Ubuntu 24.04
qwertKI
Благодарил (а): 87 раз
Ubuntu 24.04
25 апр 2024, 18:43
... релиз состоялся https://releases.ubuntu.com/24.04/ с 23.10 нормально обновилось , ожидаемых траблов не было , стало :
qwert@qwert-PC:~$ inxi -Fxz
Kernel: 6.8.0-31-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
Desktop: GNOME v: 46.0 Distro: Ubuntu 24.04 LTS (Noble Numbat)
Type: Desktop System: Dell product: OptiPlex 9020 v: 01
serial: <superuser required>
Mobo: Dell model: 06X1TJ v: A00 serial: <superuser required> BIOS: Dell
v: A08 date: 09/01/2014
Info: quad core model: Intel Core i7-4790 bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 3371 high: 3909 min/max: 800/4000 cores: 1: 3592 2: 3858
3: 3592 4: 3909 5: 3243 6: 1200 7: 3692 8: 3885 bogomips: 57465
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Dell driver: i915 v: kernel arch: Gen-7.5 bus-ID: 00:02.0
Display: wayland server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: dri: crocus gpu: i915
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: crocus,swrast platforms:
active: wayland,x11,surfaceless,device inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-1ubuntu1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
GT2)
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell 8
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
API: ALSA v: k6.8.0-31-generic status: kernel-api
Server-1: sndiod v: N/A status: active
Server-2: PipeWire v: 1.0.5 status: active
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB bus-ID: 2-1.2:3
Report: hciconfig ID: hci0 rfk-id: 0 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Local Storage: total: 912.89 GiB used: 209 GiB (22.9%)
ID-1: /dev/sda vendor: KIOXIA model: EXCERIA SATA SSD size: 447.13 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD5000AAJS-32TKA0
ID-1: / size: 146.82 GiB used: 29.94 GiB (20.4%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 291.17 GiB used: 103.53 GiB (35.6%) fs: ext4
dev: /dev/sda2
Swap:
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) file: /swap.img
ID-2: swap-2 type: zram size: 256 MiB used: 0 KiB (0.0%) dev: /dev/zram0
System Temperatures: cpu: 36.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB available: 31.25 GiB used: 3.59 GiB (11.5%)
Processes: 289 Uptime: 11m Init: systemd target: graphical (5)
Packages: 2720 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
... из отвалившегося : PortProton , ProtonVPN ... вроде и все ... может не все помацал :hoho: ... мультимедиа вся на месте с настройками и плюшками ... отпишусь если шо ... :)))
qwertKI
Ubuntu 24.04
25 апр 2024, 19:53
:))) ProtonVpn жив , улетела куча gnome extension (кто бы сомневался)...
qwertKI
Ubuntu 24.04
26 апр 2024, 20:07
коротко за впечатления ... если интересно ... поразило ... ожидал худшего , обновлять убунту на релизе - плохая примета ... рухнет :crazy: , пол-года не подходи, рискнул , накатил на 23.10 ... запустилась - уже гут ... траблов по системе ( инет, звук , графика ) просто нет , сделано с любовью ... отвалилось : Port Proton - ваашпе умер , только переустановка и задышал ( правда коряво, работает все а на созданные им ярлыки не реагирует , может и мои кривые руки ... разбираюсь, в процессе ...) vmware player - умер , переустановка , модули или отсутствуют или не подтягиваются штатно ( решение https://gist.github.com/YPermitin/9554d ... 409e681d46 помогло) ... часть gnome extensions не под 46-й ... ждем обнов ... звук порадовал , бомба , связка you tube ( soundcloud, spotify) + PipeWire + JamesDSP(эквалайзер) + блютуз уши рубит без заиканий (на 23.10 было и крепко ) как только не ганял ...и басы и верха , доводил до маразма - без провалов , как себе настоишь так и слушай ... mpv подхватил все настройки с лету и псевдо-HDR и прочее ... система грузиться вроде быстрее ... что еще ... ну радует :))) ... что думаю ... если это основа под грядущий Linux Mint ( а допиливать там умеют ) всех ждет вишенка на торте ... ... а я вернусь на минт :)))
qwertKI
Ubuntu 24.04
26 апр 2024, 20:32
... да чуть не забыл ... firefox опять прикрутили snap-овскую ... но это лечиться :)))
