BTRFS первый щуп
BTRFS первый щуп
23 май 2024, 17:52
Итак. Имеем.
dja@dja-home:~$ inxi -Fxz
  Kernel: 5.15.0-107-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Console: pty pts/0
    Distro: Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy
  Type: Laptop System: ASUSTeK product: X541UVK v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X541UVK v: 1.0 serial: <superuser required> UEFI: American Megatrends
    v: X541UVK.308 date: 01/30/2018
  ID-1: BAT0 charge: 27.5 Wh (100.0%) condition: 27.5/34.6 Wh (79.5%) volts: 10.8 min: 10.8
    model: ASUSTeK ASUS Battery status: Not charging
  Info: dual core model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake rev: 3 cache:
    L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 2000 min/max: 400/2000 cores: 1: 2000 2: 2000 3: 2000 4: 2000
    bogomips: 15999
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915 v: kernel
    bus-ID: 00:02.0
  Device-2: NVIDIA GM108M [GeForce 920MX] vendor: ASUSTeK driver: nvidia v: 535.171.04
    bus-ID: 01:00.0
  Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-6:3
  Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.1 driver: X:
    loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa gpu: i915 tty: 238x57
    resolution: 1920x1080
  Message: GL data unavailable in console. Try -G --display
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 00:1f.3
  Sound Server-1: ALSA v: k5.15.0-107-generic running: yes
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel
    port: d000 bus-ID: 02:00.2
  IF: enp2s0f2 state: down mac: <filter>
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: AzureWave driver: rtl8723be
    v: kernel port: c000 bus-ID: 03:00.0
  Local Storage: total: 1.38 TiB used: 602.89 GiB (42.8%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
  ID-2: /dev/sdb model: SATA3 512GB SSD size: 476.94 GiB
  ID-1: / size: 200 GiB used: 6.48 GiB (3.2%) fs: btrfs dev: /dev/sdb3
  ID-2: /boot size: 4.89 GiB used: 370.1 MiB (7.4%) fs: ext2 dev: /dev/sdb2
  ID-3: /boot/efi size: 259.8 MiB used: 24.2 MiB (9.3%) fs: vfat dev: /dev/sdb1
  ID-4: /home size: 271.7 GiB used: 9.85 GiB (3.6%) fs: btrfs dev: /dev/sdb4
Swap:
  Alert: No swap data was found.
  System Temperatures: cpu: 57.0 C pch: 49.0 C mobo: N/A gpu: nvidia temp: 36 C
  Fan Speeds (RPM): cpu: 2800
  Processes: 248 Uptime: 0m Memory: 7.64 GiB used: 1.76 GiB (23.0%) Init: systemd runlevel: 5
  Compilers: gcc: 11.4.0 Packages: 2485 Shell: Bash v: 5.1.16 inxi: 3.3.13
dja@dja-home:/$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda      8:0    0 931,5G  0 disk
└─sda1   8:1    0 931,5G  0 part /mnt/hardD
sdb      8:16   0 476,9G  0 disk
├─sdb1   8:17   0   260M  0 part /boot/efi
├─sdb2   8:18   0     5G  0 part /boot
├─sdb3   8:19   0   200G  0 part /
└─sdb4   8:20   0 271,7G  0 part /home
hw-probe
Сначала (а вернее не сначала, а после того как включил wi-fi) была адская нагрузка на проц. Но с этим я разобрался (старая проблема). Остался один вопрос со свапом. Он не подключается при загрузке. Разумеется заглянул в systemctl status swapfile.swap куда меня посылали на простыне загрузки.
dja@dja-home:~$ systemctl status swapfile.swap
× swapfile.swap - /swapfile
     Loaded: loaded (/etc/fstab; generated)
     Active: failed (Result: exit-code) since Thu 2024-05-23 17:27:51 MSK; 3min 4s ago
       What: /swapfile
       Docs: man:fstab(5)
             man:systemd-fstab-generator(8)
        CPU: 3ms
мая 23 17:27:51 dja-home systemd[1]: Activating swap /swapfile...
мая 23 17:27:51 dja-home swapon[803]: swapon: /swapfile: не удалось выполнить swapon: Недопустимый аргумент
мая 23 17:27:51 dja-home systemd[1]: swapfile.swap: Swap process exited, code=exited, status=255/EXCEPTION
мая 23 17:27:51 dja-home systemd[1]: swapfile.swap: Failed with result 'exit-code'.
мая 23 17:27:51 dja-home systemd[1]: Failed to activate swap /swapfile.
Так же наткнулся на инфу, что свап в BTRFS какой-то особенный... Непонятно только почему тогда не создается этот особенный и прописывается в /etc/fstab... Ну да ладно.
sudo btrfs subvolume create /@swap
sudo mkdir /swap
sudo mount -o subvol=@swap /dev/sdb3 /swap
Но не тут-то было.
mount: /swap: сбой системного вызова mount(2): Нет такого файла или каталога.
Таки какие мои дальнейшие действия? :blink2: Или что я делаю не так? :fire:
BTRFS первый щуп
23 май 2024, 18:27
Dja, на btrfs не надо делать swap. Если используешь btrfs для swap надо использовать раздел
UPD:
▶ lsblk
sda           8:0    1   3,6T  0 disk
└─sda1        8:1    1   3,6T  0 part /mnt/data
sdb           8:16   1 223,6G  0 disk
├─sdb1        8:17   1    16M  0 part
└─sdb2        8:18   1 223,6G  0 part
sdc           8:32   1   3,6T  0 disk
└─sdc1        8:33   1   3,6T  0 part
sdd           8:48   1   192K  1 disk
└─sdd1        8:49   1 160,5K  1 part
nvme1n1     259:0    0 931,5G  0 disk
├─nvme1n1p1 259:1    0 915,5G  0 part
└─nvme1n1p2 259:2    0    16G  0 part [SWAP]
nvme0n1     259:3    0 953,9G  0 disk
├─nvme0n1p1 259:4    0   300M  0 part /boot/efi
├─nvme0n1p2 259:5    0 937,6G  0 part /var/log
│                                     /var/cache
│                                     /home
└─nvme0n1p3 259:6    0    16G  0 part [SWAP]
BTRFS первый щуп
23 май 2024, 22:43
23 май 2024, 18:27
Вот это в brtfs меня и отпугивает, так как сразу возникает вопрос "а сколько надо". С одной стороны, не хотелось бы, чтобы дисковое пространство простаивало, а с другой – опасения, что будет недостаточно. :pc2:
Благодарил (а): 1737 раз
BTRFS первый щуп
23 май 2024, 22:45
madesta, btrfs же умеет динамически разделы ворочать
Благодарил (а): 54 раза
BTRFS первый щуп
23 май 2024, 22:45
Dja писал(а):
23 май 2024, 17:52
swap-файл на btrfs. Такого делать не нужно, если не хочешь капитальный геморрой и потерю половины фич btrfs на которой такой файл создан (причем тех, которые являются главным смыслом ее использовать). И не надо говорить что файл, мол - удобнее. В случае btrfs выделение места под swap раздел - настолько же просто, и делается прямо на работающей системе. И даже в GUI. Btrfs тем и хороша в подобных случаях, что изменения ее размера проводятся online на смонтированном разделе. В отличии от ext и большинства прочего.
1. Запускаем gparted.
2. Берем хвост раздела btrfs и двигаем его к началу раздела (resize) - освобождаем столько места, сколько нам под swap надо.
3. Создаем на освобожденном месте swap.
4. Подтверждаем операции.
5. Готово! Можно юзать новый свап.
Все делается даже без перезагрузок. Операция resize для нее настолько же безопасна как и простая запись файла - механизм COW и там работает.
P.S. Потенциальная проблема одна - btrfs позволяет менять раздел двигая хвост. Начало двигать после создания раздела нельзя. Зато можно объединить два куска пространства (раздела) разделенных на диске чем то еще между ними в одно большое (единую FS) - как JBOD (можно и на разных дисках, но там уже raid выгоднее будет). И тоже на лету. И убрать потом один из кусков тоже можно (если на оставшихся хватает места для данных - перенос будет выполнен автоматически в процессе исключения).
BTRFS первый щуп
24 май 2024, 08:26
madesta, делаешь 2x от объема ОЗУ - всегда точно хватит. А на счет простаивать - сейчас диски такого объема что пофиг простаивает 10ГБ или нет
Благодарил (а): 1236 раз
BTRFS первый щуп
24 май 2024, 10:28
24 май 2024, 08:26
А если оперативки 128 гигов?
BTRFS первый щуп
24 май 2024, 10:37
hellonet писал(а):
24 май 2024, 10:28
Swap все равно нужен, а дальше уже думай будешь ли ты использовать сон/гибернацию или нет
Думать головой никто не отменял. К тому же если поступил правильно и сделал swap-раздел после btrfs раздела, то изменить размер swap не доставит проблем
BTRFS первый щуп
24 май 2024, 11:31
По снапам. Если я правильно понял, то смысла в хранении кучи снапов перед и после апта или сделанных по времени - нет. По сути же мы создаем точку возврата. А зачем нам их несколько?
Потому сделал по паре скриптов
Запустить перед и после - не проблема! :vic:
upd. к sudo mkdir добавлю -p. а то ругаться будет.
upd. оу... и вместо mkdir mount написал ) тоже исправил
BTRFS первый щуп
24 май 2024, 11:32
Dja писал(а):
24 май 2024, 11:31
а чего б нет, если хранятся лишь изменения?
BTRFS первый щуп
24 май 2024, 11:34
WWolf, ну это как со скринами или фотками на смарте... львиная доля скринов уже не нужна, но они есть :-D да и фотки порой сделаны лишь для того чтобы их просто переслать или показать однократно, а потом они тоже не нужны. но лежат :-D Надо следить за чистотой!
KOT040188
Благодарил (а): 11 раз
BTRFS первый щуп
25 май 2024, 05:20
Года три на бтрфс. Полет нормальный, свап естественно на разделе в размере оперативки для гибернации. Плюс офигенская плюшка бтрфс снимки при каждой установке/удалении/обновлении и восстановление через grub. На опенсуст это было автоматом, здесь пришлось ручками настроить.
Хто ты гэткі?
BTRFS первый щуп
25 май 2024, 15:30
Dja писал(а):
24 май 2024, 11:31
Просто потому что создание снимка btrfs - очень легкая операция. И мгновенная. А места снимок не занимает. Занимает место исключительно различие в данных между двумя субтомами (снимок тоже равноправный субтом). Обратной стороной является то, что снимок != бекап. Физической дубликации всех данных нету. Потому снимки - это контрольная точка состояния FS, но совсем не защита от аппаратных сбоев. Бекапа на другое устройство они не заменяют.
Но именно по этому - можно десятки левых снимков иметь, и особенно их даже не замечать, т.к. места почти не тратится в большинстве случаев, и быстродействие тоже не страдает (что происходит в случае LVM снимков).
А так - да, иметь кучу лишних снимков совсем не обязательно. :)
BTRFS первый щуп
27 май 2024, 17:14
kosmos-454545 писал(а):
29 май 2019, 17:21
space_cache
А у меня с этим не грузится, кстати )
Вот еще наткнулся
Чет не нравится эта опция :hoho:
BTRFS первый щуп
07 июн 2024, 11:39
Dja писал(а):
24 май 2024, 11:31
В итоге всё равно руками проще. Ведь before недостаточно бывает. Мало ли чего дописать надо, особенно когда экспериментируешь с чем-то :joke:
