Успешное обновление стационарного ПК
1o4ka
Благодарил (а): 23 раза
26 фев 2024, 09:15
Воротясь из долгих странствий, успешно обновил стационарный ПК до версии Linux Mint 21.3 Virginia:
$ inxi -Fxz
Kernel: 5.15.0-97-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F9 date: 08/11/2015
Info: dual core model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 3180 high: 3184 min/max: 800/3200 cores: 1: 3176
2: 3184 bogomips: 12771
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce GTX 750] vendor: Palit Microsystems
driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3
unloaded: fbdev,vesa gpu: nouveau resolution: 1920x1080~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 23.2.1-1ubuntu3.1~22.04.2
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Palit Microsystems driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-4: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.15.0-97-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-1:2
IF: wlxc46e1f210c3f state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 1.35 TiB used: 67.74 GiB (4.9%)
ID-1: /dev/sda vendor: TeamGroup model: T253480GB size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-3: /dev/sdc vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-1: / size: 91.11 GiB used: 39.71 GiB (43.6%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 569.9 MiB used: 31.4 MiB (5.5%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 332.16 GiB used: 28 GiB (8.4%) fs: ext4 dev: /dev/sda4
Swap:
ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/sdb5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 34.0 C
Processes: 226 Uptime: 23h 25m Memory: 15.51 GiB used: 3.01 GiB (19.4%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2820 Shell: Bash
v: 5.1.16 inxi: 3.3.13
На сей раз, в отличие от ноутбука, всё прошло в течение 10-ти минут. Ничего не отвалилось. Обновления встали отлично. Оно и понятно: стабильный и быстрый интернет (~100Мб/с) много чего значит в деле обновления.
Претензий к Вирджинии у меня нет.
Я тут почитал посты пользователей. Что могу сказать. Всё, что мне надо, на ПК работает. Со ждущим режимом, к примеру, никаких проблем. В общем, пока, всё нормально.
Чего и всем желаю.
...bis dat qui cito dat
SHERI_FFF
Благодарил (а): 33 раза
26 фев 2024, 10:47
А что теперь на каждое обновление ПК надо новую тему заводить? А если просто перезагрузил ПК, тоже можно?
________________________
Команды могу только копировать :hoho:
Ноутбук Acer Aspire 5 с Manjaro inxi -Fxz
ПК с Manjaro inxi -Fxz
26 фев 2024, 13:12
SHERI_FFF писал(а):
26 фев 2024, 10:47
Такое, наверное, в болталку надо переместить.
1o4ka
02 апр 2024, 15:25
madesta, в общем-то, можно и удалить. Просто, подобный случай в моей практике, пожалуй, впервые. Как-то всё чётко обновилось и ничего не отвалилось по дороге.
