Bluetooth Не видит ни каких устройств.
Colgra
04 авг 2024, 11:41
Доброго времени суток. Испытываю трудности в работе Bluetooth модуля Realtek RTL8761B (Buro BU-BT50C). Не видит ни каких устройств.
USB 00.1: 11500 Bluetooth Device
[Created at usb.122]
Unique ID: xnLL.huCbZCwfOy3
Parent ID: k4bc.tisqRJYDXEC
SysFS ID: /devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-4/1-4:1.1
SysFS BusID: 1-4:1.1
Hardware Class: bluetooth
Model: "Realtek Bluetooth Radio"
Hotplug: USB
Vendor: usb 0x0bda "Realtek Semiconductor Corp."
Device: usb 0x8771 "Bluetooth Radio"
Revision: "2.00"
Serial ID: "00E04C239987"
Driver: "btusb"
Driver Modules: "btusb"
Speed: 12 Mbps
Module Alias: "usb:v0BDAp8771d0200dcE0dsc01dp01icE0isc01ip01in01"
Driver Info #0:
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #7 (Hub)
Kernel: 5.15.0-117-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: B450M S2H serial: <superuser required>
UEFI: American Megatrends LLC. v: F63b date: 05/11/2022
Info: 6-core model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3
rev: 2 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 3003 high: 3656 min/max: 2200/3500 boost: enabled
cores: 1: 3563 2: 2874 3: 2583 4: 3569 5: 2525 6: 2283 7: 3578 8: 2875
9: 2966 10: 3656 11: 2831 12: 2738 bogomips: 84000
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Sapphire
driver: amdgpu v: kernel bus-ID: 0c:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa gpu: amdgpu resolution: 3440x1440
OpenGL: renderer: AMD Radeon RX 6600 (navi23 LLVM 15.0.7 DRM 3.42
5.15.0-117-generic)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 0c:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0e:00.4
Sound Server-1: ALSA v: k5.15.0-117-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:5
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 3.0 lmp-v: 5.1
Local Storage: total: 476.94 GiB used: 97.71 GiB (20.5%)
ID-1: /dev/nvme0n1 vendor: Seagate model: XPG GAMMIX S11 Pro
size: 476.94 GiB temp: 41.9 C
ID-1: / size: 467.89 GiB used: 97.71 GiB (20.9%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
System Temperatures: cpu: 16.8 C mobo: 16.8 C gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 394 Uptime: 1h 26m Memory: 15.53 GiB used: 3.94 GiB (25.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2413 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Подскажите как можно поправить ситуацию?
Дядя Миша
Благодарил (а): 121 раз
06 авг 2024, 12:56
Так драйвера надо установить. На этом чипе блютузины из коробки не работают в Минте, хоть и заявлена работоспособность, однако пока драйвера не установишь, устройства не видит. Дрова тут: https://github.com/mkopa/Linux-Driver-U ... CO-BTA-508
qwertKI
Благодарил (а): 87 раз
06 авг 2024, 20:40
нормально работающий bluetooth 5.0 и выше завезли только с 6.8.1 ядра , все ранее - не дозрело , на ubuntu 24 подобная проблема была хоть и ядро 6.8.0 , прикрутил 6.9.0 - зашелестело ...
