после обновления при установке vpn пропадает подключение к интернету
briz90
17 июл 2024, 09:19
LM 21.1 Vera x64
Kernel: 5.15.0-116-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: MATE 1.26.0 Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP ProBook 450 G5 v: N/A
serial: <superuser required>
Mobo: HP model: 837D v: KBC Version 02.41.00 serial: <superuser required>
UEFI: HP v: Q85 Ver. 01.23.00 date: 11/29/2022
ID-1: BAT0 charge: 35.4 Wh (97.3%) condition: 36.4/48.0 Wh (75.9%)
volts: 11.7 min: 11.4 model: Hewlett-Packard Primary status: N/A
Info: quad core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 800 min/max: 400/3400 cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 28800
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce 930MX] vendor: Hewlett-Packard
driver: nvidia v: 535.183.01 bus-ID: 01:00.0
Device-3: Lite-On HP HD Camera type: USB driver: uvcvideo bus-ID: 1-6:3
Display: x11 server: X.Org v: 1.21.1.4 driver: X:
loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa gpu: i915
resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.0-116-generic running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 03:00.0
Bluetooth:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-7:4
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 931.51 GiB used: 481.71 GiB (51.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-60Z10T0
ID-1: / size: 49.98 GiB used: 32.18 GiB (64.4%) fs: xfs dev: /dev/dm-2
mapped: centos-root
ID-2: /boot/efi size: 96 MiB used: 60.8 MiB (63.3%) fs: vfat
dev: /dev/sda2
ID-3: /home size: 741.66 GiB used: 449.47 GiB (60.6%) fs: xfs
dev: /dev/dm-1 mapped: centos-home
Swap:
ID-1: swap-1 type: partition size: 7.75 GiB used: 0 KiB (0.0%)
dev: /dev/dm-0 mapped: centos-swap
System Temperatures: cpu: 43.0 C pch: 39.5 C mobo: 41.0 C
Processes: 306 Uptime: 39m Memory: 7.64 GiB used: 3.77 GiB (49.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2547 Shell: Bash
v: 5.1.16 inxi: 3.3.13
после обновления 11.07.24 на ядро 5.15.0-113 при установке vpn на рабочий компьютер пропадает соединение с интернетом
где может быть проблема, подскажите, до этого все работало как часы
17 июл 2024, 09:33
briz90, да в чем угодно. Пока мы не знаем как у тебя происходит подключение к VPN, какой VPN ты используешь - ни чем не поможем. А еще лучше обратись к админу на работе - пусть посмотрит какие маршруты у тебя создаются
briz90
17 июл 2024, 10:14
админ к сожалению помочь не смог
vpn стандартный ppp
briz90
17 июл 2024, 10:18
сорри за количество скринов, не совсем пока разобралась, как вставлять картинки
17 июл 2024, 10:36
briz90 писал(а):
17 июл 2024, 10:18
Кнопка "Добавить файлы", расположенная ниже формы "Быстрый ответ"
briz90 писал(а):
17 июл 2024, 10:14
Стоит намекнуть начальству о его профпригодности
Покажи вывод
ip route
До подключения VPN и после подключения
briz90
17 июл 2024, 10:43
без vpn
ip route
default via 192.168.0.1 dev wlp3s0 proto dhcp metric 600
169.254.0.0/16 dev wlp3s0 scope link metric 1000
192.168.0.0/24 dev wlp3s0 proto kernel scope link src 192.168.0.13 metric 600
c установленым vpn
ip route
default dev ppp0 proto static scope link metric 50
188.186.140.11 via 192.168.0.1 dev wlp3s0 proto static metric 50
192.168.0.1 dev wlp3s0 proto static scope link metric 50
192.168.154.111 dev ppp0 proto kernel scope link src 192.168.154.103
192.168.154.111 dev ppp0 proto kernel scope link src 192.168.154.103 metric 50
17 июл 2024, 15:15
Возможно конфликт диапазонов адресов локалки и VPN. Один и тот же использовать пытается. Но это не точно, т.к. от масок зависит. Однако, если админ не заморачивался - у него теперь и локалка и сеть vpn на 192.168.0.0/16 что приводит к конфликту, и ничего не работает разумеется. Но это не точно. :)
P.S. Потому и рекомендуют настраивать сети vpn как 172.16.x.x а не 192.168.x.x Чтобы не путаться потом и пространства под ошибку меньше было.
briz90
17 июл 2024, 16:08
с этими адресами на прошлой неделе все работало, перестало после обновления моей системы
настройки сети никто не трогал
17 июл 2024, 16:37
"После этого" - еще не значит "В следствие этого".
briz90
17 июл 2024, 17:54
ну адрес впн остался тот же, как и оостальные настройки, с той стороны админ меня на тмг видит
только вот я инета не вижу
18 июл 2024, 02:18
briz90 писал(а):
17 июл 2024, 17:54
Если у вас без впн Интернет имеется, а с впн пропадает, то, вероятно, и ежу будет понятно, что впн дурно влияет на наличие у вас Интернет. Если ваш админ такой упёртый, то помогите себе сами: например, как вариант, перебейте свою домашнюю сеть со 192.168.x.x на 172.16.x.x Только с маской сети будьте внимательны.
18 июл 2024, 09:57
briz90 писал(а):
17 июл 2024, 10:43
Если не ошибаюсь, то 188.186.140.* это именно та подсеть, в которую пробрасывается VPN. Только вот прописан ли маршрут )))
Вангую, что нет. Пропишите маршрут с галочкой (использовать это соединение только для ресурсов в этой сети) и будет вам счастье
18 июл 2024, 15:29
188.186.140.11 – это JSC "ER-Telecom Holding" (по информации от 2ip.ru). Возможно, что это внешний IP-адрес организации. C VPN автор, насколько я понял, соединяется и доступ к ресурсам той внутренней сети имеет. Но вот терзают меня некие смутные сомнения, что в этом случае он на другие сайты Интернет хочет достучаться или через VPN, или обращается не к тем DNS, к которым следовало бы, или с маршрутами у него там каша. Странно, что админ не помог, типа "отвали, моя черешня, от меня пули вылетают".
В свою бытность меня за такую поддержку пользователей моментально бы расстреляли :gun:
Кстати, на втором скрине увидел отмеченное галочкой поле "Use L2TP...". М.б. автор какую информацию нужную нам недодал?
А вообще с микротиком было бы самое то: он и VPN нужный поднимет, и смаршрутизирует как надо, и пользователю не нужно в настройки своей сети лезть и VPN добавлять. Но, конечно, во-первых, его нужно иметь, а во-вторых, – знать что там сделать и как.
Вернуться в «Mate»
