Установка CoreCtrl
Leo
Установка CoreCtrl
31 авг 2024, 16:29
Хочу установить CoreCtrl при вводе команды пишет что такого пакета нет.
Помогите пожалуйста установить CoreCtrl
Построение дерева зависимостей… Готово
E: Невозможно найти пакет corectrl
Kernel: 6.10.7-x64v2-xanmod1 x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Type: Laptop System: ASUSTeK product: X75VC v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X75VC v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X75VC.201 date: 02/26/2013
Info: dual core model: Intel Core i5-3230M bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2555 high: 3200 min/max: 1200/3200 cores: 1: 3200
2: 2819 3: 3007 4: 1197 bogomips: 20753
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M]
vendor: ASUSTeK driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation Asus Webcam type: USB driver: uvcvideo
bus-ID: 1-1.3:4
unloaded: fbdev,vesa gpu: i915 resolution: 1600x900~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k6.10.7-x64v2-xanmod1 running: yes
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel bus-ID: 03:00.0
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK
driver: alx v: kernel port: d000 bus-ID: 04:00.0
Bluetooth:
Device-1: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter type: USB
driver: btusb v: 0.8 bus-ID: 1-1.1:3
bt-v: 2.1 lmp-v: 4.0
Local Storage: total: 465.76 GiB used: 60.24 GiB (12.9%)
ID-1: /dev/sda vendor: Hitachi model: HTS545050A7E380 size: 465.76 GiB
ID-1: / size: 93.31 GiB used: 60.21 GiB (64.5%) fs: ext4 dev: /dev/sda6
ID-2: /boot/efi size: 96 MiB used: 29.8 MiB (31.0%) fs: vfat
dev: /dev/sda2
Swap:
ID-1: swap-1 type: partition size: 10.63 GiB used: 0 KiB (0.0%)
dev: /dev/sda7
ID-2: swap-2 type: zram size: 1.86 GiB used: 57.5 MiB (3.0%)
dev: /dev/zram0
System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2500
Processes: 223 Uptime: 7m Memory: 3.72 GiB used: 2.49 GiB (66.9%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2821 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Решение madesta » 31 авг 2024, 16:46
Leo писал(а):
31 авг 2024, 16:29
установить CoreCtrl
Не оно? https://launchpad.net/~ernstp/+archive/ubuntu/mesarc
Установка CoreCtrl
31 авг 2024, 16:46
Leo писал(а):
31 авг 2024, 16:29
установить CoreCtrl
sheridan
Решено: 14
Благодарил (а): 900 раз
Установка CoreCtrl
31 авг 2024, 18:40
Leo, вот пробуй CoreCtrl
CoreCtrl GitLab
Установка CoreCtrl
31 авг 2024, 19:47
Leo писал(а):
31 авг 2024, 16:29
Все правильно - этого пакета нет в репозитории той версии системы, которая у тебя установлена. Этот пакет появился в репозитории ubuntu только начиная с версии 23.10. А у тебя система основана на Ubuntu 22.04. Обновись или установи Mint 23(основан на Ubuntu 24.04) тогда этот пакет будет в репозитории.
Если хочешь свежую версии - собери из исходников. Если свежая версия не сильно нужна - можешь подключить ppa(выше дали ссылку)
Вернуться в «Xfce»
