Почему LM 21.3 Xfce c поднятием ядра до ver. 5.17.6 НЕ обновился до ver. 6.5 ?
sasha300
Решено: 6
Благодарил (а): 107 раз
03 апр 2024, 20:47
:hi2:
На борту LM 21.3 xfce
sas@NB264:~$ inxi -Fxz
Kernel: 5.17.6-051706-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Xfce 4.18.1 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Type: Laptop System: IRBIS product: NB264 v: N/A
serial: <superuser required>
Mobo: weibu model: Y116GRX200 serial: <superuser required>
UEFI: American Megatrends v: JLC-BI-14.1-Y116GRX200-171-B date: 04/23/2021
ID-1: BAT0 charge: 28.6 Wh (94.1%) condition: 30.4/N/A Wh volts: 8.2
min: N/A model: WB SR 1 WB Lion Battery status: Discharging
Info: dual core model: Intel Celeron N4020 bits: 64 type: MCP
arch: Goldmont Plus rev: 8 cache: L1: 112 KiB L2: 4 MiB
Speed (MHz): avg: 1695 min/max: 800/2800 cores: 1: 1695 2: 1695
bogomips: 4377
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: USB Camera CS type: USB driver: uvcvideo bus-ID: 1-8:5
unloaded: fbdev,vesa gpu: i915 resolution: 1368x768~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl bus-ID: 00:0e.0
Sound Server-1: ALSA v: k5.17.6-051706-generic running: yes
Message: No device data found.
IF-ID-1: wlx3095872d67ec state: up mac: <filter>
Bluetooth:
Device-1: Realtek RTL8723BU 802.11b/g/n WLAN Adapter type: USB
driver: btusb,rtl8xxxu bus-ID: 1-7:4
Report: hciconfig ID: hci0 rfk-id: 4 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.0
Local Storage: total: 148.45 GiB used: 25.39 GiB (17.1%)
ID-1: /dev/mmcblk0 model: S0J59X size: 118.56 GiB
ID-2: /dev/sda type: USB model: Mass Storage Device size: 29.89 GiB
ID-1: / size: 82.91 GiB used: 11.85 GiB (14.3%) fs: btrfs
dev: /dev/mmcblk0p2
ID-2: /boot/efi size: 511 MiB used: 30.1 MiB (5.9%) fs: vfat
dev: /dev/mmcblk0p1
ID-3: /home size: 82.91 GiB used: 11.85 GiB (14.3%) fs: btrfs
dev: /dev/mmcblk0p2
Swap:
ID-1: swap-1 type: partition size: 5.37 GiB used: 438.1 MiB (8.0%)
dev: /dev/mmcblk0p4
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 250 Uptime: 1d 8h 43m Memory: 3.65 GiB used: 2.45 GiB (67.2%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2087 Shell: Bash
v: 5.1.16 inxi: 3.3.13
sas@NB264:~$
С помощью Mainline поднял версию ядра до 5.17.6, ну и ожидал, что прилетит обнова до версии 6.х. И вот уже прошел 3-ий день с момента установки оси, а "sudo apt update" молчит.
На LM 21.2 xfce, при аналогичной ситуации, словил сей прикол, в ноябре 2023 года разместил аналогичный сабж "Почему обновилось ядро до версии 6.2.0.37 ?" где сказали, что c поднятием ядра LM превращается, превращается.. в EDGE (хотя какой EGDE, если у меня DE Xfce, а не Cinnamon), ну а тут что скажут товарищи эксперты?
p.s.: LM 21.2 xfce => up to kernel 5.17.7 => прилетает обнова до версии 6.х; LM 21.3 xfce => up to kernel 5.17.7 =>НЕ прилетает обнова до версии 6.х, хм, какая-то непонятка..
Решение WWolf » 04 апр 2024, 08:21
sasha300, значит там у тебя было какое-то из ядер 6.2 опробовано и висело в системе и потому прилетело обновление для той ветки.
03 апр 2024, 21:16
в минте никогда не было перехода автоматом между веток ядер, если на стабильных сидишь... всегда надо вручную смотреть появилась ли новая ветка или нет...
при этом если ты откатился от какого-то крайнего ядра, то и предлагать его не будет для обновления.
а 5.17 так вообще в минте не было никогда, а так как это ты сам поставил, то и обновлять не будет предлагать, так как тебе виднее что ставить...
ilikethat
Решено: 10
Благодарил (а): 129 раз
03 апр 2024, 23:14
sasha300, отвыкай. Это windows думала за тебя. А тут свобода и ответственность! :-D
Собственно WWolf уже сказал, установка вручную ядра, не ведет к его автоматическому обновлению.
Если нужно свежее ядро, зайди в Менеджер обновлений, пункт меню Ядра и поставь свежее. Если эта ветка, 6.5 к примеру, еще обновляется, то будут приходить и новые ядра.
sasha300
Решено: 6
04 апр 2024, 01:00
03 апр 2024, 21:16
ilikethat писал(а):
03 апр 2024, 23:14
Ну я бы и не спорил, если бы в ноябре 2023 года на LM 21.2 Xfce не словил мажорное обновление ядра, даже запостил вопрос (ссылка на тот топик: Почему обновилось ядро до версии 6.2.0.37 ?) и там подсказали, что с повышением версии ядра система стала считать себя версией "EDGE", поэтому и прилетело обновление.
А сейчас я делаю аналогичные действия, только уже на LM 21.3 Xfce - обнова не прилетает.
Сдается мне, что в LM 21.2 Xfce был баг, который был принят за фичу, а в LM 21.3 Xfce эту ошибку убрали.
04 апр 2024, 01:22
Считать себя версией EDGE система не может, т.к. системы версии EDGE не существует. :)
Существует установочный дистрибутив EDGE с которого ставится обычный вариант системы с Cinnamon, но другим ядром. Результат - практически как если бы сначала поставили с обычного дистрибутива Cinnamon а потом обновили ядро до одной из mainline веток. По сути, нужен именно этот вариант дистрибутива исключительно тем, кого железо настолько новое, что на обычном ядре вообще никак не стартует, и обновиться после установки - не вариант. Остальным он технически не нужен (тот же результат достигается обычной установкой и обновлением).
Переход с ветки на ветку mainline ядер через менеджер обновлений иногда происходит форсировано. Например, когда ядро установленной ветки достигает EOL и при этом известно о каких-то серьезных проблемах найденных в последней версии. Но в основном - автоматически их не меняют.
04 апр 2024, 08:21
Вернуться в «Общие вопросы по системе»
