Вопрос о некоторых функциях настроек Окна Входа В Систему Mint Mate 22.0
konstantin
Благодарил (а): 33 раза
29 сен 2024, 16:21
kostya@kostya-B550M-K:~$ inxi -Fxz
Kernel: 6.8.0-45-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
Desktop: MATE v: 1.26.2 Distro: Linux Mint 22 Wilma
base: Ubuntu 24.04 noble
Type: Desktop System: Gigabyte product: B550M K v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B550M K v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F2 date: 03/01/2023
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1789 high: 4115 min/max: 400/4464 cores: 1: 400 2: 400
3: 400 4: 400 5: 400 6: 2989 7: 400 8: 2994 9: 2990 10: 4115 11: 2993
12: 2994 bogomips: 93425
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3 bus-ID: 03:00.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
gpu: amdgpu resolution: 3840x2160~60Hz
API: EGL v: 1.5 drivers: radeonsi,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-0ubuntu0.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7600 (radeonsi navi33
LLVM 17.0.6 DRM 3.57 6.8.0-45-generic)
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 03:00.1
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 08:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 08:00.6
API: ALSA v: k6.8.0-45-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 21.58 GiB (1.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO with Heatsink 2TB
size: 1.82 TiB temp: 32.9 C
ID-1: / size: 154.78 GiB used: 12.21 GiB (7.9%) fs: ext4 dev: /dev/nvme0n1p1
ID-2: /boot/efi size: 476 MiB used: 6.1 MiB (1.3%) fs: vfat
dev: /dev/nvme0n1p4
ID-3: /home size: 457.28 GiB used: 9.36 GiB (2.0%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 38.2 C mobo: 30.0 C gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 62
Memory: total: 16 GiB available: 15.48 GiB used: 2.47 GiB (16.0%)
Processes: 326 Uptime: 4h 34m Init: systemd target: graphical (5)
Packages: 2284 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Попробовал по-подробнее настроить Окно Входа в Систему. По двум пунктам появились вопросы именно по теории. Прямо сразу никак в интернете не находится ответ на эту тему. А именно по таким настройкам :
1) Рисовать сетку . -- Для чего эта функция и когда её следует применять ?
2) Дополнительные изображения -- пункт "снизу слева" . -- Для чего эта функция и какие по размеру и по формату изображения подходят ? Когда это следует применять ?
( "Снизу слева" выбирал разные изображения по размеру и по формату (.png , .jpg) , но что-то изменилось в окне ввода пароля при входе в систему -- только с изображением из набора картинок-обоев для рабочего стола из этой версии Минт Мате -- просто снизу полоса около 2 - 3 сантиметров с фоном из этой картинки. Другие варианты ничего не дополняли и не меняли. )
29 сен 2024, 16:40
konstantin, в корице если задержать курсор на пункте, выскочит пояснение. В мяте этого разве нет?
ну и что мешает включить, посмотреть и выключить? :)
konstantin
29 сен 2024, 17:19
29 сен 2024, 16:40
Пояснения у меня такие есть , но они не дают ответ на вопросы , которые я имею. Вот эти два пояснения :
Вопросы мои в начале. Я ведь практически нажимая и подбирая разные изображения не выяснил. А по сетке -- что это , для какой цели , и когда применяется , для маломощных компютеров что-ли ?
29 сен 2024, 23:06
konstantin писал(а):
29 сен 2024, 17:19
На маломощных компьютерах такое включать не будут, поскольку там народ будет бороться за ресурсы, а не заниматься декором.
konstantin
30 сен 2024, 12:50
По пункту "Дополнительные изображения" -- " Снизу слева ".
- В каком формате должно быть изображение : .png , .jpg или .gif ?
- Какой размер или интервал размеров для применяемого изображения ?
Экспериментально у меня пока не получилось это определить .
Вернуться в «Mate»
