Нет звука в наушниках по радиоканалу.
Piul
20 фев 2024, 10:23
Имеется:
  Kernel: 5.15.0-94-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Desktop: Cinnamon 6.0.4
    tk: GTK 3.24.33 wm: muffin vt: 7 dm: LightDM 1.30.0 Distro: Linux Mint 21.3 Virginia
    base: Ubuntu 22.04 jammy
  Type: Desktop System: HUANANZHI product: N/A v: N/A serial: <superuser required>
  Mobo: HUANANZHI model: X99-QD4 v: V1.0 serial: <superuser required> UEFI: American Megatrends
    v: 5.11 date: 10/10/2022
  Info: 14-core model: Intel Xeon E5-2680 v4 bits: 64 type: MT MCP smt: enabled arch: Broadwell
    rev: 1 cache: L1: 896 KiB L2: 3.5 MiB L3: 35 MiB
  Speed (MHz): avg: 1432 high: 2903 min/max: 1200/3300 cores: 1: 1197 2: 1198 3: 1197 4: 1197
    5: 1198 6: 1198 7: 1325 8: 1198 9: 1198 10: 1198 11: 1635 12: 2018 13: 1198 14: 1780 15: 1197
    16: 1197 17: 1198 18: 1687 19: 1197 20: 1197 21: 1359 22: 1197 23: 1197 24: 1197 25: 2903
    26: 2299 27: 1197 28: 2359 bogomips: 134093
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Tul driver: amdgpu v: kernel pcie:
    speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-3 empty: DP-1,HDMI-A-1 bus-ID: 05:00.0
    chip-ID: 1002:73ff class-ID: 0300
  Device-2: Sunplus Innovation SPCA2650 PC Camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 3-1:2 chip-ID: 1bcf:0c15 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
    unloaded: fbdev,modesetting,radeon,vesa gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x2880 s-dpi: 96 s-size: 677x762mm (26.7x30.0") s-diag: 1019mm (40.1")
  Monitor-1: DisplayPort-1 mapped: DP-2 pos: primary,bottom model: GA271 serial: <filter>
    res: 2560x1440 hz: 60 dpi: 109 size: 598x336mm (23.5x13.2") diag: 685mm (27") modes:
    max: 2560x1440 min: 720x400
  Monitor-2: DisplayPort-2 mapped: DP-3 pos: primary,top model: GA271 serial: <filter>
  OpenGL: renderer: AMD Radeon RX 6600 (navi23 LLVM 15.0.7 DRM 3.42 5.15.0-94-generic)
    v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
  Device-2: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] driver: snd_hda_intel
    v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-3: Sunplus Innovation SPCA2650 PC Camera type: USB driver: snd-usb-audio,uvcvideo
  Device-4: Weltrend Temple type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-9:6
    chip-ID: 040b:0897 class-ID: 0300
  Sound Server-1: ALSA v: k5.15.0-94-generic running: yes
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.87 TiB used: 24.47 GiB (1.3%)
  ID-1: /dev/nvme0n1 vendor: Seagate model: XPG GAMMIX S11 Pro size: 476.94 GiB speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 32A1TCTB temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 vendor: Seagate model: XPG GAMMIX S11 Pro size: 476.94 GiB speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 32A1TCTB temp: 36.9 C scheme: GPT
  ID-3: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB speed: 6.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
  ID-4: /dev/sdb type: USB vendor: Netac model: OnlyDisk size: 29 GiB type: N/A serial: <filter>
    rev: 3.00 scheme: MBR
  ID-1: / size: 136.45 GiB used: 18.92 GiB (13.9%) fs: ext4 dev: /dev/nvme1n1p2
  ID-2: /boot/efi size: 96 MiB used: 31.1 MiB (32.4%) fs: vfat dev: /dev/nvme0n1p1
  ID-3: /home size: 329.96 GiB used: 2.6 GiB (0.8%) fs: ext4 dev: /dev/nvme1n1p3
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2 file: /swapfile
USB:
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
    class-ID: 0900
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
    chip-ID: 8087:8008 class-ID: 0900
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
    class-ID: 0900
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s
    chip-ID: 8087:8000 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 15 rev: 2.0 speed: 480 Mb/s
    chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 3-1:2 info: Sunplus Innovation SPCA2650 PC Camera type: Video,Audio
    driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 3-3:3 info: Microdia Redragon Mitra RGB Keyboard type: Keyboard,Mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 400mA chip-ID: 0c45:5004
    class-ID: 0301
  Device-3: 3-4:4 info: HP HyperX Pulsefire Haste 2 type: Mouse,Keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 100mA
    chip-ID: 03f0:0b97 class-ID: 0300
  Device-4: 3-6:5 info: Netac OnlyDisk type: Mass Storage driver: usb-storage interfaces: 1
    rev: 2.1 speed: 480 Mb/s power: 100mA chip-ID: 0dd8:3708 class-ID: 0806 serial: <filter>
  Device-5: 3-9:6 info: Weltrend Temple type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid
    interfaces: 4 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 040b:0897 class-ID: 0300
  Hub-6: 4-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003
    class-ID: 0900
  System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 45.0 C mem: 50.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Repos:
  Packages: 2323 apt: 2309 flatpak: 14
  No active apt repos in: /etc/apt/sources.list
    1: deb http: //packages.linuxmint.com virginia main upstream import backport
    2: deb http: //archive.ubuntu.com/ubuntu jammy main restricted universe multiverse
    3: deb http: //archive.ubuntu.com/ubuntu jammy-updates main restricted universe multiverse
    4: deb http: //archive.ubuntu.com/ubuntu jammy-backports main restricted universe multiverse
    5: deb http: //security.ubuntu.com/ubuntu/ jammy-security main restricted universe multiverse
  Processes: 462 Uptime: 6m wakeups: 0 Memory: 31.18 GiB used: 4.4 GiB (14.1%) Init: systemd
  v: 249 runlevel: 5 Compilers: gcc: 11.4.0 alt: 11/12 Client: Cinnamon v: 6.0.4 inxi: 3.3.13
Наушники : Радиочастотная гарнитура ARDOR GAMING Temple.
Параллельно стоит винда, на винде наушники работают через провод, по радиоканалу, по БТ, на линуксе работают только по проводу, по БТ не работают, по радиоканалу не работают, НО, когда вынимаю и вставляю обратно флэшку наушников (с которой они конектятся) на пол секунды появляется звук в левом ухе и сразу пропадает. Система наушники видит
sheridan
Решено: 14
Благодарил (а): 900 раз
20 фев 2024, 19:13
Piul, Если у тебя две оси, то ключи в мак адресе не совпадают, из-за этого необходимо новая инициализация наушников после винды в линуксе
Вернуться в «Звуковые карты»
