Загрузка наскольких Систем через загрузчик Mint
medusa_l
20 июн 2024, 14:21
Информация о Системе
medusa@medusa-pc-O-E-M:~$ inxi -Fxz
Kernel: 6.5.0-41-generic x86_64 bits: 64 compiler: N/A
base: Ubuntu 22.04 jammy
Type: Desktop System: Gigabyte product: A520M K V2 v: -CF
serial: <superuser required>
Mobo: Gigabyte model: A520M K V2 v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: FA date: 08/08/2023
Info: 8-core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
rev: 2 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 2527 high: 3303 min/max: 2200/4850 boost: enabled
cores: 1: 2200 2: 2892 3: 2872 4: 2200 5: 2200 6: 2881 7: 2200 8: 2200
9: 2200 10: 2200 11: 2200 12: 2940 13: 3303 14: 2200 15: 2881 16: 2875
bogomips: 121377
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASRock
driver: amdgpu v: kernel bus-ID: 06:00.0
Device-2: Aveo Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa gpu: amdgpu
resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon RX 6600 (radeonsi navi23 LLVM 15.0.7 DRM
3.54 6.5.0-41-generic)
v: 4.6 Mesa 24.1.1 - kisak-mesa PPA direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 06:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 08:00.4
Device-3: Aveo Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2
Sound Server-1: ALSA v: k6.5.0-41-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 03:00.0
Local Storage: total: 2.26 TiB used: 28.07 GiB (1.2%)
ID-1: /dev/sda vendor: Kingston model: SA400S37240G size: 223.57 GiB
ID-2: /dev/sdb vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
ID-3: /dev/sdc vendor: Seagate model: ST2000DM008-2UB102 size: 1.82 TiB
ID-1: / size: 84.7 GiB used: 15.19 GiB (17.9%) fs: ext4 dev: /dev/sda3
ID-2: /boot size: 937.8 MiB used: 172.1 MiB (18.4%) fs: ext2
dev: /dev/sda2
ID-3: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sda1
ID-4: /home size: 102.11 GiB used: 12.71 GiB (12.4%) fs: ext4
dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 29.8 GiB used: 0 KiB (0.0%)
dev: /dev/sda5
System Temperatures: cpu: 51.0 C mobo: 32.0 C gpu: amdgpu temp: 39.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 370 Uptime: 7m Memory: 62.71 GiB used: 2.97 GiB (4.7%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3058 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Доброго времени суток. Есть вопрос к гуру - установлено 3 ОС: Linux Mint, Arch, Windows 10. Последний для отдыха, хоть и редко используется. Для обнаружения загрузчикам LM системы Windows никаких проблем не возникло. Но вот обнаруживать Arch он не хочет. В файле /etc/default/grub я добавил строку GRUB_DISABLE_OS_PROBER=false после чего в терминале: [bsudo update-grub][/b]. Это прекрасно сработало с Windows, но вот с Арчем - никак. Может кто пытался провернуть нечто подобное. Буду признателен любым рекомендациям. Спасибо.
Linux Mint 21.3 Cinnamon (x86-64) | Cinnamon - 6.0.4 | Ядро Linux - 6.5.0-28-generic | SSD 2Tb
20 июн 2024, 14:47
Поставьте rEFInd и не мучайтесь. Для подобных ситуаций - самое оно.
https://wiki.archlinux.org/title/REFInd ... %B8%D0%B9) - написано много, но на самом деле он может практически все что вам нужно делать полностью автоматически - и установленные системы находить, и грузить напрямую или цепочкой (запускать другой загрузчик). Даже legacy (BIOS) загрузчики для этого использовать может.
medusa_l
20 июн 2024, 15:42
20 июн 2024, 14:47
Спасибо за наводку. Сейчас займусь.
medusa_l
20 июн 2024, 17:35
Сделал. :thumbs:
Благодарил (а): 1228 раз
20 июн 2024, 19:30
medusa_l писал(а):
20 июн 2024, 17:35
Сделал
Отметь как решение для slant, кармы много не бывает
medusa_l
09 июл 2024, 13:32
hellonet писал(а):
20 июн 2024, 19:30
medusa_l писал(а):
20 июн 2024, 17:35
Сделал
Так я же вроде добавил + или что-то не то сделал?
09 июл 2024, 14:13
medusa_l писал(а):
09 июл 2024, 13:32
В правом верхнем углу поста slant должна быть дополнительная кнопочка - "отметить как решение"
Сейчас этот форум просматривают: Google [Bot] и 1 гость
