Не могу устанавливать библиотеки для python
Dragar_1991
07 июл 2024, 21:51
Здравствуйте!
Недавно столкнулся с проблемой - не могу установить библиотеки для python через команду pip., выводит
 >>> pip install tqdm
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: tqdm in ./.local/lib/python3.10/site-packages (4.66.4)
WARNING: Error parsing dependencies of send2trash: Expected matching RIGHT_PARENTHESIS for LEFT_PARENTHESIS, after version specifier
    sys-platform (=="darwin") ; extra == 'objc'
WARNING: Error parsing dependencies of libtorrent: Invalid version: '2.0.5-build-libtorrent-rasterbar-qrM5vM-libtorrent-rasterbar-2.0.5-bindings-python'
Версия - Cinnamon 5.4.12
Вывод команды inxi -Fxz
Kernel: 5.15.0-41-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Laptop System: LENOVO product: 81D7 v: Lenovo ideapad 330-17AST
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0M26038WIN
serial: <superuser required> UEFI: LENOVO v: 8UCN09WW date: 07/27/2018
ID-1: BAT0 charge: 25.0 Wh (86.5%) condition: 28.9/34.2 Wh (84.6%)
volts: 8.4 min: 7.6 model: SMP L16M2PB1 status: Charging
Info: dual core model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64
type: MCP arch: Excavator rev: 0 cache: L1: 192 KiB L2: 2 MiB
Speed (MHz): avg: 3000 min/max: 1300/2600 boost: enabled cores: 1: 3000
2: 3000 bogomips: 10399
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
driver: amdgpu v: kernel bus-ID: 00:01.0
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile]
vendor: Lenovo driver: amdgpu v: kernel bus-ID: 01:00.0
Device-3: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-1.3:4
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1600x900~60Hz
OpenGL: renderer: STONEY (stoney LLVM 15.0.7 DRM 3.42 5.15.0-41-generic)
v: 4.5 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:01.1
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2
Sound Server-1: ALSA v: k5.15.0-41-generic running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel bus-ID: 02:00.0
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 1000 bus-ID: 03:00.0
IF-ID-1: docker0 state: down mac: <filter>
Bluetooth:
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-1.2:3
Report: hciconfig ID: hci0 rfk-id: 2 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 476.94 GiB used: 147.66 GiB (31.0%)
ID-1: /dev/sda vendor: Hikvision model: HS-SSD-E100 512G size: 476.94 GiB
ID-1: / size: 467.89 GiB used: 147.65 GiB (31.6%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 813.5 MiB (39.7%) file: /swapfile
System Temperatures: cpu: 66.8 C mobo: N/A
GPU: device: amdgpu temp: 65.0 C device: amdgpu temp: 66.0 C
Processes: 281 Uptime: 5h 9m Memory: 6.67 GiB used: 3.03 GiB (45.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3190 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Обновление системы с помощью apt-get не помогло.
Напишите пожалуйста, если знаете, как решить эту проблему
07 июл 2024, 22:07
Dragar_1991, используй виртуальное окружение
