при переключении экрана на 165 герц он желтеет и эфект старого телевизора
justshadownine
24 окт 2024, 19:02
NVIDIA Corporation TU116 [GeForce GTX 1650] менял драйвера (стало только хуже, система не видела монитора)
Kernel: 6.8.0-47-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
Desktop: Cinnamon v: 6.2.9 Distro: Linux Mint 22 Wilma
base: Ubuntu 24.04 noble
Type: Desktop System: ARDOR Gaming product: NEO M133 v: 2.0
serial: <superuser required>
Mobo: Micro-Star model: PRO H610M-E DDR4 (MS-7D48) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.A1
date: 05/16/2023
Info: quad core model: 12th Gen Intel Core i3-12100F bits: 64 type: MT MCP
arch: Alder Lake rev: 5 cache: L1: 320 KiB L2: 5 MiB L3: 12 MiB
Speed (MHz): avg: 2449 high: 4300 min/max: 800/4300 cores: 1: 802 2: 800
3: 4015 4: 3780 5: 800 6: 800 7: 4300 8: 4295 bogomips: 52838
Device-1: NVIDIA TU116 [GeForce GTX 1650] driver: N/A arch: Turing
bus-ID: 01:00.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting,nouveau,vesa unloaded: fbdev dri: swrast gpu: N/A
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: kms_swrast,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 24.0.9-0ubuntu0.2 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 17.0.6 256 bits)
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
API: ALSA v: k6.8.0-47-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter driver: mt7601u type: USB
bus-ID: 1-1:2
IF: wlx3c3300805d2c state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 18.75 GiB (3.9%)
ID-1: /dev/nvme0n1 vendor: Seagate model: XPG GAMMIX S50 Lite
size: 476.94 GiB temp: 41.9 C
ID-1: / size: 467.89 GiB used: 18.74 GiB (4.0%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 512 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 62.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.48 GiB used: 4.01 GiB (25.9%)
Processes: 287 Uptime: 16m Init: systemd target: graphical (5)
Packages: 1959 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Благодарил (а): 1223 раза
24 окт 2024, 19:17
justshadownine, посмотри здесь https://www.linux.org.ru/forum/general/17701768
ответ ТС поместил в первый пост
