linux mint не видит флешку вообще
linux_newbie
26 фев 2024, 01:49
в линуксе новичок... подключаю usb флешку (4 штуки перепробовал, пытался к смартфону подключить - на нем все норм) и система ее не видит... флешка Apacer 2GB
  Kernel: 5.15.0-97-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    base: Ubuntu 22.04 jammy
  Type: Desktop System: Gigabyte product: N/A v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: 970A-DS3P serial: <superuser required>
    UEFI: American Megatrends v: FD date: 02/26/2016
  Info: 8-core model: AMD FX-8320E bits: 64 type: MT MCP arch: Piledriver
    rev: 0 cache: L1: 384 KiB L2: 8 MiB L3: 8 MiB
  Speed (MHz): avg: 1864 high: 3390 min/max: 1400/3200 boost: enabled
    cores: 1: 1406 2: 1406 3: 1415 4: 1636 5: 3390 6: 2848 7: 1406 8: 1406
    bogomips: 51437
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Sapphire driver: amdgpu v: kernel bus-ID: 01:00.0
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
    unloaded: fbdev,modesetting,radeon,vesa gpu: amdgpu
    resolution: 2560x1080~60Hz
  OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 15.0.7 DRM
    3.42 5.15.0-97-generic)
    v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
  Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
    bus-ID: 00:14.2
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Sapphire driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Sound Server-1: ALSA v: k5.15.0-97-generic running: yes
    vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
  Local Storage: total: 1.36 TiB used: 27.37 GiB (2.0%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-35WN4A0
  ID-2: /dev/sdb vendor: Samsung model: HD501LJ size: 465.76 GiB
  ID-1: / size: 91.11 GiB used: 19.57 GiB (21.5%) fs: ext4 dev: /dev/sda7
  ID-2: /boot/efi size: 96 MiB used: 49.6 MiB (51.6%) fs: vfat
    dev: /dev/sda5
  ID-3: /home size: 124.51 GiB used: 7.74 GiB (6.2%) fs: ext4
    dev: /dev/sda8
Swap:
  ID-1: swap-1 type: partition size: 29.8 GiB used: 0 KiB (0.0%)
    dev: /dev/sda1
  System Temperatures: cpu: 33.6 C mobo: N/A gpu: amdgpu temp: 46.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 737
  Processes: 302 Uptime: 22m Memory: 15.64 GiB used: 2.85 GiB (18.2%)
  Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2442 Shell: Bash
  v: 5.1.16 inxi: 3.3.13
Диск /dev/sda: 931,51 GiB, 1000204886016 байт, 1953525168 секторов
Disk model: WDC WD10EZEX-35W
Размер сектора (логический/физический): 512 байт / 4096 байт
Размер I/O (минимальный/оптимальный): 4096 байт / 4096 байт
Тип метки диска: gpt
Идентификатор диска: 8FFF7C60-5251-03AB-18DF-FF6394D4EA00
Устр-во        начало      Конец   Секторы Размер Тип
/dev/sda1        2048   62500863  62498816  29,8G Linux своп
/dev/sda2   524290048 1236994047 712704000 339,8G Microsoft basic data
/dev/sda3  1236994048 1949698047 712704000 339,8G Microsoft basic data
/dev/sda4  1949698048 1950781439   1083392   529M Среда для восстановления Micro
/dev/sda5  1950781440 1950986239    204800   100M EFI
/dev/sda6  1950986240 1951019007     32768    16M Зарезервированный раздел Micro
/dev/sda7    62500864  257812479 195311616  93,1G Файловая система Linux
/dev/sda8   257812480  524290047 266477568 127,1G Файловая система Linux
Элементы таблицы разделов упорядочены не так, как на диске.
Диск /dev/sdb: 465,76 GiB, 500106780160 байт, 976771055 секторов
Disk model: SAMSUNG HD501LJ
Размер I/O (минимальный/оптимальный): 512 байт / 512 байт
Тип метки диска: dos
Идентификатор диска: 0xa579d6f1
Устр-во    Загрузочный    начало     Конец   Секторы Размер Идентификатор Тип
/dev/sdb1  *                  63 155653784 155653722  74,2G            83 Linux
/dev/sdb2              155653846 976750591 821096746 391,5G             f W95 ра
/dev/sdb5              155653848 565244976 409591129 195,3G             7 HPFS/N
/dev/sdb6              565247088 913837439 348590352 166,2G             7 HPFS/N
/dev/sdb7              913838080 976750591  62912512    30G             7 HPFS/N
[  926.181531] usb 8-1.1: new full-speed USB device number 5 using xhci_hcd
[  926.289374] usb 8-1.1: New USB device found, idVendor=09da, idProduct=9033, bcdDevice= 1.02
[  926.289390] usb 8-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  926.289398] usb 8-1.1: Product: USB Device
[  926.289403] usb 8-1.1: Manufacturer: A4TECH
[  926.298944] input: A4TECH USB Device Keyboard as /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb8/8-1/8-1.1/8-1.1:1.0/0003:09DA:9033.0005/input/input21
[  926.358224] input: A4TECH USB Device as /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb8/8-1/8-1.1/8-1.1:1.0/0003:09DA:9033.0005/input/input22
[  926.358674] hid-generic 0003:09DA:9033.0005: input,hiddev0,hidraw0: USB HID v1.11 Keyboard [A4TECH USB Device] on usb-0000:02:00.0-1.1/input0
[  926.364878] input: A4TECH USB Device as /devices/pci0000:00/0000:00:04.0/0000:02:00.0/usb8/8-1/8-1.1/8-1.1:1.1/0003:09DA:9033.0006/input/input23
[  926.365242] hid-generic 0003:09DA:9033.0006: input,hidraw1: USB HID v1.11 Mouse [A4TECH USB Device] on usb-0000:02:00.0-1.1/input1
Решение madesta » 26 фев 2024, 03:08
Я бы ваш вопрос разбил на 2 отдельных.
Первый – device not accepting address 25, error -32
Второй – device descriptor read/64, error -32
По первому можно было бы попробовать вот это, а по второму прочитать это.
Смущает ещё вот такая запись: usb usb1-port3: unable to enumerate USB device Так как, похоже, у вас Gigabyte, то попробуйте сделать как написано здесь в последнем комментарии.
Только делайте действия по одному и смотрите изменилось ли чего. Поскольку вы, как говорите, новичок, то записывайте или каким-либо другим образом фиксируйте свои действия, чтобы в случае необходимости вернуть в состояние "как было".
Может быть наши гуру ещё что-либо подскажут.
linux_newbie
26 фев 2024, 02:18
upd: при этом подключены клавиатура и мышь - оба usb - оба девайса более менее нормально работает... иногда отваливается мышь - решается перевтыканием в разъем...
[ 3312.883588] usb 1-3: new high-speed USB device number 25 using ehci-pci
[ 3313.299652] usb 1-3: device not accepting address 25, error -32
[ 3313.299707] usb usb1-port3: unable to enumerate USB device
[ 3319.935637] usb 1-3: new high-speed USB device number 26 using ehci-pci
[ 3320.063566] usb 1-3: device descriptor read/64, error -32
[ 3320.299634] usb 1-3: device descriptor read/64, error -32
[ 3320.535637] usb 1-3: new high-speed USB device number 27 using ehci-pci
[ 3320.667652] usb 1-3: device descriptor read/64, error -32
[ 3320.907611] usb 1-3: device descriptor read/64, error -32
[ 3321.015658] usb usb1-port3: attempt power cycle
26 фев 2024, 03:08
26 фев 2024, 08:24
linux_newbie, питания в порт не хватает похоже... Блок питания нормальный?
linux_newbie
26 фев 2024, 12:19
madesta писал(а):
26 фев 2024, 03:08
Спасибо! как с работы приду - изучу материал :)
linux_newbie
26 фев 2024, 12:20
26 фев 2024, 08:24
БП aero-cool на 550W... пока сидел на винде - с питанием проблем не было...
26 фев 2024, 12:55
Из любопытства поискал описание для Gigabyte model: 970A-DS3P Там, оказывается, 2 варианта: rev 1.0 и rev 2x. Леший его знает, может быть нужно втыкать именно в usb3.0/2.0, а не в usb2.0/1.1 (типа силы тока не хватает, чтобы флэшка завелась). Что касается того, что на винде проблем не было, то это не показатель, так как характеристики БП могли некоим образом ухудшиться одномоментно.
linux_newbie писал(а):
26 фев 2024, 02:18
У меня как-то одно время были проблемы с модемом wifi через usb, который резко переставал видеть точку доступа. При перезагрузке или перетыкании в разъёме всё становилось нормальнно. Предположил, что имеет место некое засыпание по usb и сделал себе выключение энергосбережения на usb (по крайней мере, заявлялось именно так): sudo xed /etc/default/grub и сделать
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend=-1", после чего sudo update-grub
linux_newbie
26 фев 2024, 18:39
madesta писал(а):
26 фев 2024, 12:55
26 фев 2024, 02:18
Спасибо! Прочитал всю информацию по предоставленным ссылкам и ситуация совпала с этой :hshake:
