Перемонтирование SSD
Isemann
Благодарил (а): 2 раза
11 июн 2024, 15:14
SSD примрнтировался по пути корень/media/dan/SSD Samsung, а хочется примонтировать его по пути корень/home/SSD Samsung. Возможно ли это сделать? Если да то как?
Linux Mint 21.3 Virginia х64 Cinnamon
Kernel: 6.9.3-1-liquorix-amd64 x86_64 bits: 64 compiler: gcc v: 11.4.0
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME H510M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/27/2021
Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 1979 high: 4377 min/max: 800/4400 cores: 1: 4377
2: 4326 3: 4352 4: 4300 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800
12: 800 bogomips: 62208
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
v: 535.171.04 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~144Hz
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 535.171.04 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Sound Server-1: ALSA v: k6.9.3-1-liquorix-amd64 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
Local Storage: total: 1.59 TiB used: 743.35 GiB (45.6%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SWORDFISH size: 232.89 GiB
temp: 39.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
ID-3: /dev/sdb vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB
ID-1: / size: 93.31 GiB used: 22.33 GiB (23.9%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 486 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 117.43 GiB used: 40.07 GiB (34.1%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p4
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 56%
Processes: 362 Uptime: 6h 6m Memory: 15.46 GiB used: 5.02 GiB (32.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2944 Shell: Bash
v: 5.1.16 inxi: 3.3.13
11 июн 2024, 15:49
Возникает концептуальный вопрос как надо монтировать: при старте системы когда это внутренний носитель, по команде как подключаемый типа через usb, или же как внутренний, но подключаемый по отдельной команде. Если он как внутренний носитель, то, по-моему, это проще сделать через редактирование /etc/fstab И, на свой взгляд, в этом случае я бы папку data создавал как точку монтирования в домашнем каталоге, то есть в /home/dan/data. Если он как подключаемый через usb или внутренний, но подключаемый по отдельной команде, то реализация будет по-другому.
Isemann
11 июн 2024, 16:26
Хочу примонтировать как внутренний носитель /home/ssd
11 июн 2024, 16:38
Isemann писал(а):
11 июн 2024, 16:26
Тогда нужно править /etc/fstab - с указанием желаемого места куда монтировать (сначала создается пустой каталог в желаемом месте и уже он используется как точка монтирования в fstab). SSD оттуда будет монтироваться при загрузке, а уже смонтированный ssd не будет попадать в /media/dan/.. - там система цепляет найденные внешние носители.
Isemann
11 июн 2024, 17:18
11 июн 2024, 16:38
Isemann писал(а):
11 июн 2024, 16:26
Как это сделать?
11 июн 2024, 17:48
В текстовом редакторе, от имени root.
KOT040188
Благодарил (а): 11 раз
11 июн 2024, 20:57
Isemann писал(а):
11 июн 2024, 15:14
Лично я монтирую все диски именно туда. А оттуда делаю символьную ссылку в хомяк. Так гораздо удобнее, ссылку можно перемещать и переименовывать.
Хто ты гэткі?
11 июн 2024, 22:48
KOT040188 писал(а):
11 июн 2024, 20:57
Не слишком хорошая привычка, IMHO, т.к. в /media/<user>/<media_label_or_uuid> монтируются "внешние" устройства автоматически. Во первых - немного смесь ежа и ужа получается, а во вторых можно получить нежданчик, если имя/метка/uuid совпадет у ручного и автоматического устройства.
Лично я предпочитаю все, что лично прописываю в fstab - монтировать в /mnt/... А вот далее - да, тоже симлинки откуда надо. К сожалению, в редких случаях симлинк может не работать (например git к ним по особому относится). Тогда - "mount --bind" вместо симлинка.
KOT040188
12 июн 2024, 01:13
slant, имя никак не совпадёт, даю уникальное. Метка совпадёт и что, где она фигурирует???? А каким образом uuid может совпасть???? Куда лучше монтировать?
Хто ты гэткі?
Isemann1
12 июн 2024, 12:30
11 июн 2024, 17:48
Я автор темы. Добавил в fstab строку UUID=$#&@... /home/ssd default 0 3 перезагрузился и сисстема легла. Сейчас нахожусь в emergency mode с загрузочной флешки не запускается, видит только другую с LMDE.
12 июн 2024, 13:35
Isemann1 писал(а):
12 июн 2024, 12:30
default 0 3
Откуда вы взяли цифру 3? И, по-моему, надо было не default, а defaults.
Isemann1
12 июн 2024, 14:01
madesta писал(а):
12 июн 2024, 13:35
Isemann1 писал(а):
12 июн 2024, 12:30
default 0 3
На форуме убунту кто то писал какую строчку добавить.
12 июн 2024, 14:14
Я бы руководствовался официальной документацией, хотя бы даже этой.
