan out of memory была замечена новая ошибка:
pashgorr
15 дек 2024, 21:33
Попробуйте ---- sudo nano /etc/sysctl.conf -- Добавляем в конце vm.swappiness=5 --- сохраняем ---- перезагрузка.
Какой драйвер видео используется? Попробуйте все варианты.
Если не поможет попробуйте Mint 21.3 Xfce.
pashgorr
15 дек 2024, 21:35
15 дек 2024, 21:32
hellonet писал(а): ↑
11 минут назад
Да, и о том что говорил hellonet, новый --- inxi -Fxz
15 дек 2024, 21:50
°Feijoada°, и ещё, не смог найти на офсайте HP точную модель твоего ноутбука
serial: <filter>
date: 11/24/2021
Но есть после 2021 года обновление BIOS 2024 года
https://support.hp.com/kz-ru/drivers/hp ... ku=600C3U8
Если умеешь обновлять, то можно обновиться на свой страх и риск (Я тебе этого не говорил). Но нужно найти BIOS именно для твоей модели. Может даже для неё и нет обновления - надо поискать
16 дек 2024, 03:34
pashgorr писал(а):
15 дек 2024, 21:33
vm.swappiness=5 ...
Это влияет лишь на порог включения в работу файла подкачки по результатам измерений расхода оперативной памяти. Но где-то здесь на форуме читал реплику от slant, что 5% порог не является хорошей идеей.
А про Xfce раньше было актуально, теперь, после того как полностью перешли на GTK3, это уже устарело. По крайней мере, по результатам измерений по расходам памяти на LM22 Cinnamon и LM22 Xfce особенных отличий не увидел. Возможную разницу в 100-200 килобайт, полагаю, можно не учитывать. А с таким параметром ноутбука как Memory: 14.95 GiB вообще можно "забить" на разницу в DE. Тут проблема в чём-то другом.
16 дек 2024, 08:34
Вся проблема в том, что уже давно эта игра стала требовательна к видеокарте. У меня были такие же проблемы с картой RX 570 4GB. Уже года 3 как сменил ее на карту с количеством памяти больше. После смены карты все проблемы исчезли.
Если BIOS/UEFI ноутбука не позволяет увеличить количество памяти выделяемое интегрированной графике - хоть на голове стой ничего не поможет
pashgorr
16 дек 2024, 10:02
madesta писал(а):
16 дек 2024, 03:34
Я в игры не играю, но на одном из форумов (возможно здесь) вычитал о прожорливости по памяти современных игр, (отсюда и 5%) у меня лет 10 стоит такой параметр (у меня 8Gb) проблем не было, на счёт сравнения Cinnamon и Xface по расходу памяти, не знал), а °Feijoada° можно посоветовать мониторить потребление ресурсов во время игр, отрубить эффекты Cinnamon, Compiz, или по совету hellonet, попробовать обновить BIOS.
pashgorr
16 дек 2024, 10:15
В принципе речь идёт не только о потреблении ОЗУ, но и о потреблении видео памяти расположенной в ОЗУ рабочим окружением.
