Не работает принтер HUAWEI PixLab X1
°Feijoada°
Благодарил (а): 4 раза
19 мар 2024, 17:59
Не работает принтер HUAWEI PixLab X1 на Linux Mint 21.3 Virginia
Система видит принтер (подключен через провод) но выдаёт ошибку COPS server error
Что можно сделать для того чтобы принтер заработал?
  Kernel: 6.5.0-26-generic x86_64 bits: 64 compiler: N/A
    base: Ubuntu 22.04 jammy
  Type: Laptop System: Micro-Star product: Katana 17 B12UCR v: REV:1.0
    serial: <superuser required>
  Mobo: Micro-Star model: MS-17L5 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: E17L5IMS.30F date: 10/02/2023
  ID-1: BAT1 charge: 50.5 Wh (96.6%) condition: 52.3/52.0 Wh (100.6%)
    volts: 12.8 min: 11.4 model: MSI BIF0_9 status: Not charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
    charge: 55% (should be ignored) status: Discharging
  Info: 8-core (4-mt/4-st) model: 12th Gen Intel Core i5-12450H bits: 64
    type: MST AMCP arch: Alder Lake rev: 3 cache: L1: 704 KiB L2: 7 MiB
    L3: 12 MiB
  Speed (MHz): avg: 421 high: 493 min/max: 400/4400:3300 cores: 1: 493
    2: 491 3: 400 4: 400 5: 400 6: 400 7: 400 8: 470 9: 400 10: 400 11: 400
    12: 400 bogomips: 59904
  Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Micro-Star MSI
    driver: i915 v: kernel bus-ID: 0000:00:02.0
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Micro-Star MSI
    driver: N/A bus-ID: 0000:01:00.0
  Device-3: Luxvisions Innotech Integrated Camera type: USB
    driver: uvcvideo bus-ID: 1-6:4
    unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~144Hz
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2)
    v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    vendor: Micro-Star MSI driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3
  Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
    bus-ID: 0000:01:00.1
  Sound Server-1: ALSA v: k6.5.0-26-generic running: yes
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3
    vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000
    bus-ID: 0000:03:00.0
Bluetooth:
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-10:5
    bt-v: 3.0 lmp-v: 5.2
RAID:
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 bus-ID: 0000:00:0e.0
  Local Storage: total: 479.26 GiB used: 33.84 GiB (7.1%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PGP4512Q-AI
    size: 476.94 GiB temp: 26.9 C
  ID-2: /dev/sdb type: USB vendor: Hitachi model: HUAWEI PixLab X1
  ID-1: / size: 465.29 GiB used: 16.39 GiB (3.5%) fs: ext4 dev: /dev/dm-1
    mapped: vgmint-root
  ID-2: /boot size: 1.61 GiB used: 887.9 MiB (54.0%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-3: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
    dev: /dev/nvme0n1p1
Swap:
  ID-1: swap-1 type: partition size: 980 MiB used: 0 KiB (0.0%)
    dev: /dev/dm-2 mapped: vgmint-swap_1
  System Temperatures: cpu: 53.0 C mobo: N/A
  Processes: 348 Uptime: 6h 22m Memory: 7.46 GiB used: 4.22 GiB (56.6%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2221 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Благодарил (а): 1228 раз
19 мар 2024, 18:08
Из отзывов покупателей:
(5) Выбор OS: Windows, Mac, Android (но Linux не обещают!)
https://www.dns-shop.ru/product/d4e0111 ... pixlab-x1/
°Feijoada°
19 мар 2024, 18:13
hellonet, получается данный аппарат может вообще не работать на ОС Линукс?
19 мар 2024, 20:13
°Feijoada° писал(а):
19 мар 2024, 18:13
Скорее всего да. У меня принтер Ricoh 240 тоже не работает. Уже лет 6 пытаюсь дрова найти. Правильно определяется, но увы тоже не печатает
°Feijoada°
20 мар 2024, 09:52
Вопрос актуален, просьба помочь найти драйвер.
Вознаграждение гарантируется!
Для просмотра скрытого текста необходимо быть авторизованным пользователем.
20 мар 2024, 15:15
20 мар 2024, 09:52
По вопросам сюда: mikail7d6@yandex.ru
Согласно правил форума (пункт 3 l) - запрещается указывать в своем вопросе e-mail (icq) и другие каналы связи, с просьбой ответить по нему на вопрос. Используйте возможность подписаться на интересующую Вас тему. #
20 мар 2024, 15:20
hellonet, ну захотел спам фильтр натренировать :-D
21 мар 2024, 10:15
Так автор, вроде бы, автоматически уже подписан на тему, так как он является автором. Как второй вариант, можно было сказать, что очень ждёт решений в ЛС.
21 мар 2024, 11:25
madesta писал(а):
21 мар 2024, 10:15
Всех нюансов правила не могут предусмотреть. Общий смысл ясен - домашний адрес сюда выкладывать не нужно :-)
cyber
07 июл 2025, 10:47
0. Качаем x64 драйвер с китайской версии сайта
1. Распаковываем архив и устанавливаем пакет.
2. Добавляем принтер как JetDirect, если используется подключение по Wi-Fi (подключение вида socket://ip_addr)
3. Вы великолепны!
