Проблема в игре Undecember, Proton, Steam, Linux Mint
BASS_not_Pushkin
Благодарил (а): 3 раза
15 июн 2024, 08:04
Linux Mint 21.3 Cinnamon
Процессор Ryzen 5600G
Материнская плата ASUS ROG STRIX B550-XE GAMING WIFI
Видеокарта ASRock AMD Radeon RX 6950 XT Phantom Gaming OC
Телевизор LED TCL 65C728 - подключен по hdmi к видеокарте
полный вывод inxi -Fxz
Kernel: 6.5.0-35-generic x86_64 bits: 64 compiler: N/A
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1401
date: 12/03/2020
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 2991 high: 2995 min/max: 400/4464 cores: 1: 2993
2: 2995 3: 2989 4: 2986 5: 2992 6: 2994 7: 2994 8: 2994 9: 2994 10: 2985
11: 2985 12: 2995 bogomips: 93435
Device-1: AMD vendor: ASRock driver: amdgpu v: 6.3.6 bus-ID: 03:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa gpu: amdgpu
resolution: 3840x2160~60Hz
OpenGL: renderer: AMD Radeon RX 6950 XT (navi21 LLVM 17.0.4 DRM 3.56
6.5.0-35-generic)
v: 4.6 Mesa 23.3.0-devel direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.6
Sound Server-1: ALSA v: k6.5.0-35-generic running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 07:00.0
IF: wlp7s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-5:3
bt-v: 3.0 lmp-v: 5.2
Local Storage: total: 1.82 TiB used: 169.71 GiB (9.1%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNVS500G size: 465.76 GiB
temp: 34.9 C
ID-2: /dev/nvme1n1 vendor: Kingston model: SNVS500G size: 465.76 GiB
temp: 31.9 C
ID-3: /dev/sda vendor: Toshiba model: HDWL110 size: 931.51 GiB
ID-1: / size: 426.87 GiB used: 51.77 GiB (12.1%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 486 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p2
Swap:
ID-1: swap-1 type: partition size: 30.52 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p1
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 438 Uptime: 42m Memory: 31.22 GiB used: 5.8 GiB (18.6%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2686 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Игра Undecember в Steam, установлена по кнопке установить в Steam, игра запускается и играется
НО есть проблема с отображением некоторых элементов: фон главного меню и некоторые элементы предпросмотра скиллов и скинов отображаются как "настроечная таблица телевизора" скриншоты прилагаю:
Большая часть остальных элементов игры отображается нормально
Версии steam и proton регулярно обновляются, проблема остаётся
Может кто подсказать как это исправить? может в префикс протона что-то доустановить или в параметрах запуска что-то указать?
Решение Kamikaze » 15 июн 2024, 12:30
BASS_not_Pushkin писал(а):
15 июн 2024, 08:04
Использовать Proton GE.
Kamikaze
Благодарил (а): 6 раз
15 июн 2024, 12:30
15 июн 2024, 08:04
BASS_not_Pushkin
15 июн 2024, 13:42
Спасибо, помогло!
Вернуться в «Игры»
