после обновления до 22 стал часто зависать при запуске
chiplun
10 авг 2024, 22:05
vladimir@vladimir-PLCSF:~$ inxi -Fxz
  Kernel: 6.8.0-40-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
  Desktop: Cinnamon v: 6.2.9 Distro: Linux Mint 22 Wilma
    base: Ubuntu 24.04 noble
  Type: Laptop System: TOSHIBA product: PLCSF v: xxxxxx-xxxxxx
    serial: <superuser required>
  Mobo: Type2 - Board Vendor Name1 model: Type2 - Board Product Name1
    v: Type2 - Board Version serial: <superuser required> UEFI-[Legacy]: Insyde
    v: 6.80 date: 10/01/2013
  ID-1: BAT0 charge: 38.5 Wh (100.0%) condition: 38.5/48.4 Wh (79.5%)
    volts: 11.8 min: 10.8 model: TKBSS NS2P3SZMC4WR status: full
  Info: dual core model: Intel Core i3-2370M bits: 64 type: MT MCP
    arch: Sandy Bridge rev: 7 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 989 high: 1134 min/max: 800/2400 cores: 1: 973 2: 926
    3: 925 4: 1134 bogomips: 19157
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    vendor: Toshiba driver: i915 v: kernel arch: Gen-6 bus-ID: 00:02.0
  Device-2: Chicony TOSHIBA Web Camera driver: uvcvideo type: USB
    bus-ID: 1-1.3:4
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915
    resolution: 1366x768~60Hz
  API: EGL v: 1.5 drivers: crocus,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland
  API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 24.0.9-0ubuntu0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB
    GT2)
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Toshiba 7
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  API: ALSA v: k6.8.0-40-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
  Device-1: Realtek RTL8723AE PCIe Wireless Network Adapter driver: rtl8723ae
    v: kernel port: 3000 bus-ID: 02:00.0
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Toshiba
    driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
  Local Storage: total: 465.76 GiB used: 33.73 GiB (7.2%)
  ID-1: /dev/sda vendor: Hitachi model: HTS547550A9E384 size: 465.76 GiB
  ID-1: / size: 456.88 GiB used: 33.72 GiB (7.4%) fs: ext4 dev: /dev/sda3
  ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
Swap:
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 4 GiB available: 3.72 GiB used: 1.82 GiB (48.9%)
  Processes: 228 Uptime: 7m Init: systemd target: graphical (5)
  Packages: 2328 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Здравстуйте !В линуксе я слабо разбираюсь и тут такая проблема , после обновления до линукс вилма ноут уже третий раз зависает при запуске на логотипе .приходится делать хард ресет после чего запускать по новой ,выбирать тип запуска ,идет что то типа прверки где все ок пишут .после чего ноут запускается и отчетах о системе пишут все нормально
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 12
Причина: bbcode
sveta13
Благодарил (а): 47 раз
10 авг 2024, 22:53
chiplun
Извини не поняла
(дура и народ это знает :sad:)
Ты сколько раз перезагружался после обновы до Wilma 22 и с какой обновлялся Virginia 21.3?
После обновы нормальный процесс грузит долго иногда просит reboot это не страшно :evil:, но если это постоянно происодит значит при обнове чтото пошло не так. Отпиши как и откуда обновлялся народ тут добрый, помогут. :smile:
Debian 12 xfce:LM-22.1 xfce:
chiplun
10 авг 2024, 23:09
обновлялся с верджинии 21.3 вручную через минт апгрейд .обновление длилось около 2х часов , перезагрузка была один раз . вроде все прямо встало никаких косяков вначале не было .теперь вот приходится постоянно жесткий сброс делать, чтоб запустить ось . уже подумываю на понижении версии и переходе на 21ю xfce c корицы. флешка есть .про диск пишет что исправен, но есть один сбойный сектор
Kernel: 6.8.0-40-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0 clocksource: tsc
Desktop: Cinnamon v: 6.2.9 tk: GTK v: 3.24.41 wm: Muffin v: 6.2.0 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22 Wilma base: Ubuntu 24.04 noble
Type: Laptop System: TOSHIBA product: PLCSF v: xxxxxx-xxxxxx serial: <superuser required>
Mobo: Type2 - Board Vendor Name1 model: Type2 - Board Product Name1 v: Type2 - Board Version
serial: <superuser required> part-nu: xxxxxx-xxxxxx UEFI-[Legacy]: Insyde v: 6.80
date: 10/01/2013
Info: dual core model: Intel Core i3-2370M bits: 64 type: MT MCP smt: enabled arch: Sandy Bridge
Speed (MHz): avg: 822 high: 894 min/max: 800/2400 cores: 1: 798 2: 798 3: 894 4: 798
bogomips: 19156
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Toshiba
driver: i915 v: kernel arch: Gen-6 ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: Chicony TOSHIBA Web Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 bus-ID: 1-1.3:4 chip-ID: 04f2:b303 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: modesetting
unloaded: fbdev,vesa dri: crocus gpu: i915 display-ID: :0 screens: 1
sveta13
11 авг 2024, 01:40
Тебя поняла такаяже Ж..., ну ты понял, пыталась так же обновление длилось долго и мучительно (девочки меня поймут :sad: ), плюнула и просто установила с оф сайта. У меня крыса (xfce) Debian тоже крыска, комп старенький, корица Cinnamon установи иэошку с оф сайта и всё у тебя будет норм. Удачи :thumbs:.
sveta13
11 авг 2024, 05:15
sveta13 писал(а):
11 авг 2024, 01:40
Или дождись как тут:
Что это?
11 авг 2024, 07:35
chiplun писал(а):
10 авг 2024, 23:09
А вот это как раз может быть причиной зависаний
chiplun
11 авг 2024, 08:42
ну на 21 образе замечаний не было .если и были тормоза то сами собой проходили. Попробую на xfce перейти .к тому же этому багу много лет он еще на винде у меня был .но не расширяется как опухоль а вполне стабилен. но ктож сможет понять что на душе у компьютера
11 авг 2024, 09:20
chiplun писал(а):
10 авг 2024, 23:09
1. Любые не постоянные зависания, тем более без логов - это в 95% случаев проблемы с железом. В вашем случае - начавшиеся вместе с апгрейдом - совпало.
2. Диск не может быть полностью исправным, если там уже есть сбойный сектор. Скорее всего там кроме него еще куча "кандидатов", а сам диск начал сыпаться - описанная картина хорошо совпадает с той, которая обычно бывает в подобных случаях. Даже апгрейд - как то, что спровоцировало обвал (большое количество random записи). Так то это нормально, но если диск уже был на грани - могло спровоцировать.
Сделайте вывод sudo smartctl -a /dev/sda (вместо sda подставьте ваш диск) и покажите. Это единственный адекватный способ быстро посмотреть реальное состояние диска. Всякие ".про" - это ни о чем.
chiplun
11 авг 2024, 09:45
как выбрать и вставить диск .где его искать не сердитесь мне седьмой десяток и напортачить с системой совсем не хочется, боязно как то. а на новый комп денег нет .ну может со времен на диск и смогу насобирать
11 авг 2024, 10:17
chiplun, покажи вывод
chiplun
11 авг 2024, 11:36
ну вот что выдало
=== START OF INFORMATION SECTION ===
Model Family:     Hitachi/HGST Travelstar 5K750
Device Model:     Hitachi HTS547550A9E384
Serial Number:    120408J2300050E5NP4A
LU WWN Device Id: 5 000cca 63bdec280
Firmware Version: JE3OA60B
User Capacity:    500 107 862 016 bytes [500 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        In smartctl database 7.3/5528
ATA Version is:   ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Sun Aug 11 11:34:43 2024 MSK
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(   45) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 129) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   062    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   040    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0007   182   182   033    Pre-fail  Always       -       1
  4 Start_Stop_Count        0x0012   091   091   000    Old_age   Always       -       15297
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       1
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   040    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0012   064   064   000    Old_age   Always       -       15832
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   091   091   000    Old_age   Always       -       14916
191 G-Sense_Error_Rate      0x000a   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       126
193 Load_Cycle_Count        0x0012   088   088   000    Old_age   Always       -       126289
194 Temperature_Celsius     0x0002   206   206   000    Old_age   Always       -       29 (Min/Max 14/51)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       1
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
223 Load_Retry_Count        0x000a   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
ATA Error Count: 1
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	SC = Sector Count Register [HEX]
	SN = Sector Number Register [HEX]
	CL = Cylinder Low Register [HEX]
	CH = Cylinder High Register [HEX]
	DH = Device/Head Register [HEX]
	DC = Device Command Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 1 occurred at disk power-on lifetime: 3276 hours (136 days + 12 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 00 60 9f 4c 03  Error: WP at LBA = 0x034c9f60 = 55353184
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  61 10 18 c0 1a f0 40 00      02:38:53.698  WRITE FPDMA QUEUED
  61 18 10 e0 60 30 40 00      02:38:53.451  WRITE FPDMA QUEUED
  61 01 00 60 09 fc 40 00      02:38:52.386  WRITE FPDMA QUEUED
  60 0a f0 88 0a 82 40 00      02:38:51.830  READ FPDMA QUEUED
  61 08 e8 a0 65 92 40 00      02:38:51.806  WRITE FPDMA QUEUED
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     15145         -
# 2  Short offline       Completed without error       00%     15005         -
# 3  Short offline       Completed without error       00%     14651         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 11
Причина: bbcode
11 авг 2024, 18:30
chiplun писал(а):
11 авг 2024, 11:36
ну вот что выдало
Что хорошо - диск таки не сыпется. Что плохо - серьезно выработан ресурс по количеству парковок головок. Это не приговор, но повод насторожиться. Когда ноут подвисает - попробуйте приложить ухо и послушать - нет ли регулярных шелчков с периодом - 1-5 секунд. Именно регулярных, с примерно равной периодичностью. Если есть - увы, таки диск (из парковки не выходит нормально).
chiplun
11 авг 2024, 19:31
сейчас ноут работает норм ,как только зависнет,обязательно проверю.а это вообще лечится,можно ли нам линукс как то отлючит эти парковки или как то по другому решить
11 авг 2024, 19:32
chiplun писал(а):
11 авг 2024, 19:31
Нет. Тут уже не помочь. Диск только под замену
chiplun
11 авг 2024, 19:41
плохо, но все равно спасибо
chiplun
11 авг 2024, 20:31
щелчки есть но редкие , а если рискнуть и поставить вместо корицы ,крыску может и зависания исчезнут вдруг там несовместимость ядер и железа .ведь то вильмы такого почти не было .
sheridan
Решено: 14
Благодарил (а): 900 раз
11 авг 2024, 20:51
chiplun, Если есть что ценное лучше сохранить как можно быстрей.
11 авг 2024, 23:02
chiplun писал(а):
11 авг 2024, 20:31
Редкие - это скорее всего именно оно.
chiplun писал(а):
11 авг 2024, 20:31
Скорее всего будет только хуже. Новой установкой только повысите износ - глючить будет больше. В прочем - хуже будет однозначно - вопрос только как быстро.
Когда винту плохеет - лечится это исключительно заменой оного целиком. Т.к. ремонт нерентабелен - обойдется в несколько раз дороже чем новый винт.
Программно это тоже не лечится. По аналогии - если у вас нога сломана, какой мазью ее не мажь - будет болеть при попытке ходить. Только винт еще и не заживает в принципе.
Благодарил (а): 1226 раз
12 авг 2024, 09:32
chiplun писал(а):
11 авг 2024, 19:41
Хороший повод вместо дорогого (в настоящее время) сдыхающего медленного устаревшего HDD диска установить быстрый современный сравнительно недорогой SSD диск
12 авг 2024, 09:39
hellonet писал(а):
12 авг 2024, 09:32
5400 ₽ офигеть. За такие деньжищи можно нормальный SSD купить
https://dsp-shop.ru/products/11854-zhes ... aii-25-hdd
Вот, чисто для примера, нормальный SSD на 480 гигов, более 12000 отзывов и всего за 4000 ₽
https://www.dns-shop.ru/product/d74ecd0 ... 00s37480g/
И скорость раз в 10 выше, можно сказать на порядок. Любая ось летать будет!
