Проблемы с Audacity
Leo
Проблемы с Audacity
21 май 2024, 13:15
Всем привет, прошу помочь мне с решением вопроса.
Kernel: 5.15.0-107-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Type: Laptop System: ASUSTeK product: X75VC v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X75VC v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X75VC.201 date: 02/26/2013
Info: dual core model: Intel Core i5-3230M bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1197 min/max: 1200/3200 cores: 1: 1197 2: 1197 3: 1197
4: 1197 bogomips: 20753
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M]
vendor: ASUSTeK driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation Asus Webcam type: USB driver: uvcvideo
bus-ID: 1-1.3:4
unloaded: fbdev,vesa gpu: i915 resolution: 1600x900~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.15.0-107-generic running: yes
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel bus-ID: 03:00.0
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK
driver: alx v: kernel port: d000 bus-ID: 04:00.0
Bluetooth:
Device-1: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter type: USB
driver: btusb v: 0.8 bus-ID: 1-1.1:5
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.0
Local Storage: total: 465.76 GiB used: 25.27 GiB (5.4%)
ID-1: /dev/sda vendor: Hitachi model: HTS545050A7E380 size: 465.76 GiB
ID-1: / size: 93.31 GiB used: 25.01 GiB (26.8%) fs: ext4 dev: /dev/sda6
ID-2: /boot/efi size: 96 MiB used: 29.8 MiB (31.0%) fs: vfat
dev: /dev/sda2
Swap:
ID-1: swap-1 type: partition size: 10.63 GiB used: 233.6 MiB (2.1%)
dev: /dev/sda7
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2100
Processes: 234 Uptime: 34m Memory: 3.71 GiB used: 2.65 GiB (71.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2473 Shell: Bash
v: 5.1.16 inxi: 3.3.13
В Audacity есть несколько устройств записи:
- HDA Intel PCH: ALC269VB ANALOG (hw:0,0)
- sysdefault
- samplrate
- speexrate
- pulse
- upmix
- vdownmix
- default
Хочу записать гитару + бас гитару с пульта
Вход на пульте называется "Tape out" тюльпаны, вход на ноутбуке Aux
На всех устройствах записи, кроме трех последних, пишется звук со встроенноого микрофона.
При выставлении трех последних Audacity просто вылетает при попытке записи вот с такой ошибкой:
Ошибка сегментирования (образ памяти сброшен на диск)
Задача записать гитару через пульт.
Прошу помочь
Проблемы с Audacity
21 май 2024, 13:23
Leo, этот разъем на ноуте совмещенный там микрофон и наушники. Тебе нужна внешняя звуковая карта с линейным входом
Leo
Проблемы с Audacity
21 май 2024, 13:26
21 май 2024, 13:23
Которая будет через USB подключаться ?
Просто почему запрос составил потому что Отец раньше с этого ноута через этот же вход записывал синтезатор.
Проблемы с Audacity
21 май 2024, 13:40
Leo писал(а):
21 май 2024, 13:26
На ноуте больше некуда подключить
Leo писал(а):
21 май 2024, 13:26
Или кто-то лукавит, или кто-то чего-то не знает.
Проблемы с Audacity
21 май 2024, 13:45
я, конечно, не знаток в этой области. Но я бы подключил гарнитуру... открыл pavucontrol и смотрел бы в устройствах ввода какие дергаются когда говорю в микрофон.
Проблемы с Audacity
21 май 2024, 14:03
Нужно в pulseaudio/pipewire переключить устройство записи - вход с микрофона на LineIn / AUX. Не в Audacity (а в нем - оставить один из первых источников, которые сейчас с микрофона пишут).
Т.к. в ноутбуке железо не профессионального класса, писать оно может только с одного источника одновременно. Коммутация/микширование оного идет раньше редактора, в софт-микшерах - через PipeWire или PulseAudio.
Leo
Проблемы с Audacity
21 май 2024, 14:31
21 май 2024, 14:03
В "устройства ввода" один только микрофон
Leo
Проблемы с Audacity
21 май 2024, 14:36
21 май 2024, 14:03
Pipewire не получается установить (
sudo apt install pipewire pipewire-audio-client-libraries
Построение дерева зависимостей… Готово
Некоторые пакеты не могут быть установлены. Возможно, то, что вы просите,
неосуществимо, или же вы используете нестабильную версию дистрибутива, где
запрошенные вами пакеты ещё не созданы или были удалены из Incoming.
Следующая информация, возможно, вам поможет:
Следующие пакеты имеют неудовлетворённые зависимости:
pipewire : Зависит: libpipewire-0.3-modules (= 1.0.3-2~ubuntu22.04) но он не будет установлен
Зависит: pipewire-bin (= 1.0.3-2~ubuntu22.04)
E: Невозможно исправить ошибки: у вас зафиксированы сломанные пакеты.
Проблемы с Audacity
21 май 2024, 14:38
У меня вот при отключенной гарнитуре
При подключенной
Проблемы с Audacity
21 май 2024, 14:49
Тут я уже особо не смогу помочь с подробностями т.к. у меня другая система (manjaro), но попробуйте посмотреть на вкладке "Конфигурация" - там скорее всего есть профили. Среди них будут варианты как используются входы/выходы на гнездах звуковой карты.
У почти всех современных звуковых карт за исключением совсем уж хай-энд класса эти гнезда - меняют назначение программно, через драйвер. Скажем, у карты три гнезда - для использования акустики 5.1 будут задействованы на выход все три. А для подключения гарнитуры - одно будет выходом а второе входом. Но на выход будет работать только одно, и 5.1 в этом случае недоступно. И т.д.
Немного нелогично, но активный вход для записи (микрофон или LineIn) нужно переключать тоже там - смотрите какие там есть профили и выбирайте тот, где указан не Mic а Line In
Кроме того, возможно в вашем случае переключение входа нужно делать на еще более низком уровне. Это через alsamixer - консольная команда запустит интерфейс с псевдографикой. Причем там еще через F6 нужно выбрать вашу карту из списка, т.к. по умолчанию может быть показан виртуальный общий канал.
Вернуться в «Xfce»
