konstantin@bkl-B550M-K:~$ inxi -Fxz
Kernel: 6.5.0-26-generic x86_64 bits: 64 compiler: N/A Desktop: MATE 1.26.0
Distro: Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy
Type: Desktop System: Gigabyte product: B550M K v: -CF
serial: <superuser required>
Mobo: Gigabyte model: B550M K v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F2 date: 03/01/2023
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 1696 high: 2994 min/max: 400/4464 cores: 1: 2994
2: 2994 3: 400 4: 400 5: 400 6: 400 7: 2994 8: 2993 9: 400 10: 400 11: 2994
12: 2991 bogomips: 93423
Device-1: AMD vendor: ASRock driver: amdgpu v: kernel bus-ID: 03:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa gpu: amdgpu
resolution: 3840x2160~60Hz
OpenGL: renderer: GFX1102 (gfx1102 LLVM 15.0.7 DRM 3.54 6.5.0-26-generic)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 08:00.1
Device-3: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 08:00.6
Sound Server-1: ALSA v: k6.5.0-26-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 142.78 GiB (7.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO with Heatsink 2TB
size: 1.82 TiB temp: 31.9 C
ID-1: / size: 154.78 GiB used: 20.89 GiB (13.5%) fs: ext4
dev: /dev/nvme0n1p1
ID-2: /boot/efi size: 952.1 MiB used: 6.1 MiB (0.6%) fs: vfat
dev: /dev/nvme0n1p4
ID-3: /home size: 640.99 GiB used: 121.87 GiB (19.0%) fs: ext4
dev: /dev/nvme0n1p2
Swap:
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 33.0 C mobo: 29.0 C gpu: amdgpu temp: 33.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 311 Uptime: 1h 26m Memory: 15.47 GiB used: 2.26 GiB (14.6%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2553 Shell: Bash
v: 5.1.16 inxi: 3.3.13
