Проблема с экранной заставкой
1o4ka
Благодарил (а): 23 раза
19 окт 2024, 18:38
Linux Mint 21.3 Virginia x86_64
$ inxi -Fxz
Kernel: 5.15.0-124-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F9 date: 08/11/2015
Info: dual core model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 3191 high: 3193 min/max: 800/3200 cores: 1: 3190
2: 3193 bogomips: 12771
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce GTX 750] vendor: Palit Microsystems
driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3
unloaded: fbdev,vesa gpu: nouveau resolution: 1920x1080~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 23.2.1-1ubuntu3.1~22.04.2
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Palit Microsystems driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-4: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.15.0-124-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-1:2
IF: wlxc46e1f210c3f state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 1.35 TiB used: 86.66 GiB (6.3%)
ID-1: /dev/sda vendor: TeamGroup model: T253480GB size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-3: /dev/sdc vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-1: / size: 91.11 GiB used: 48.38 GiB (53.1%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 569.9 MiB used: 31.4 MiB (5.5%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 332.16 GiB used: 38.25 GiB (11.5%) fs: ext4
dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/sdb5
System Temperatures: cpu: 51.0 C mobo: 27.8 C gpu: nouveau temp: 40.0 C
Processes: 234 Uptime: 7h 54m Memory: 15.51 GiB used: 4.4 GiB (28.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3000 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Как-то заметил, что на стационаре перестала запускаться экранная заставка. а вместе с ней и блокировка экрана. Пытался переставлять время запуска, никакого результата:
не гаснет экран.
Чего перед этим было? Обновления были. Ну, и ещё, Skype установил (из коробки), т.е. из Synaptica. Но, не думаю, что это - из-за Skypa.
После выхода из Спящего экрана блокировка сохраняется, а так - не срабатывает.
Подскажите, как решить проблему.
...bis dat qui cito dat
19 окт 2024, 18:50
Заставка не запускаетя потому, что этот запуск блокируется чем-то.
1o4ka писал(а):
19 окт 2024, 18:38
Запущенный скайп может блочить запуск заставки.
1o4ka
19 окт 2024, 18:54
19 окт 2024, 18:50
Для чистоты эксперимента Skype выключен. Обычно работает SMPlayer (радио из инета), но это никогда не мешало заставке срабатывать.
Как можно поискать, чего блочит заставку?
pashgorr
Благодарил (а): 4 раза
19 окт 2024, 23:25
Попробуйте, SMPlayer-Параметры-Настройки-Основные-Видео- галка подавить хранитель экрана.
1o4ka
20 окт 2024, 09:52
pashgorr писал(а):
19 окт 2024, 23:25
pashgorr, SMPlayer не мешает заставке срабатывать.
1o4ka
20 окт 2024, 10:54
Для чистоты эксперимента удалил Skype из системы. Заставка начала срабатывать. Получается, всему "виной" -- Skype. Остаётся вопрос: как его настроить, чтобы он не подавлял заставку?
После вторичной установки Skypa, как-то всё наладилось. Заставка начала срабатывать, экран гаснуть. Не готов сказать, почему, но всё устаканилось.
