Проблема с телевизором по hdmi
BASS_not_Pushkin
Благодарил (а): 3 раза
29 апр 2024, 11:31
Linux Mint 21.3 Cinnamon
Процессор Ryzen 5600G
Материнская плата ASUS ROG STRIX B550-XE GAMING WIFI
Видеокарта ASRock AMD Radeon RX 6950 XT Phantom Gaming OC
Телевизор LED TCL 65C728 - подключен по hdmi к видеокарте
полный вывод inxi -Fxz
  Kernel: 5.15.0-105-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    base: Ubuntu 22.04 jammy
  Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
  Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 1401
    date: 12/03/2020
  Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
  Speed (MHz): avg: 2593 high: 2994 min/max: 1400/3900 boost: enabled
    cores: 1: 2392 2: 2993 3: 2992 4: 2394 5: 2394 6: 2393 7: 2395 8: 2991
    9: 2994 10: 2393 11: 2393 12: 2395 bogomips: 93418
  Device-1: AMD vendor: ASRock driver: amdgpu v: 6.3.6 bus-ID: 03:00.0
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
    unloaded: fbdev,modesetting,radeon,vesa gpu: amdgpu
    resolution: 3840x2160~60Hz
  OpenGL: renderer: AMD Radeon RX 6950 XT (navi21 LLVM 17.0.4 DRM 3.56
  5.15.0-105-generic)
    v: 4.6 Mesa 23.3.0-devel direct render: Yes
  Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
    driver: snd_hda_intel v: kernel bus-ID: 03:00.1
  Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 0a:00.6
  Sound Server-1: ALSA v: k5.15.0-105-generic running: yes
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 07:00.0
  IF: wlp7s0 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    port: N/A bus-ID: 08:00.0
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-5:3
    bt-v: 3.0 lmp-v: 5.2
  Local Storage: total: 1.82 TiB used: 203.46 GiB (10.9%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SNVS500G size: 465.76 GiB
    temp: 38.9 C
  ID-2: /dev/nvme1n1 vendor: Kingston model: SNVS500G size: 465.76 GiB
    temp: 34.9 C
  ID-3: /dev/sda vendor: Toshiba model: HDWL110 size: 931.51 GiB
  ID-1: / size: 426.87 GiB used: 46.68 GiB (10.9%) fs: ext4
    dev: /dev/nvme0n1p3
  ID-2: /boot/efi size: 486 MiB used: 6.1 MiB (1.2%) fs: vfat
    dev: /dev/nvme0n1p2
Swap:
  ID-1: swap-1 type: partition size: 30.52 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p1
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 54.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 446 Uptime: 5h 4m Memory: 31.23 GiB used: 8.17 GiB (26.2%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2659 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
При включении ПК на телевизоре появляется POST, затем загрузка операционной системы, затем изображения на телевизоре нет(пишет нет сигнала), но если его выключить и снова включить изображение появляется и не пропадает до перезагрузки ПК.
Может кто подсказать что и как донастроить что бы изображение не пропадало?
Решение WWolf » 02 май 2024, 16:07
BASS_not_Pushkin, попробуй ядро 6.5 установить, может поможет...
29 апр 2024, 16:01
У меня похожая ситуация с мини-ПК. Если он не включается больше какого-то времени (примерно часов 6-8), то после нажатия кнопки "Вкл." подсоединённый через HDMI ТВ говорит, что нет сигнала. Если вынуть из гнезда провод от БП или отключить БП от 220 В, а через секунд 5-10 вернуть "как было", то всё становится нормально. Идей о причинах такого поведения не имеется.
29 апр 2024, 17:49
BASS_not_Pushkin писал(а):
29 апр 2024, 11:31
Кого его ?
POST обычно обозначает проверку и инициализацию железа (ИМХО). Возможно причина в очерёдности инициализации.
BASS_not_Pushkin
29 апр 2024, 18:03
29 апр 2024, 17:49
29 апр 2024, 11:31
Кого его ?
Извините, если не ясно выразился, постараюсь описать подробнее:
1. включаю ПК
2. вижу на экране телевизора POST, проходит нормально
3. вижу на экране телевизора загрузку Linux Mint (консоль с бегущими строками)
4. вижу на экране нет сигнала
5. выключаю телевизор
6. включаю телевизор, вижу нормальное изображение рабочего стола, и больше сигнал не пропадает
есть подозрение что это связано с тем, что в дайвере амд нет поддержки 4к 120гц, а максимальное разрешение телевизра 4к 120гц (на windows 10 такой режим был доступен, на linux mint максимум 4к 60гц)
sasha300
Решено: 6
Благодарил (а): 107 раз
29 апр 2024, 20:22
29 апр 2024, 11:31
Была похожая проблема, причиной оказался дохлый переходник, у меня даже фотка осталась (слева виновник), так как возвращал:
29 апр 2024, 20:44
29 апр 2024, 18:03
есть подозрение
XRandR не пробовали применять, чтобы принудительно выставлялся нужный режим из списка поддерживаемых?
ilikethat
Решено: 10
Благодарил (а): 129 раз
30 апр 2024, 01:33
BASS_not_Pushkin,
1)В какой порт втыкаете? Если правильно понял, на телеке 2 порта( HDMI 2.1\4k@120) и 2 порта ( HDMI 1.4\4k@60)
2)Кабель HDMI менять не пробывали?
В обеих случаях симптомы будут похожи, загрузка идет либо в меньшем разрешении, либо 4к@60.
А как только заработает драйвер - попытается установить 4к@120 и начинаются проблемы. Либо порт не понимает такое, либо кабель не может пропустить.
Включени\ выключение телека, или выдергивание\вставка кабеля приводят к пере-согласованию устройств на общий знаменатель 4k@60.
BASS_not_Pushkin
30 апр 2024, 06:00
madesta писал(а):
29 апр 2024, 20:44
29 апр 2024, 18:03
есть подозрение
Попробовал xrandr, выставил 3840х2160_120.00, получилось всё равно 60гц и проблема осталась...
BASS_not_Pushkin
30 апр 2024, 06:03
ilikethat писал(а):
30 апр 2024, 01:33
BASS_not_Pushkin,
1) проверил порт, подключено в HDMI 2.1\4k@120
2) не пробовал, другого кабеля нет, но недавно на этом же пк стояла windows 10 подключение было к этому же телевизору, тем же кабелем, в тот же порт, и режим 4к 120 гц был и работал
ilikethat
Решено: 10
02 май 2024, 10:47
Вот табличка пропускной способности HDMI
Как видно при 4k 120 Герц, пропускная способность гуляет в 2 раза. От 18 Гбит\с до 40 Гбит\с.
И чтобы все работало, нужно, чтобы и видеокарта и кабель и порт телевизора могли поддерживать эту скорость.
Можно предположить, что видеокарта выдает такую скорость сигнала, что либо кабель, либо порт не могут его принять.
Как это починить не знаю. Навскидку
1)задать кодировку цветности через настройки драйвера AMD
2)попробывать поменять кабель на более дорогой
3)Покопаться в настройках телека. Вкл\выкл HDR и тому подобное. Включить режим РС, если он есть.
4)Обратится в форум по Вашей модели телевизора https://4pda.to/forum/index.php?showtop ... y112347181
5)Обратится в тех поддержку TCL
:hi3:
02 май 2024, 12:33
ilikethat писал(а):
02 май 2024, 10:47
Навскидку
Как мне видится, следует сначала попробовать п.1, так как кабель и пункт 3 можно во внимание пока что не принимать по причине того, что, по словам автора, на Windows проблема отсутствует.
BASS_not_Pushkin
02 май 2024, 15:51
ilikethat писал(а):
02 май 2024, 10:47
:hi3:
1) Не подскажите как и чем это делать? (в гуглении я плох и ничего путного не нашёл...)
2) С виндой ведь кабель работал на 4к 120Гц...да и так не дешёвый кабель(и сечение наибольшее и контакты типа позолочены и отзывы хорошие были), единственное он hdmi-hdmi, может кабель hdmi-DispleyPort лучше будет? К тому же не удаётся задать больше чем 4к 60Гц, в настройках отсутствуют и через xrandr тоже (задаёшь 3840х2160_120.00, получаешь 4к 60Гц)
3) В настройках телека копался, единственное что нашёл когда сигнал пропадает вместо перезапуска телевизора, может помочь включить VRR - выключить VRR, но это опять же каждый раз делать надо
4) и 5) в телевизоре ли дело? с виндой ведь работало, и обычно режимы он без проблем переключает (например при запуске игр с другим разрешением экрана и частотой) это и на винде и на linux mint работает, только при старте ПК проблема...
02 май 2024, 16:07
ilikethat
Решено: 10
02 май 2024, 18:52
BASS_not_Pushkin, так в том то и дело, что непонятно, какой режим пропускной способности используется в винде. Может windows знает этот телевизор в лицо :joke:
и работает в таком режиме который точно понимает телек. А драйвер от амд хочет сделать как лучше :smile:, а получается как всегда.
ИМНО нужно копать в сторону глубины цвета.
ilikethat
Решено: 10
02 май 2024, 18:53
02 май 2024, 16:07
Кстати хорошая идея. Я бы еще и mesa обновил.
BASS_not_Pushkin
03 май 2024, 13:24
ilikethat писал(а):
02 май 2024, 18:53
02 май 2024, 16:07
mesa оказалась уже самая свежая
а вот обновление ядра помогло!
Спасибо за советы!
BASS_not_Pushkin
03 май 2024, 13:26
02 май 2024, 16:07
Спасибо!
с версией 6.5 проблема исчезла!
Вернуться в «Видеокарты»
