Kernel: 6.8.0-39-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
Desktop: MATE v: 1.26.2 Distro: Linux Mint 22 Wilma
base: Ubuntu 24.04 noble
Type: Desktop System: Gigabyte product: B550M K v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B550M K v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F2 date: 03/01/2023
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1123 high: 3691 min/max: 400/4464 cores: 1: 400 2: 3182
3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 3691 11: 3007 12: 400
bogomips: 93415
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3 bus-ID: 03:00.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
gpu: amdgpu resolution: 3840x2160~60Hz
API: EGL v: 1.5 drivers: radeonsi,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-0ubuntu0.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7600 (radeonsi navi33
LLVM 17.0.6 DRM 3.57 6.8.0-39-generic)
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 03:00.1
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 08:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 08:00.6
API: ALSA v: k6.8.0-39-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 174.6 GiB (9.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO with Heatsink 2TB
size: 1.82 TiB temp: 35.9 C
ID-1: / size: 154.78 GiB used: 14.31 GiB (9.2%) fs: ext4 dev: /dev/nvme0n1p1
ID-2: /boot/efi size: 952.1 MiB used: 6.1 MiB (0.6%) fs: vfat
dev: /dev/nvme0n1p4
ID-3: /home size: 640.99 GiB used: 160.28 GiB (25.0%) fs: ext4
dev: /dev/nvme0n1p2
Swap:
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 39.4 C mobo: 33.0 C gpu: amdgpu temp: 46.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 59
Memory: total: 16 GiB available: 15.48 GiB used: 2.65 GiB (17.1%)
Processes: 326 Uptime: 4h 15m Init: systemd target: graphical (5)
Packages: 2769 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
konstantin@bkl-B550M-K:~$
Несколько дней назад я пробовал перейти с Lightdm на gdm3 через Менеджер приложений.
Первым делом установил "Настройки GDM - Flatpak"и попробовал запустить , но окно настроек не появилось. Далее я установил gdm3 - Системный пакет. В появившемся окне, с вопросом о Дисплейном менеджере по умолчанию, выбрал gdm3 . Запустил программу "Настройки GDM" и убедился , что окно настроек открылось и программа работает.
Выключил компьютер и включил снова. После входа в систему в новом Дисплейном менеджере экран входа сменился на рабочий стол , который был подобие Ubuntu Gnome : ничего напоминающего Linux Mint не было. Только пустая верхняя панель с маленькой полоской в левом углу и в правом углу несколько иконок , при нажатии объединённых в одно для всех всплывающее окно (яркость экрана, звук, выключение). И была только возможность включать программы с помощью плиток как в Gnome 3 , но плитки никак не организованы - всё подряд вперемешку. Явно не Минтовские настройки не позволяли вернуться к Linux Mint. И что особенно удивило , то в настройках этих при выборе пункта "Рабочий стол Ubuntu" появлялось Опа! Что-то пошло не так.
Тогда я через sudo dpkg-reconfigure gdm3 в терминале сменил Дисплейный менеджер по умолчанию на Lightdm. При выборе было три варианта : GDM3 , gdm3 (он был выделен как активный) , lightdm. Вернул систему к виду Mint Mate. Удалил и "Настройки GDM - Flatpak" , и gdm3.
Но вот несколько дополнительных вопросов всё же есть.
1) Почему теперь после sudo dpkg-reconfigure lightdm в терминале в выборе по-прежнему есть GDM3 , lightdm ? У меня ведь нет установленного приложения GDM3 .
2) Пропали флаги России и США в трее меню раскладки клавиатуры , я делал их через программу dconf и они всегда были в трее , теперь вернулись буквы посимпатичнее чем были и размером побольше. Меня это устраивает , но для интереса почему-то никак флаги с помощью dconf не появляются.
3) По горячим следам посмотрел в Менеджере приложений на программу Plymouth и увидел текст "программу удалить не удалось". Скриншот прилагаю. Я ведь не пробовал удалять Plymouth . 4) При включении компьютера при входе в систему стало появляться очень кратковременно сообщение . Скриншот прилагаю. "Не удалось применить сохранённую конфигурацию мониторов"
Монитор у меня один. Поэтому я в настройках Экрана просто формально нажал "сделать основным монитором"--применить--ок . Сообщение больше не появляется.
Такой объёмный у меня вопрос получился.
Думаю вот не попробовать ли установить Дисплейный менеджер SDDM через Менеджер приложений . Но хочется разобраться с неудачей при попытке перейти на gdm3.
