System: Kernel: 6.8.0-38-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0 Desktop: Xfce v: 4.18.1 Distro: Linux Mint 22 Wilma base: Ubuntu 24.04 noble Machine: Type: Laptop System: LENOVO product: 82EY v: IdeaPad Gaming 3 15ARH05 serial: <superuser required> Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required> UEFI: LENOVO v: FCCN16WW date: 01/05/2021 Battery: ID-1: BAT0 charge: 35.7 Wh (100.0%) condition: 35.7/45.5 Wh (78.5%) volts: 12.7 min: 11.4 model: Sunwoda L19D3PF4 status: full CPU: Info: 6-core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB L3: 8 MiB Speed (MHz): avg: 1656 high: 3000 min/max: 1400/3000 boost: enabled cores: 1: 1397 2: 1396 3: 1397 4: 1397 5: 1397 6: 1400 7: 1558 8: 1400 9: 1448 10: 1400 11: 2683 12: 3000 bogomips: 71868 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo driver: nvidia v: 535.183.01 arch: Turing bus-ID: 01:00.0 Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 bus-ID: 05:00.0 temp: 41.0 C Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB bus-ID: 1-3:2 Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: amdgpu,nvidia unloaded: fbdev,modesetting,nouveau,vesa dri: radeonsi gpu: amdgpu resolution: 1920x1080~60Hz API: EGL Message: No EGL data available. API: OpenGL v: 4.6 vendor: amd mesa v: 24.0.9-0ubuntu0.1 glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir LLVM 17.0.6 DRM 3.57 6.8.0-38-generic) Audio: Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1 Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5 Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 05:00.6 API: ALSA v: k6.8.0-38-generic status: kernel-api Server-1: PipeWire v: 1.0.5 status: active Network: Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Lenovo RTL8111/8168/8411 driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0 IF: eno1 state: down mac: <filter> Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo driver: rtw_8822ce v: N/A port: 2000 bus-ID: 04:00.0 IF: wlp4s0 state: up mac: <filter> Bluetooth: Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB bus-ID: 3-3:3 Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1 lmp-v: 10 Drives: Local Storage: total: 476.94 GiB used: 13.1 GiB (2.7%) ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA512QFD size: 476.94 GiB temp: 39.9 C Partition: ID-1: / size: 13.65 GiB used: 9.77 GiB (71.6%) fs: ext4 dev: /dev/nvme0n1p6 ID-2: /boot/efi size: 96 MiB used: 31.4 MiB (32.7%) fs: vfat dev: /dev/nvme0n1p1 ID-3: /home size: 33.66 GiB used: 2.68 GiB (8.0%) fs: ext4 dev: /dev/nvme0n1p7 Swap: ID-1: swap-1 type: partition size: 7.45 GiB used: 639.7 MiB (8.4%) dev: /dev/nvme0n1p5 Sensors: System Temperatures: cpu: 50.4 C mobo: N/A gpu: amdgpu temp: 41.0 C Fan Speeds (rpm): N/A Info: Memory: total: 8 GiB note: est. available: 7.13 GiB used: 2.79 GiB (39.1%) Processes: 331 Uptime: 36m Init: systemd target: graphical (5) Packages: 1998 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Почему linux не переключается между видеокартами.
Автор темы - Сообщения: 292
- Решено: 4
Inxi -Fxz
задача стоит в том чтобы Linux Mint XFCE переключал автоматический видеокарту со встройки на дискретную. Несмотря на то что я установил драйвер Nvidia он не помог автоматизировать процесс переключения. Приходиться делать ручное переключение.
- Решено: 10
Нур, к сожалению тут есть проблема. Насколько я понял, переключение видеокарты на лету - тема завязанная на реализацию железа самим производителем.
И если производитель не заинтересован в том, чтобы это работало на Linux, то все грустно.
У самого ноутбук леново Legion 5. Так и не смог заставить работать переключение на Mint и еще паре систем клонов Ubuntu. Вроде как работала Manjaro. Но, поскольку я особо не играю, то забил на это.
Нур, можно заморочиться и настроить, но только на связке NVIDIA+INTEL. Для других связок нет софта
